Thanks!paolo
link alpha4 in first page
this morning I saw that they started working on CM14.1 (android 7.1)
I'm downloading the source codes
excellent job ! :)
I am compiling AICP7.1, I do not know will not be reported, SUDAROM on the wrong.
Checking build tools versions...
build/core/binary.mk:1230: external/deqp/Android.mk: libdeqp: Unused source files: \
build/core/binary.mk:1230: external/pdfium/third_party/pdfiumbigint.mk: libpdfiumbigint: Unused source files: bigint/BigInteger.cc bigint/BigIntegerUtils.cc bigint/BigUnsigned.cc bigint/BigUnsignedInABase.cc
external/skia/dm/Android.mk:653: frameworks/base/libs/hwui/hwui_static_deps.mk: No such file or directory
build/core/ninja.mk:166: recipe for target '/home/syai2012/rom/suda3/out/build-sm_nx505j.ninja' failed
make: *** [/home/syai2012/rom/suda3/out/build-sm_nx505j.ninja] Error 1
#### make failed to build some targets (01:50 (mm:ss)) ####
WHY?
I don't know
I never tried this rom
I think the error is here
maybe some source codes are missingcodice:external/skia/dm/Android.mk:653: frameworks/base/libs/hwui/hwui_static_deps.mk: No such file or directory
Yes, AICP and SUDA compiled into the back also reported the wrong.
make: Leaving directory '/home/syai2012/rom/suda3/kernel/nubia/nx505j'
Building DTBs
make: Entering directory '/home/syai2012/rom/suda3/kernel/nubia/nx505j'
/home/syai2012/rom/suda3/kernel/nubia/nx505j/arch/arm/boot/Makefile:31: mhx
make[2]: Nothing to be done for 'arch/arm/boot/dtbs'.
Kernel Modules not enabled
ninja: build stopped: subcommand failed.
build/core/ninja.mk:151: recipe for target 'ninja_wrapper' failed
make: *** [ninja_wrapper] Error 1
