Pagina 11 di 19 primaprima ... 910111213 ... ultimoultimo
Visualizzazione dei risultati da 101 a 110 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #101
    Nov 2015
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    I still can't edit the first message -.-
    so for now I write here, tomorrow I will open a new thread:
    CM14.1 (beta2)
    Changelog:
    • 11/11/2016 beta2 (MD5: de24780ba73c5ffc3590e1b31c4f197f)
      • due to some recent changes to the phone DB the upgrade from a previous version (beta1 or older) may not work (FC android.phone and not detect the sim). in this case you must do the full wipe and reflash.
      • Security patch November 2016
      • kernel: some security patch
      • proprietary blobs updated from latest stock firmware 3.89 (with new camera blobs)
      • sync cyanogen source code (11/11/2016)
    Device tree code uploaded yet?Look forward to。
    Quote Originariamente inviato da awssong Visualizza il messaggio
    lol no, I completely forgot
    give me 10 minutes and I will update all
    edit:
    done
    Ultima modifica di PaoloW8; 13-11-16 alle 13:19
    Nubia Z7MAX
  4. Il seguente Utente ha ringraziato PaoloW8 per il post:
    brooklyn2006 (14-11-16)
  5. #103
    Nov 2016
    Hello. as firmware situation with playback of music via stereo bluetooth headset?
  6. #104
    Nov 2015
    edit:
    done
    Suitable for CM14. 1 where is the new camera setup?
  7. #105
    the camera.apk ?
    It doesn't work on Android 7, I'm trying to do the port.
    Nubia Z7MAX
  8. #106
    Nov 2015
    the camera.apk ?
    oh ,Thanks paolo!
  9. #107
    Oct 2016
    Hi Paolo, did cm14.1 officially fix the camera recording problem? Or you just applied some additional patches to fix it? Thanks.
  10. #108
    Quote Originariamente inviato da seth09 Visualizza il messaggio
    the fix is official and already merged in the cm14.1 source code
    Nubia Z7MAX
  11. #109
    Oct 2016
    Hi Paolo, currently I’m porting the proprietary files to z7mini. I noticed that some files are different from those of official ROM, indicating they are probably from somewhere else. Can I assume these files (as well as those missing in official rom) should also be able to work with Z7mini safely? Thanks.
    Files different from official rom:
    codice:
    bin\hci_qcomm_init
    bin\qseecomd
    lib\libSFB.so
    vendor\lib\drm\libdrmwvmplugin.so
    vendor\lib\egl\eglsubAndroid.so
    vendor\lib\egl\libEGL_adreno.so
    vendor\lib\egl\libGLESv1_CM_adreno.so
    vendor\lib\egl\libGLESv2_adreno.so
    vendor\lib\egl\libq3dtools_adreno.so
    vendor\lib\mediadrm\libwvdrmengine.so
    vendor\lib\libadreno_utils.so
    vendor\lib\libbccQTI.so
    vendor\lib\libC2D2.so
    vendor\lib\libc2d30-a3xx.so
    vendor\lib\libCB.so
    vendor\lib\libdrmdiag.so
    vendor\lib\libdrmfs.so
    vendor\lib\libdrmtime.so
    vendor\lib\libgsl.so
    vendor\lib\libllvm-qcom.so
    vendor\lib\libOpenCL.so
    vendor\lib\libQSEEComAPI.so
    vendor\lib\libril-qc-qmi-1.so
    vendor\lib\librpmb.so
    vendor\lib\librs_adreno.so
    vendor\lib\librs_adreno_sha1.so
    vendor\lib\libRSDriver_adreno.so
    vendor\lib\libsc-a3xx.so
    vendor\lib\libscale.so
    vendor\lib\libssd.so
    vendor\lib\libwvdrm_L3.so
    vendor\lib\libwvm.so
    vendor\lib\libWVStreamControlAPI_L3.so
    Files missing in official rom:
    codice:
    lib\libcurl_camera.so
    lib\libmorpho_image_converter.so
    lib\libmorpho_jpeg_io.so
    lib\libmorpho_memory_allocator.so
    lib\libmorpho_strobe_photo_jni.so
    vendor\lib\libdrmdecrypt.so
    vendor\lib\libuiblur.so
    vendor\lib\libWVphoneAPI.so
  12. #110
    They are the adreno and drm driver, I took them from the bacon (oneplus one) firmware
    yes, should also work on the z7mini
    Nubia Z7MAX
