Pagina 5 di 19 primaprima ... 3456715 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 185
[ROM] [Z7MAX] [Android 7.1] CM 14.1 unofficial
  1. #41
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    Great news!
    What's about proximity sensors?
    I have no problem with the proximity sensor
    anyway, I changed some configuration about the sensor in the alpha3....you can try with the new version
    Quote Originariamente inviato da awssong Visualizza il messaggio
    The system comes with the file manager to open the external memory card, prompted the need for ROOT users, but through the download menu can be opened
    not ask the root permission but a permission to access to the external sdcard
    Nubia Z7MAX
    alpha3 in first page
    Nubia Z7MAX
  4. I seguenti 2 Utenti hanno ringraziato PaoloW8 per il post:
    brooklyn2006 (13-10-16),mai62 (13-10-16)
  5. #43
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Alpha3:
    Proximity sensor - the same problem.
    Camera - after switch to video mode black sceen, need reboot phone.
  6. #44
    Alpha3:
    I still have no problem with proximity sensor...
    anyone have this problem with the sensor ?
    in camera I also have no problem to switch from video/photo mode
    you have already tried to reflash the rom with a full wipe ?
    Nubia Z7MAX
  7. #45
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    I will make reflash with full wipe
  8. #46
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    make: Leaving directory '/home/syai2012/rom/cm14/kernel/nubia/nx505j'
    Building DTBs
    make: Entering directory '/home/syai2012/rom/cm14/kernel/nubia/nx505j'
    /home/syai2012/rom/cm14/kernel/nubia/nx505j/arch/arm/boot/Makefile:31: mhx
    make[2]: Nothing to be done for 'arch/arm/boot/dtbs'.
    Kernel Modules not enabled
    ninja: build stopped: subcommand failed.
    build/core/ninja.mk:151: recipe for target 'ninja_wrapper' failed
    make: *** [ninja_wrapper] Error 1
  9. #47
    Nov 2015
    [ 99% 1296/1308] Construct recovery from boot
    FAILED: /bin/bash -c "(mkdir -p /home/syai2012/rom/cm14/out/target/product/nx505j/obj/PACKAGING/recovery_patch_intermediates/ ) && (PATH=/home/syai2012/rom/cm14/out/host/linux-x86/bin:\$PATH /home/syai2012/rom/cm14/out/host/linux-x86/bin/imgdiff /home/syai2012/rom/cm14/out/target/product/nx505j/boot.img /home/syai2012/rom/cm14/out/target/product/nx505j/recovery.img /home/syai2012/rom/cm14/out/target/product/nx505j/obj/PACKAGING/recovery_patch_intermediates/recovery_from_boot.p )"
    Error: footer size 967211821 != decompressed size 0
    failed to break apart source image
    [ 99% 1296/1308] target Package: Syste...PS/SystemUI_intermediates/package.apk)
    warning: string 'notifications_off_text' has no default translation.
    warning: string 'notifications_off_text' is missing 41 required localizations: ast_ES az_AZ bn_BD bs_BA en_AU en_CA en_GB en_IN en_NZ en_SG en_US eo_EU eu_ES gl_ES gu_IN hy_AM is_IS ka_GE kk_KZ km_KH kn_IN ku_IQ ky_KG lb_LU lo_LA mk_MK ml_IN mn_MN mr_IN my_MM ne_NP pa_IN si_LK sq_AL ta_IN te_IN ur_PK uz_UZ zh_CN zh_HK zh_TW
    warning: string 'notifications_off_title' has no default translation.
    warning: string 'notifications_off_title' is missing 41 required localizations: ast_ES az_AZ bn_BD bs_BA en_AU en_CA en_GB en_IN en_NZ en_SG en_US eo_EU eu_ES gl_ES gu_IN hy_AM is_IS ka_GE kk_KZ km_KH kn_IN ku_IQ ky_KG lb_LU lo_LA mk_MK ml_IN mn_MN mr_IN my_MM ne_NP pa_IN si_LK sq_AL ta_IN te_IN ur_PK uz_UZ zh_CN zh_HK zh_TW
    warning: no entries written for string/notifications_off_title (0x7f0d0432)
    warning: no entries written for string/notifications_off_text (0x7f0d0433)
    [ 99% 1296/1308] target Package: Setti...PS/Settings_intermediates/package.apk)
    nothing matches overlay file suw_navbar_ic_back.xml, for flavor anydpi-v21
    nothing matches overlay file suw_navbar_ic_more.xml, for flavor anydpi-v21
    nothing matches overlay file suw_navbar_ic_next.xml, for flavor anydpi-v21
    nothing matches overlay file suw_progress_bar.xml, for flavor v21
    Paolo help me,Thanks!
  10. #48
    the real error is before this block of text
    you have already tried to delete the out directory and do a full compile ?
    Nubia Z7MAX
  11. #49
    Nov 2015
    我现在编译的环境是ubuntu15.04,安装了这些环境软件:
    但我编译CM14老是报错,同样编译AICP7.0和suda7.0都没有问题,我想知道你搭建的环境都安 装了哪些?
    I now compile the environment is ubuntu15.04, the installation of these environmental software:
    apt-get install bison build-essential curl flex git gnupg gperf libesd0-dev libncurses5-dev libsdl1.2-dev libwxgtk2.8-dev libxml2 libxml2-utils lzop openjdk-8-jdk openjdk-8-jre pngcrush schedtool squashfs-tools xsltproc zip zlib1g-dev g++-multilib gcc-multilib lib32ncurses5-dev lib32z1-dev gksu maven maven2 phablet-tools
    But I compile CM14 is always wrong, the same compiler AICP7.0 and suda7.0 are no problem, I would like to know what you build the environment are installed?
  12. #50
    Now I using Ubuntu 16.10 but I also have used Ubuntu 16.04 and manjaro without any problem
    I just installed this package:
    codice:
    sudo apt-get install git ccache automake lzop bison gperf build-essential zip curl zlib1g-dev zlib1g-dev:i386 g++-multilib python-networkx libxml2-utils bzip2 libbz2-dev libbz2-1.0 libghc-bzlib-dev squashfs-tools pngcrush schedtool dpkg-dev liblz4-tool make optipng maven openjdk-8-jdk
    from this guide: [GUIDE] How to Setup Ubuntu 16.04 LTS Xenial Xerus for Compiling Android ROMs
    Nubia Z7MAX
