Pagina 40 di 50 primaprima ... 303839404142 ... ultimoultimo
Visualizzazione dei risultati da 391 a 400 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #391
    Jul 2016
    Forgot to add: the blobs are from the nubia z5s. Users in the 4pda confirm that they completely solved the bug. Please test and tell which i have to keep in order to have it fixed without worse call audio quality.
    ok I have tried the new blobs but the problem still exist, nothing changed
    for the vulnerability....I have compared my kernel source code and your source code and the vulnerability patches are the same but to me the 2 apps show two different vulnerabilities
    quadrooter: Imgur: The most awesome images on the Internet
    qualcomm: Imgur: The most awesome images on the Internet
    I don't know why
    edit:
    I have recompiled right now the whole rom so now I will retry with the new blobs
    Ultima modifica di PaoloW8; 11-08-16 alle 23:04
    Nubia Z7MAX
  4. #393
    No, I tried and tried and the new blobs not fix the bluetooth problem
    Nubia Z7MAX
  5. #394
    release V12 in first page
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (13-08-16)
  7. #395
    Jul 2016
    I am having some issues with messenger calls with my latest build with the rel12 changes(havent got a chance to test these in a long time). Do they work okay in your end? For me, i can hear the other side just fine, but they cannot hear me.
  8. #396
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    which messenger ?
    anyway, the only thing I changed for the audio is the audio_effects.conf, you can try with the old version
    Nubia Z7MAX
  9. #397
    Jul 2016
    The facebook messenger, but i guess viper and skype(all voip calls) will have the same issue. Anyways, trying with old audio_effects.conf.
  10. #398
    Jul 2016
    Tried merging this commit : https://github.com/CyanogenMod/andro...7ce4e5cb1808d0 . Did not help, microphone is not working on facebook messenger or skype. It did improve voice quality though(because of qualcomm fluence), thinking about keeping it in place. Hope you have some idea to solve that.
  11. #399
    I just tried now a call with whatsapp, no problem here
    (I not use skype or other voip app)
    edit:
    you use the original acdb blobs or the z5s version ?
    Ultima modifica di PaoloW8; 15-08-16 alle 12:30
    Nubia Z7MAX
  12. #400
    Jul 2016
    I am using the original blobs for everything except bluetooth. I wasnt using whatsapp before, tried it and the mic worked for that app. It just wont work on facebook messenger and skype so far. This is really weird, considering i have not used messenger for calls since rel v9, and it worked fine then. Maybe this is a cm source issue? Could be the new CMAudioService breaks something. If you could test skype too, i would be grateful, since i cannot test CM right now, or i have to format my internal storage(/data and /cache are in f2fs in my rom).
