Pagina 17 di 19 primaprima ... 71516171819 ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #161
    Senior Droid L'avatar di ase11
    Ringraziato 47 volte in 44 Posts
    Anybody tried to encrypt phone? I tried and it does not work. Stuck on Android logo for hours. Interruption by switching it off and then on does not damage the system, though.
    still can't edit the first message.....
    LineageOS cm14.1 beta8
    changelog:
    26/01/2017 beta8 (MD5: 57bcefa3a5324e3864e3f44fd9e3ea21)
    • due to a bug tun off the phone sometimes it does not work properly, temporarily if you need to turn off the phone using an app like quick reboot
    • kernel: updated to 3.4.113
    • kernel: added f2fs support (not tested)
    • kernel: security fix
    • audio: fix echo during call
    • audio: fix mic low volume
    • cover: initial support to smart cover, It is under development so at the moment is very limited (for enable the cover you need to flash the file CM_enablecover.zip)
    • various fixes around
    • sync LineageOS source code (26/01/2017)
    Nubia Z7MAX
  4. Il seguente Utente ha ringraziato PaoloW8 per il post:
    ase11 (27-01-17)
  5. #163
    fix for poweroff bug:
    CM14.1beta8_fixpoweroffbug_maybe.zip
    just flash the zip without any wipe
    Nubia Z7MAX
  6. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (27-01-17)
  7. #164
    Jul 2016
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    Thank you for the new build! Could you upload the fixed kernel source in github?
  8. #165
    Quote Originariamente inviato da pchatzop Visualizza il messaggio
    the fix is not kernel related
    just add this line in your boardconfig.mk and compile
    codice:
    TARGET_INIT_UMOUNT_AND_FSCK_IS_UNSAFE := true
    Nubia Z7MAX
  9. #166
    Jul 2016
    Thank you, that worked perfectly! Any chance you can share your new twrp build (3.0.3)? I'm trying to build it with nougat sources but getting errors about busybox. With toybox I can build it but it is not working reliably with some zips.
  10. #167
    sure, I just need to do few more test before release the device tree
    btw, I use the toybox and and I suggest you to compile the recovery in eng mode, not in userdebug (compiled in userdebug the backup stuck at the end of the process in "updating partition details")
    Nubia Z7MAX
  11. #168
    Jul 2015
    Anyone got same issue, when making call the other side report they hear a lot of echo and very difficult to hear?
  12. #169
    Quote Originariamente inviato da mactrash Visualizza il messaggio
    with the beta8 ?
    try to flash this zip without any wipe: CM14beta8_echo_test1.zip
    Nubia Z7MAX
  13. #170
    Jul 2015
    Thanks for quick response, I have make one call that last 18mins... and the 3rd party say... now is far more better... although my voice is a bit distort as robot )may be caused by the network) I will try to test it more soon and report back.
    Anyway many thanks for your rom.
