Pagina 17 di 23 primaprima ... 71516171819 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 224
[84x ROM] JellyBean 4.1.1 SmartPao 2.0
  1. #161
    Senior Droid L'avatar di effeci2
    Sicilia
    Wiko Rainbow Jam -Vodafone 875
    Ringraziato 232 volte in 153 Posts
    Penso di aver risolto, il fix della recovery non ha sortito effetto,
    ls -l dava questo output
    codice:
    shell@android:/sys/devices/system/cpu/cpu0/cpufreq # ls -la
    ls -la
    -r--r--r-- root     root         4096 2012-10-09 23:53 affected_cpus
    -r--r--r-- root     root         4096 2012-10-09 23:53 cpuinfo_max_freq
    -r--r--r-- root     root         4096 2012-10-09 23:53 cpuinfo_min_freq
    -r--r--r-- root     root         4096 2012-10-09 23:53 cpuinfo_transition_latenc
    y
    -r--r--r-- root     root         4096 2012-10-09 23:53 related_cpus
    -r--r--r-- root     root         4096 2012-10-09 23:53 scaling_available_frequen
    cies
    -r--r--r-- root     root         4096 2012-10-09 23:53 scaling_available_governo
    rs
    -r--r--r-- root     root         4096 2012-10-09 23:53 scaling_cur_freq
    -r--r--r-- root     root         4096 2012-10-09 23:53 scaling_driver
    -rw-r--r-- root     root         4096 2012-10-09 23:46 scaling_governor
    -rw-rw---- system   system       4096 2012-10-09 23:46 scaling_max_freq
    -rw-r--r-- root     root         4096 2012-10-09 23:46 scaling_min_freq
    -rw-r--r-- root     root         4096 2012-10-09 23:53 scaling_setspeed
    drwxr-xr-x root     root              2012-10-09 23:46 stats
    quindi ho fatto
    chown root:root scaling_max_freq
    quindi
    chmod 644 scaling_max_freq
    adesso ls -l ed il cat danno valori corretti
    codice:
    ls -la
    y
    cies
    rs
    -rw-r--r-- root     root         4096 2012-10-09 23:46 scaling_max_freq
    shell@android:/sys/devices/system/cpu/cpu0/cpufreq # cat scaling_max_freq
    ing_max_freq        <
    1008000
    shell@android:/sys/devices/system/cpu/cpu0/cpufreq # exit
    Wiko Rainbow Jam MTK6580 Lollipop 5.1 - Wiko Iggy MTK6572 JB 4.2.2 - Mediacom Smartpad 722Mobile MTK6582 JB 4.2.2 - Mediacom Smartpad 706 Allwinner JB 4.1.1 by effeci2 - Mediacom Smartpad 720 e 722 Amlogic ICS 4.0.4 - Dicra Tab208 CyanogenMod 10 JB 4.1.1
    Ringraziato 97 volte in 64 Posts
    oki, cmq ti ho mandato il boot.img fixato per il problema dei permessi
    ma il punto è...adesso al reboot la freq è giusta ? (ah se non metti il boot.img nuovo al riavvio ti risetta il file come system system)
    Ultima modifica di paopad; 10-10-12 alle 01:07
    tablet Mediacom SmartPad 844i
    Rom CM9 + kernel OC - freq min 300Mhz, max 1.17Ghz, governor smartass V2
    Rom SmartPao v1.5 + kernel OC - freq min 300Mhz, max 1.17Ghz, governor smartass V2
    Rom SmartPao v2.1 JellyBean 4.1.1 + kernel OC - freq min 300Mhz, max 1.17Ghz, governor smartass V2
  4. #163
    Sicilia
    Quote Originariamente inviato da paopad Visualizza il messaggio
    Dopo il riavvio e nuovo test con Antutu, questi continuava a segnare 1200.
    Ho flashato il nuovo boot.img che mi hai inviato ed al riavvio il nuovo test indicava 1008 correttamente.
    Comunque secondo me era una frequenza fittizia, il punteggio da quando segnava 1200 a quando segna 1008 sostanzialmente e' rimasto inalterato.
    Inoltre come ti avevo scritto, prima del nuovo flash totale avevo provato l'oc a 1200 con cpu master e gia' durante il test il tablet si era piantato di brutto, seqno che la mia cpu non regge l'oc a 1200.
    Adesso stacco, domani continuero' le prove batteria.
    Buonanotte
  5. #164
    Androidiano L'avatar di NEOGENIO
    Italia, Sicilia
    Samsung Galaxy W
    Scusate il mio (forse) OT, ma esiste la possibilità di aumentare quel famoso 1gb di memoria interna?
  6. #165
    Ringraziato 23 volte in 23 Posts
    Si se controlli bene la prima pagina,paopad ha fatti anche questa modifica.
    Inviato dal mio The One - SBSY94 Style! v3.1 usando Androidiani App
  7. Il seguente Utente ha ringraziato Simonehd per il post:
    NEOGENIO (10-10-12)
  8. #166
    Sicilia
    Quote Originariamente inviato da NEOGENIO Visualizza il messaggio
    Se intendi la RAM, non si puo' aumentare perche' si tratta di chip di memoria saldati sulla piastra. Non e' come sui pc che se hai degli slot liberi sulla piastra, basta acquistare dei banchi di RAM compatibili, montarli e ottieni l'aumento della memoria.
    Se intendi invece la memoria destinata alle applicazioni, paopad in prima pagina ha postato una patch per l'aumento a 2 GB
    se volete la partizione per le app da 2Gb scaricate anche questo file parameter_new_2Gb
  9. Il seguente Utente ha ringraziato effeci2 per il post:
    NEOGENIO (10-10-12)
  10. #167
    Ciao Pao e Effe domanda se volessi testare questa JB sul mio 715 devo seguire la procedura solita + lo script di Effeci postato nel 3d della CM9 4.0.4 by paopad? Fuori OT le prove di ieri per CM9 hanno continuato a dare problemi con il touch, quindi tornato a m4b
  11. #168
    aspetta, forse per il 715 devo fare una modifica al kernel (che vale anche per la CM9) per il touch e per poter usare i dpi a 160
    aspetto effeci2 che mi dica qualcosa
  12. #169
    Ok grazie e buon lavoro!
  13. #170
    Italia, Sicilia
    Samsung Galaxy W
    Quote Originariamente inviato da effeci2 Visualizza il messaggio
    Esatto, intendo la memoria interna (non la ram)... adesso guardo il topic che mi hai indicato grazie!
    EDIT:
    P.S: come si utilizza il file parameter che permette questa modifica?
    se possibile se funziona vorrei provarlo sulla rom del Pascal 2
    Ultima modifica di NEOGENIO; 10-10-12 alle 20:05
