Pagina 8 di 19 primaprima ... 67891018 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #71
    Nov 2015
    Quote Originariamente inviato da mai62 Visualizza il messaggio
    Thank you. I downloaded your file successfully. Tomorrow I'll try to flash. Now we have 4:00 night.
    CM14.1 Successfully compiled.
  2. Il seguente Utente ha ringraziato awssong per il post:
    mai62 (29-10-16)
    Quote Originariamente inviato da awssong Visualizza il messaggio
    yes
    I already merged all fix/patch (camera recording, battery icon customization) and I'm uploading the rom zip right now
    Nubia Z7MAX
  5. #73
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    yes
    Thanks!Paolo
  6. #74
    I don't know why but I can't edit the first message -.-
    so for now I write here:
    CM14.1 (beta1)
    Changelog:
    • switch to CM14.1 (Android 7.1)
    • 29/10/2016 beta1 (MD5: 88cac05a8c329c61dd3e28430de40c3b)
      • Android updated to 7.1 (CM14.1)
      • added all fix present in old cm14.0
      • sync cyanogen source codes (29/10/2016)
    Ultima modifica di PaoloW8; 29-10-16 alle 12:23
    Nubia Z7MAX
  7. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (29-10-16),mai62 (29-10-16)
  8. #75
    Nov 2015
    CM14.1 (beta1)
    Changelog:
    I see you upload the source code has not yet resolved you let you say the problem, CM14 and CM14.1 code is the same.
  9. #76
    what is the question ?
    yes, the device tree is the same
    Nubia Z7MAX
  10. #77
    Nov 2015
    For example: the camera video, the battery icon circle display, etc..
  11. #78
    Oct 2016
    Hi Paolo,
    I ported your nx505j device code to nx507j(Z7mini) and successfully compiled cm-14.1. The built works pretty well except for the proximity sensor. Sensors test shows the proximity functions correctly. But when making a call, the screen does not turn off. It would be appreciated if you could take a look at this problem. Thanks.
    ps: how do I post the log?
  12. #79
    These are patches to do in the rom sources
    Gerrit Code Review
    Gerrit Code Review
    Nubia Z7MAX
  13. #80
    Nov 2015
    Thanks!Thanks!
    Do you have a suitable course? I also want to learn to adapt to the new mobile phone. Thank you
