Sono curioso ank'io di questa cosa perchè ho riscontrato i tuoi stessi problemi per quanto riguarda i contatti.
Ciao a tutti,
ho installato viber, ma non riesce a caricare i contatti che hanno viber dalla rubrica. C'è qualcosa da fare? Ho già disinstallato e reinstallato, inserito il codice, spento e riavviato.
Please make sure that Viber is the cause for the battery drain. We conduct strict testing in our labs with several devices and othen than when making a call (when it is natural for the battery to be used), we did not came across any significant battery drain when Viber was simply running in the background. Furthermore, over the course of over 15 hours, on average the battery use was only 2%.
You can find additional information on tests performed by Viber users, which show similar results, at:
forums.whirlpool.net.au/archive/1625174#r30755699
forum.lowyat.net/topic/1965357/+220
Ultima modifica di Viber; 11-10-11 alle 16:21
Ciao,
Questo è un rappresentante di Viber Media.
Mi scusi, il mio italiano non è così buono, così sarò scrivere in inglese.
We are going to release a new version of Viber within the next several days. We recommend you all to download and install it, and see if the problem persists even with the new version. We would like to hear a report from you and assist you further if you encounter problems.
Grazie,
Viber.
thank you for the answer.
i've just updated the new version. for now i can't check for new contacts problem because i haven't new contact. (you should think also a version for symbian, IMHO. )
i think the app is improving but i suggest to fix the call's quality because without wifi is really bad and it's impossible to call and understand something. and to add for example smiley, the timing for each message and to check if the contact is on line, even if i saw the new function : "contact is typing".
for now I only have the old contacts so I can not check if the problem continues
yes we have both 2.1.1 but the other one wasn't using wifi connection.- We are working to improve the sound quality at the moment. Please make sure both sides have 2.1.1 installed.
great! i hope also the possibility to check the status of the other contacts.- We might be adding a feature that lets you add smilies in the future.
So at the moment inside your Viber contact list, you can see all the contacts who have Viber, and everything works fine?
yes, except the call but you already told me you're working on it.
Ciao,
It's a known issue and we're currently working to fix that.
We have release Viber version no. 2.1.1 with major bug fixes and 2.1.2 is on it's way
If you have any question about Viber - please feel free to ask.
Grazie,
the Viber Team.
