Pagina 474 di 1789 primaprima ... 3744244644724734744754764845245749741474 ... ultimoultimo
Visualizzazione dei risultati da 4,731 a 4,740 su 17884
Jiayu S3 - Modding
  1. #4731
    Androidiano VIP L'avatar di metrino
    Jiayu S3A (JY-S3S)
    Ringraziato 1,301 volte in 792 Posts
    @nazmi28: it could be useful if you write in english, even by using a translator.
    Translations from Turkish to Italian probably are made through English, then the result is often unuseful.
    Aug 2015
    @metrino
    3G mobile data distressed in my country . Search for breakage. the same in all oparatörü . I tried several ROMs to the same result . Anyone complaining. I install the latest ROM ( KitKat )
    the result is still the same . the band gap in our country .Allegato 149747Allegato 149748
  4. #4733
    Aug 2015
    anyone else have this problem with . Try all ROMs. the results are always negative . How to fix this problem?
  5. #4734
    Jiayu S3A (JY-S3S)
    Quote Originariamente inviato da nazmi28 Visualizza il messaggio
    Did you already tried to select just the band frequencies you need?
    Did you already disabled B38 band? (sometime it causes a strange behaviour)
    Type *#*#5429873#*#* in dialer.
    go to band mode
    disable the bands you don't need, check your carrier bands to do that.
  6. #4735
    Aug 2015
    @metrino
    This working bands . the same results . 3g internet occasional break . Wifi slow down occasionally . what's the problem?
    Allegato 149753
  7. #4736
    Jiayu S3A (JY-S3S)
    Did you disable B38 LTE band?
    Out of that , I don't know what to do. I've got the same problem, but not always and not in 4G, just 3G.
  8. #4737
    Aug 2015
    @metrino
    No 4g our country. There 3g .
    Allegato 149756Allegato 149757
  9. #4738
    Jiayu S3A (JY-S3S)
    Yes, I know, but as I told you before, sometime it causes a strange behaviour.
    Disable Band 38, keep just Band 40.
    Apply changes and restart the phone.
    It doesn't solve your problem, but it could be less annoing
  10. #4739
    Aug 2015
    Do your friends do not have the solution ?
  11. #4740
    Aug 2015
    @metrino
    No 4g our country. There 3g . Does this method work? How else could it work?
