Pagina 42 di 50 primaprima ... 324041424344 ... ultimoultimo
Visualizzazione dei risultati da 411 a 420 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #411
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    sure, also works for the z7mini
    Do you have any plans for ANDOIRD 7?
    repo init -u git://github.com/omnirom/android.git -b android-7.0
    Quote Originariamente inviato da awssong Visualizza il messaggio
    I don't like omnirom
    read the answer that I wrote yesterday
    https://www.androidiani.com/forum/in...ml#post7621809
    Nubia Z7MAX
  4. #413
    Jul 2016
    Paolo, you can have a look in my git if you want, i used bacon bluetooth kernel files, bdroid_build.cfg, and returned the hci_qcomm_init (using the bacon blob). I am not sure yet, but i feel a huge change in responsiveness in anything bluetooth related, i even set up my phone via a2dp to my computer, playing music for 2 hours now, no stuttering anywhere(even had some calls,music continued playing on its own after them). It surely needs more testing, but i think we are on the right path for this damned a2dp bug .
  5. #414
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    ok thanks, I will look and I will try
    It is a week that I'm working on CM14 but at the moment the source code is still very messed up (missing pieces and many are still buggy)
    this morning I finally managed to complete the first compilation but the phone doesn't start
    but no problem, I continue to work on it
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (04-09-16)
  7. #415
    Jul 2016
    Wow, you sure are brave for trying nougat so soon, I would wait till we have the first cm14(not aosp) roms for bacon. I will try my best to help once I find some time. I hope that solving the bugs in the current tree will prevent them from popping up in nougat builds.
  8. #416
    CM14.0, after a week of works now boot !!
    there is a really lot of bugs (nothing works....no sim, no wifi, no bluetooth, no audio, no camera etc etc....but infrared works lol).....but now start !!!
    screenshot
    Nubia Z7MAX
  9. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (07-09-16),mai62 (05-09-16)
  10. #417
    Nov 2015
    screenshot
    Thank you for your hard work! We are looking forward to your work, I hope you to upload the same source as before, so that we can make progress together with you! Come on.
  11. #418
    Nov 2015
    I am in the process of compiling, encountered this error, how do you solve it?
    build/core/ninja.mk:148: recipe for target 'ninja_wrapper' failed
    make: *** [ninja_wrapper] Error 1
    I use the staging/cm-14.0. CM and then I use the DEVICE. you provided
  12. #419
    sure but for the moment it is too early to release the device tree, there are too many bugs
    the cm14 source codes are very bugged at the moment, I worked six days just to be able to compile without error....
    Nubia Z7MAX
  13. #420
    release V13 in first page
    Nubia Z7MAX
  14. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (09-09-16)
