Pagina 43 di 50 primaprima ... 334142434445 ... ultimoultimo
Visualizzazione dei risultati da 421 a 430 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #421
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    CM14.0, after a week of works now boot !!
    there is a really lot of bugs (nothing works....no sim, no wifi, no bluetooth, no audio, no camera etc etc....but infrared works lol).....but now start !!!
    screenshot
    How do you compile the CM14? Can be normal use it?
    sorry but I have been 4 days without Internet -.-
    a little update on the CM14 status:
    What I Fixed:
    audio
    bluetooth
    sim (both), the signal is unstable, I must investigate better
    lte/h+ data connection
    gps
    buttons, led etc
    infrared
    What is still not working
    wifi (doesn't turn on)
    camera (both)
    sensors
    I continue to work on it
    edit:
    wifi fixed
    reedit:
    sensors fixed
    Ultima modifica di PaoloW8; 17-09-16 alle 21:27
    Nubia Z7MAX
  4. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (17-09-16),mai62 (17-09-16),migel121 (19-09-16)
  5. #423
    little update of the CM14 status:
    camera fixed
    radio fm fixed
    I just need to fix the random rild crash before releasing a first aplha version
    Nubia Z7MAX
  6. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (20-09-16),mai62 (20-09-16)
  7. #424
    Sep 2016
    Thanks for your hard work !!!
  8. #425
    Aug 2015
    Thx for your work !!
    looking forward to the first stable veison !
  9. #426
    Nov 2015
    camera fixed
    radio fm fixed
    Thank you for your hard work, they will believe that milk powder works for you praise! Hope to see your work as soon as possible.
  10. #427
    Sep 2016
    hope u can finish the CM14 quickly or u update a latest CM14 to the MEGA(only for test)
  11. #428
    CM14 status
    ok I have not yet fixed the problem of random rild crash but I think today or tomorrow to release a first alpha version.
    Also I will update my github so if someone wants to work on it will do
    Ultima modifica di PaoloW8; 29-09-16 alle 12:24
    Nubia Z7MAX
  12. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (29-09-16)
  13. #429
    Nubia Z7MAX
  14. #430
    Nov 2015
    CM14 status
    Very much looking forward to, but also very grateful! We almost every day to see the posts have not updated.
