Pagina 44 di 50 primaprima ... 344243444546 ... ultimoultimo
Visualizzazione dei risultati da 431 a 440 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #431
    Oct 2016
    Hi!
    I'm having a question concerning the CM 13 ROM: Does anybody else have problems with the alarm? If the phone is off, it does not power on to wake me up.
    Regards
    rel V14 in first page
    Quote Originariamente inviato da willhaben79 Visualizza il messaggio
    Hi!
    Regards
    yes, the alarm not work if the phone is off
    Nubia Z7MAX
  4. #433
    Jul 2016
    Hey paolo, nice to see you are still working ton the cm13 branch. Could you explain to me the reason you removed the omx libs out of the latest update? There are also some small changes in bluetooth and RIL configurations, hope you have the willingness and time to explain the reasoning behind your changes. It would really help me and the rest of the community become better, thank you!
  5. #434
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    because the omx libs are compiled from source so no need to use the old precompiled blobs of the nubia stock firmware
    for the ril configurations...simply they were useless so I removed
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    stomiobeach (25-10-16)
  7. #435
    Jul 2016
    Nubia released a new rom for the z7 max, 3.89. They claimed to to release he source code for third party development. I tried to insert the vendor blobs from that version, and they broke camera. They made quite a few changes to the camera, including software image stabilization, therefore it would be great if we could benefit from them. Hope you have the time to take a look too, paolo!
  8. #436
    yes, I tried with the new blobs on the cm14.1 but the camera doesn't work (like you)
    I'm also trying to port the new nubia camera app to cm14 (and cm13)
    so....I'm working on it
    edit:
    if you find links or more information about this please inform me, thanks
    Ultima modifica di PaoloW8; 02-11-16 alle 12:49
    Nubia Z7MAX
  9. #437
    Jul 2016
    I found the rom here: ROM Z7Max(NX505J)V3.89 ?stable? | [Official]-[Updated] add the 10/28/2016 on Needrom . Last paragraph(google translated) says that this will be the last update for the z7 series, unless serious problems arise, and gives this email: rom@nubia.com , for anyone interested in 3rd party rom development. If we could get the new camera hal in source code, it would be really great. Has anyone tested the new rom to see if there is considerable impovement in camera quality? The low light quality could really use some help.
  10. #438
    ok thanks
    in the meantime I have fixed the problem with the new v3.89 camera blobs in cm14.1, now works fine
    now I restore a cm13.0 backup and try to fix here too
    however the port of the app nubia camera need more works to do
    Nubia Z7MAX
  11. #439
    Jul 2016
    Great news! Hope you can get the fix up in github soon.(Or just tell me how you did it )
  12. #440
    in cm13.0 it is easier than the cm14.1
    just copy this files from the 3.89 stock and it should work
    codice:
    paolo@Hal9000:/media/dati/Android/xx/system/system$ ls -R -l
    totale 12
    drwxrwxr-x 2 paolo paolo 4096 ott 31 06:56 bin
    drwxrwxr-x 3 paolo paolo 4096 nov  2 14:54 lib
    drwxrwxr-x 3 paolo paolo 4096 ott 31 06:54 vendor
    ./bin:
    totale 464
    -rw-rw-r-- 1 paolo paolo  58816 dic  5  2012 mm-qcamera-app
    -rw-rw-r-- 1 paolo paolo   9440 dic  5  2012 mm-qcamera-daemon
    ./lib:
    totale 13392
    drwxrwxr-x 2 paolo paolo    4096 ott 31 06:56 hw
    -rw-rw-r-- 1 paolo paolo   29852 dic  5  2012 libbuffer_manager.so
    -rw-rw-r-- 1 paolo paolo   26372 dic  5  2012 libchromatix_imx214_liveshot.so
