Pagina 10 di 19 primaprima ... 89101112 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #91
    Jul 2016
    Yes, I used the 7.1 arm nano gapps
    Quote Originariamente inviato da inhalt Visualizza il messaggio
    with the cm14.0 you have the same issue ?
    if not you can try to install the cm14.0 and update to the cm14.1 without the full wipe
    Nubia Z7MAX
  4. #93
    Jul 2016
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    I didn't try 14.0 but will try this way you say the next time I flash it. Thanks
  5. #94
    Jul 2016
    I think the problem was SuperSU. I had it installed the previous times when the problem occurred. I tried to flash again without installing it afterwards and rebooted several times without a problem...
    So there must be some kind of incompatibility with this build and SuperSU that will make you flash the rom all over again.
  6. #95
    Nov 2016
    ZTE Z5 Mini
    Hi, i want to ask you if you can make cm-14.0 for ZTE Z5 mini (Nx402 or Nx40x), or help me, since i was testing a few customs rom on my device ZTE Z5 mini (NX402) and when i flash these roms in around 5 minutes it shows no signal but it recognize the simcard, i mean that i can access the simcard and i can see also the operator, but it says "Only emergency calls", a then when i return to my previous rom, also custom but 4.4.4, i can make calls without any problem, please help me with this, we are a comunity of users with this device and we don´t know how port CM14 to this device, i will apreciate, thanks and sorry for my poor english.
  7. #96
    why you use supersu ?
    root is already present in rom, you just need to enable it in developer options
    Quote Originariamente inviato da osavigne Visualizza il messaggio
    I answered you in PM
    Nubia Z7MAX
  8. #97
    I still can't edit the first message -.-
    so for now I write here, tomorrow I will open a new thread:
    CM14.1 (beta2)
    Changelog:
    • 11/11/2016 beta2 (MD5: de24780ba73c5ffc3590e1b31c4f197f)
      • due to some recent changes to the phone DB the upgrade from a previous version (beta1 or older) may not work (FC android.phone and not detect the sim). in this case you must do the full wipe and reflash.
      • Security patch November 2016
      • kernel: some security patch
      • proprietary blobs updated from latest stock firmware 3.89 (with new camera blobs)
      • sync cyanogen source code (11/11/2016)
    Nubia Z7MAX
  9. #98
    Jul 2016
    Hi Paolo!! I had to go back to RR rom from your 14.1 beta1 cause the touch screen would stop working randomly and made me reboot like twice a day...
    Now I'm up to trying your beta2 and so far so good Will report any issues as they happen. Cheers!
  10. #99
    Nov 2016
    LG G5 h850, Zte NubiaZ7 nx505j
    Niice, for a while this rom was working even better than my older Cm14.1 Lg G5 , I'll test it now !
  11. #100
    Nov 2016
    ZTE Z5 Mini
    Hi, i´m trying to make a CM-13.0 for my nx402 (ZTE Z5 mini), and i´m getting this error:
    make: *** No rule to make target '/home/otto/android/system/out/target/product/nx402/obj/SHARED_LIBRARIES/libril_intermediates/export_includes', needed to '/home/otto/android/system/out/target/product/nx402/obj/EXECUTABLES/rild_intermediates/import_includes'. Stop.
    What can it be, i already do a few times a repo sync and a make clean and nothing, any sugestions?
    I want to make also a CM14.1 for this device, but i get this also:
    build/core/binary.mk:1231: external/deqp/Android.mk: libdeqp: Unused source files: \
    build/core/binary.mk:1231: external/pdfium/third_party/pdfiumbigint . mk: libpdfiumbigint: Unused source files: bigint/BigInteger.cc bigint/BigIntegerUtils.cc bigint/BigUnsigned.cc bigint/BigUnsignedInABase.cc
    build/core/package_internal . mk:143: Empty argument supplied to find-subdir-assets
    find: «/home/otto/android/system/out/target/common/obj/SHARED_LIBRARIES/libwifi-hal-mock_intermediates»: No existe el archivo o el directorio
    ./packages/apps/Settings/Android . mk:3: *** missing separator.
    build/core/ninja.mk:166: fallo en las instrucciones para el objetivo '/home/otto/android/system/out/build-cm_nx402 . ninja'
    make: *** [/home/otto/android/system/out/build-cm_nx402 . ninja] Error 1
    Please help me mates, i´m new on this stuff, thanks
