Pagina 16 di 19 primaprima ... 61415161718 ... ultimoultimo
Visualizzazione dei risultati da 151 a 160 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #151
    Nov 2016
    ZTE Z5 Mini
    I Paolo i am having a few errors making the 14.1 for my device nx402, when i apply the patch 0005 of https://github.com/BambooIV/android_...03a/tree/patch to make my kernel boot, this are the errors:
    /media/otto/Android/android/system/kernel/zte/nx402/scripts/Makefile.build:307: fallo en las instrucciones para el objetivo 'security/selinux/avc.o'
    make[3]: *** [security/selinux/avc.o] Error 1
    make[3]: *** Se espera a que terminen otras tareas....
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c: In function 'ioctl_has_perm':
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3060:27: error: storage size of 'ioctl' isn't known
    struct lsm_ioctlop_audit ioctl;
    In file included from /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/include/avc.h:16:0,
    from /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:86:
    /media/otto/Android/android/system/kernel/zte/nx402/include/linux/lsm_audit.h:99:16: error: 'LSM_AUDIT_DATA_IOCTL_OP' undeclared (first use in this function)
    (_d)->type = LSM_AUDIT_DATA_##_t; }
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3067:2: note: in expansion of macro 'COMMON_AUDIT_DATA_INIT'
    COMMON_AUDIT_DATA_INIT(&ad, IOCTL_OP);
    /media/otto/Android/android/system/kernel/zte/nx402/include/linux/lsm_audit.h:99:16: note: each undeclared identifier is reported only once for each function it appears in
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3068:6: error: 'union <anonymous>' has no member named 'op'
    ad.u.op = &ioctl;
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3069:6: error: 'union <anonymous>' has no member named 'op'
    ad.u.op->cmd = cmd;
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3071:6: error: 'union <anonymous>' has no member named 'op'
    ad.u.op->path = file->f_path;
    /media/otto/Android/android/system/kernel/zte/nx402/security/selinux/hooks.c:3060:27: warning: unused variable 'ioctl' [-Wunused-variable]
    error, forbidden warning: hooks.c:3060
    /media/otto/Android/android/system/kernel/zte/nx402/scripts/Makefile.build:307: fallo en las instrucciones para el objetivo 'security/selinux/hooks.o'
    make[3]: *** [security/selinux/hooks.o] Error 1
    /media/otto/Android/android/system/kernel/zte/nx402/scripts/Makefile.build:443: fallo en las instrucciones para el objetivo 'security/selinux'
    make[2]: *** [security/selinux] Error 2
    /media/otto/Android/android/system/kernel/zte/nx402/Makefile:951: fallo en las instrucciones para el objetivo 'security'
    What can it be and how to fix it, thanks mate
    Oct 2016
    Quote Originariamente inviato da PaoloW8 Visualizza il messaggio
    I did a fix yesterday, it seems to work
    try to flash this zip without any wipe
    CM14_acdbdata_mod_v2.zip
    How do you reproduce this problem? I'd like to check if z7mini has the same problem. Thanks.
  4. #153
    Quote Originariamente inviato da seth09 Visualizza il messaggio
    usually the problem occurs after a call so checks if sound still work after the call ended
    Nubia Z7MAX
  5. #154
    Dec 2016
    Hello
    I am a Z7 max user from China.And i am using your CM14.1 ROM now.
    I think everything is good but one thing.
    I use China Telecom network which is based on CDMA/EvDO+LTE.
    but the status bar cannot show the signal
    normally when I am using CDMA/EvDO+LTE mode(CDMA/EvDO or LTE only mode is no problem).
    Can you fix the problem in the future version?
    Many thanks
    And Happy New Year!
    Ultima modifica di starkin; 31-12-16 alle 16:11
  6. #155
    Oct 2016
    The signal problem can be fixed on Z7mini by
    <bool name="config_regional_lte_singnal_threshold">true</bool>
  7. Il seguente Utente ha ringraziato seth09 per il post:
    PaoloW8 (04-01-17)
  8. #156
    Dec 2016
    I have fixed the problem by changing this string in framework-res.apk.
    Thanks!
  9. #157
    Aug 2015
    你解决双卡电信无信号问题了?
  10. #158
    still can't edit the first message.....
    LineageOS cm14.1 beta7
    changelog:
    12/01/2017 beta7 (MD5: ba30dd73d1e2fe8094c560f739ffc999)
    • switched to LineageOS rom
    • Security Patch January 2017
    • kernel: security fix
    • sync LineageOS source code (12/01/2017)
    I'm working on adding support to dotcase but for now still doesn't work properly so I have not included in this release, maybe in the next release
    Ultima modifica di PaoloW8; 12-01-17 alle 19:47
    Nubia Z7MAX
  11. Il seguente Utente ha ringraziato PaoloW8 per il post:
    mai62 (12-01-17)
  12. #159
    Jan 2017
    Hello Paolo, I'd like to thank you for your work and continous support Great work!
    But I have one request, is it possible for you to make this ROM compatible with f2fs partitions? Pchatzop has managed to get it working on his RR versions, could you do this do?
  13. #160
    Jul 2016
    You could probably get f2fs support in paolo's rom by flashing the kernel from my rom. Of course, you can not report any bugs to paolo with that unusual configuration!