    -rw-rw-r-- 1 paolo paolo 2944156 dic  5  2012 libFNVfbEngineHAL.so
    -rw-rw-r-- 1 paolo paolo 2328724 dic  5  2012 libFNVfbEngineLib.so
    -rw-rw-r-- 1 paolo paolo 8175376 dic  5  2012 libImageAlogrithm.so
    -rw-rw-r-- 1 paolo paolo   42208 dic  5  2012 libmmcamera_interface.so
    -rw-rw-r-- 1 paolo paolo   42088 dic  5  2012 libmmjpeg_interface.so
    -rw-rw-r-- 1 paolo paolo   79140 dic  5  2012 libmm-qcamera.so
    -rw-rw-r-- 1 paolo paolo   13572 dic  5  2012 libnubia_effect.so
    -rw-rw-r-- 1 paolo paolo    5128 dic  5  2012 libnubiajpeg.so
    ./lib/hw:
    totale 284
    -rw-rw-r-- 1 paolo paolo 288312 dic  5  2012 camera.msm8974.so
    ./vendor:
    totale 4
    drwxrwxr-x 2 paolo paolo 4096 ott 31 07:01 lib
    ./vendor/lib:
    totale 2152
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_default_video_4k.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_default_video.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_hfr_120.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_nightmode_1.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_nightmode_2.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_nightmode.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_ois_sharp_default_video_4k.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_ois_sharp_nightmode_2.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_preview4zsl.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_preview.so
    -rw-rw-r-- 1 paolo paolo  26372 dic  5  2012 libchromatix_imx214_snapshot.so
    -rw-rw-r-- 1 paolo paolo  42108 dic  5  2012 libmmcamera2_c2d_module.so
    -rw-rw-r-- 1 paolo paolo  62524 dic  5  2012 libmmcamera2_cpp_module.so
    -rw-rw-r-- 1 paolo paolo  25660 dic  5  2012 libmmcamera2_iface_modules.so
    -rw-rw-r-- 1 paolo paolo 134680 dic  5  2012 libmmcamera2_imglib_modules.so
    -rw-rw-r-- 1 paolo paolo 432240 dic  5  2012 libmmcamera2_isp_modules.so
    -rw-rw-r-- 1 paolo paolo  33896 dic  5  2012 libmmcamera2_pproc_modules.so
    -rw-rw-r-- 1 paolo paolo 160232 dic  5  2012 libmmcamera2_sensor_modules.so
    -rw-rw-r-- 1 paolo paolo  83120 dic  5  2012 libmmcamera2_stats_modules.so
    -rw-rw-r-- 1 paolo paolo  43112 dic  5  2012 libmmcamera2_vpe_module.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_gbao_imx214_lc898122_eeprom.so
    -rw-rw-r-- 1 paolo paolo  17968 dic  5  2012 libmmcamera_imx135_front.so
    -rw-rw-r-- 1 paolo paolo  17944 dic  5  2012 libmmcamera_imx135_gbao_lc898122.so
    -rw-rw-r-- 1 paolo paolo  17944 dic  5  2012 libmmcamera_imx135_gbao.so
    -rw-rw-r-- 1 paolo paolo  19296 dic  5  2012 libmmcamera_imx135_z5s_069.so
    -rw-rw-r-- 1 paolo paolo  19328 dic  5  2012 libmmcamera_imx135_z5s.so
    -rw-rw-r-- 1 paolo paolo  12028 dic  5  2012 libmmcamera_imx214_ois_sharp.so
    -rw-rw-r-- 1 paolo paolo  12800 dic  5  2012 libmmcamera_imx214.so
    -rw-rw-r-- 1 paolo paolo   5256 dic  5  2012 libmmcamera_liteon_imx214_eeprom.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_ofilm_oty5f03_eeprom.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_sharp_imx214_ois_eeprom.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_sunny_p12v01m_eeprom.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_sunny_p5v23c_eeprom.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_sunny_q8v18a_eeprom.so
    -rw-rw-r-- 1 paolo paolo   5204 dic  5  2012 libmmcamera_truly_cm7700_eeprom.so
    -rw-rw-r-- 1 paolo paolo 562244 dic  5  2012 libmmcamera_tuning.so
    -rw-rw-r-- 1 paolo paolo  37992 dic  5  2012 liboemcamera.so
    Ultima modifica di PaoloW8; 02-11-16 alle 22:58
    Nubia Z7MAX
  13. Il seguente Utente ha ringraziato PaoloW8 per il post:
    pchatzop (03-11-16)
