Pagina 13 di 19 primaprima ... 31112131415 ... ultimoultimo
Visualizzazione dei risultati da 121 a 130 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #121
    Nov 2015
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    gello is a precompiled apk
    when you compile the full rom gello.apk is downloaded from the cyanogen server so a internet connection is required during the compile process.
    I compile it in a network environment?
    Jul 2016
    Only kinda serious bug i encountered till now(on my build) is that sdcard is mounted correctly and system can read and write to it, but normal apps can not find it. I can navigate to /mnt/media_rw/(sdcard id) and read and write files with a rooted file manager, but it makes it kinda unusable for the rest of the system. Does that happen to your builds? It looks like a cm source bug, but if you did find a workaround it would be great. Also, adoptable storage was removed from nougat? Hope it isn't, it is a great feature!
    Ultima modifica di pchatzop; 01-12-16 alle 04:44
  4. #123
    Oct 2016
    Is there a way to enable on-screen navigation bar?
  5. #124
    Nov 2015
    http://schemas.android.com/apk/res/android
    139Nav网上导航提醒您:很抱歉,您访问的页面不存在
  6. #125
    Nov 2015
    Quote Originariamente inviato da awssong Visualizza il messaggio
    https://maven.cyanogenmod.org/artifa...nmod/gello/40/
  7. #126
    check this temporary fix
    https://review.cyanogenmod.org/#/c/174025/
    maybe you can try to regenerate the certificates with the command:
    codice:
    sudo update-ca-certificates -f
    Nubia Z7MAX
  8. #127
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    umh...I don't have any problem to access to the external sdcard...I just tried right now with the camera (I have configured to save the photos on the external sd) and works
    (with a file manager if you access from /storage/sdcard_id you don't need the root permission)
    Nubia Z7MAX
  9. #128
    Nov 2016
    LG G5 h850, Zte NubiaZ7 nx505j
    It should be a cm14.1 bug on cm file manager in symbolic links on bookmarks if you follow "/mnt/media_rw/xxxx-xxxx" you'll have access, btw I have a lg g5 also with cm14.1 and it has the same issue!
  10. #129
    link cm14.1_beta4
    changelog:
    • 07/12/2016 beta4 (MD5: da10907e8ca0d659237d2ae31f099800)
      • Android updated to 7.1.1
      • Security Patch December 2016
      • kernel: few security fix
      • kernel: fix color/temperature livedisplay driver
      • navigation bar: fix for enable/disable the navbar in settings->buttons (the physical buttons should automatically disable)
      • sync cyanogen source code (07/12/2016)
    Ultima modifica di PaoloW8; 07-12-16 alle 21:31
    Nubia Z7MAX
  11. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    andrerodr (07-12-16),brooklyn2006 (08-12-16)
  12. #130
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    link cm14.1_beta4
    changelog:
    Paolo, did you fix call disconnection?
