Pagina 18 di 19 primaprima ... 816171819 ultimoultimo
Visualizzazione dei risultati da 171 a 180 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #171
    Nov 2015
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    still can't edit the first message.....
    LineageOS cm14.1 beta8
    changelog:
    26/01/2017 beta8 (MD5: 57bcefa3a5324e3864e3f44fd9e3ea21)
    • due to a bug tun off the phone sometimes it does not work properly, temporarily if you need to turn off the phone using an app like quick reboot
    • kernel: updated to 3.4.113
    • kernel: added f2fs support (not tested)
    • kernel: security fix
    • audio: fix echo during call
    • audio: fix mic low volume
    • cover: initial support to smart cover, It is under development so at the moment is very limited (for enable the cover you need to flash the file CM_enablecover.zip)
    • various fixes around
    • sync LineageOS source code (26/01/2017)
    Running kati to generate build-lineage_nx505j.ninja...
    No need to regenerate ninja file
    Starting build with ninja
    ninja: Entering directory `.'
    ninja: error: 'system/extras/su/superuser.rc', needed by '/home/syai2012/rom/los/out/target/product/nx505j/system/etc/init/superuser.rc', missing and no known rule to make it
    build/core/ninja.mk:151: recipe for target 'ninja_wrapper' failed
    make: *** [ninja_wrapper] Error 1
    Why?
    Quote Originariamente inviato da awssong Visualizza il messaggio
    Why?
    codice:
    cd system/extras/su
    git reset --hard
    Nubia Z7MAX
  4. #173
    LineageOS cm14.1 beta9
    changelog:
    • 18/02/2017 beta9 (MD5: 3d20e9ee9e312756a3dcd075f93d62be)
      • fix poweroff bug
      • audio: some configuration changes
      • flipcover: configuration added in settings->flip cover
      • sync LineageOS source codes (18/02/2017)
    Nubia Z7MAX
  5. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (18-02-17)
  6. #174
    Jul 2015
    after wiped data , cache dalvik , then beta9 works on my phone (clean install) . otherwise there will be no launcher issue , even installed nova in beta8 upgrade will be fail.
  7. #175
    Feb 2017
    Without a custom kernel Z7 Max does not show the full potential.
  8. #176
    Aug 2015
    will lineage os support oms ?
  9. #177
    LineageOS cm14.1 beta10
    Changelog:
    • 07/03/2017 beta10 (MD5: 80977810b099f29e1a7d703bb9c09f32)
      • Security Patch February + March 2017
      • sync LineageOS source code (07/03/2017)
    Ultima modifica di PaoloW8; 07-03-17 alle 17:41
    Nubia Z7MAX
  10. #178
    Aug 2015
    Changelog:
    [Guide] How to Port Pixel Navigation Bar Animation to Your Phone (Updated to 7.1.1 Final)
    the link is [Guide] How to Port Pixel Navigation Bar Animation to Your Phone (Updated to 7.1.1 Final)
    i do the same steps . then i have compiled SystemUI.apk ,and it will became Pixel Navigation Bar when i replace image files use the Pixel solid white button.
    Back and Overview is working ,but syetemui will stop when i press the home...
    i dont know why 。 can u give me any help? thanks!!
  11. #179
    LineageOS cm14.1 beta11
    Changelog:
    17/04/2017 beta11 (MD5: e024b63a3f5d148a2f63150d482d2246)
    • Android updated to 7.1.2 version
    • Security patch April 2017
    • sync LineageOS source code (al 17/04/2017)
    Nubia Z7MAX
  12. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    mai62 (18-04-17),stomiobeach (20-05-17)
  13. #180
    Feb 2016
    I've seen new versions of LineageOS/CM14.1 for OnePlus One
    And announcement of L/CM15
