Pagina 81 di 243 primaprima ... 3171798081828391131181 ... ultimoultimo
Visualizzazione dei risultati da 801 a 810 su 2425
KERNEL][4.2.x][4.3][4.4.x] Fancy Kernel
  1. #801
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    Quote Originariamente inviato da imthedoctor Visualizza il messaggio
    nuova release, qualcuno l'ha provata ?
    la provo subito
    edit : installata versione ext!!lo lasciato le impostazioni della seconda pagina..il telefono sembra ancora piu reattivo.Grande Boype!!
    New!!Controllo della temperatura
    Ultima modifica di morfances; 23-06-13 alle 11:43
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. Il seguente Utente ha ringraziato morfances per il post:
    oleksandr (23-06-13)
    Jul 2010
    Ringraziato 539 volte in 393 Posts
    Vedo che i più mattinieri di me l'hanno già scoperta
    Hi all,
    r32 is now available. Here's the change log:
    updated to Linux 3.0.83
    enable trim_override to allow >= 1.4Ghz frequencies without lagging the device (credits to francisofranco)
    removed simple GPU governor (it wasn't working as it should. You can still pick from 307, 384 and 512 MHz like you can on other kernels)
    several mostly power management related fixes and also a cache tweak from Texas Instruments
    SIOplus/deadline: Allow 0ms deadline latency
    implement temperature control (extended version only; credits to imoseyon)
    WiFi drop workaround improvement (no need to disable / enable WiFi manually anymore)
    switched compiler toolchain to Linaro Android GCC 4.7 (current version: 13.05)
    few other things
    As you can see, I switched the toolchain. While I said earlier that Google's toolchain is supposed to be very stable, Linaro's should be equally stable. Plus it gives builds with better performance (e.g. in some 3D applications) and is updated more frequently.
    Enjoy and best regards!
    standard http://boypetersen.de/fancykernel/r3....2-r32-std.zip
    ext http://boypetersen.de/fancykernel/r3....2-r32-ext.zip
  5. I seguenti 3 Utenti hanno ringraziato Pelide per il post:
    Mithril (23-06-13),oleksandr (23-06-13),Tex99 (24-06-13)
  6. #803
    Senior Droid L'avatar di oleksandr
    Galaxy Nexus GSM
    Ringraziato 303 volte in 193 Posts
    Da adesso il kernel è compilato con il Linaro Toolchain quindi non mi meraviglio se va ancora meglio di prima!
    on Stock 4.3 Rom with Fancy Kernel & ViPER4Android AudioEffect
  7. #804
    Androidiano VIP L'avatar di erghetto
    Napoli
    Galaxy S6 Flat SM-G920F
    Ringraziato 385 volte in 344 Posts
    come funziona il limite per la temperatura?
    cioè mettiamo che io stia giocando.. il mio limite è a 65°.. mentre gioco la temperatura sta per superare quel valore, il gioco che fa crasha?
    perchè se continuo a giocare sicuro supero quel valore..
    [Smartphone] Samsung Galaxy S6 Flat (SM-G920F)
    [ROM] Noble Nougat Experience 4.5
    [kernel] Kiboi kernel 2.5
  8. #805
    Galaxy Nexus GSM
    Quote Originariamente inviato da erghetto Visualizza il messaggio
    In teoria se stai per superare il limite, il telefono non ti fa andare sulle frequenze più alte, per non farlo scaldare di più. Quindi il gioco non dovrebbe crashare, ma avrai qualche lag, sempre se si sta parlando di un gioco pesante, che richiede alte frequenze...
    Correggetemi se sbaglio..
  9. #806
    Napoli
    mm non so come funziona lo scaling delle frequenze e non voglio dire eresie, quindi nel caso linciatemi pure XD, ma, quando si gioca, indipendentemente dal tipo di gioco, non va al max della frequenza?
  10. #807
    Jul 2010
    Solo se il gioco richiede le massime prestazioni... Puoi verificarlo tu stesso, entra in trickster e nella prima pagina spunta reset statistiche e poi gioca. Quando esci dal gioco ricontrolla su trickster le frequenze usate
  11. I seguenti 2 Utenti hanno ringraziato Pelide per il post:
    erghetto (23-06-13),oleksandr (23-06-13)
  12. #808
    Androidiano VIP L'avatar di Alkemix
    TRAPANI
    GALAXY NEXUS
    Ringraziato 2,219 volte in 1,084 Posts
    Quote Originariamente inviato da oleksandr Visualizza il messaggio
    Ciao Olek,
    Cambia davvero pochissimo a livello prestazionale usare NDK o Linaro Toolchain (tra l'altro NDK usa delle istruzioni di GCC Linaro stesso) ...
    Il controllo della temperatura io già lo avevo, a Boype lo ha passato Imoseyon dal Lean.. eh eh eh ho scelto proprio bene i due kernel da fondere (il meglio del meglio!!!)
    Il duro lavoro condiviso gratuitamente va rispettato, non calpestato !
    SuperMIUI ROM 4.2.2 modificata e convertita a F2FS e resa compatibile con TWRP: kernel dfk 1.5 F2FS MIUI edition inside !
  13. I seguenti 2 Utenti hanno ringraziato Alkemix per il post:
    fedelamb (23-06-13),oleksandr (23-06-13)
  14. #809
    Ringraziato 44 volte in 29 Posts
    però a me non lo vuoi far provare eh...
    LG G2 Lineage 14.1 - root - TWRP //// S8
  15. #810
    Galaxy Nexus GSM
    Quote Originariamente inviato da Alkemix Visualizza il messaggio
    Ciao Olek,
    Si, ti devo fare i miei complimenti, hai fatto la scelta migliore! Io aspetto con l'ansia la tua prima versione stabile
    P. S. Intanto ho messo su l'r32 ext con la slimbean 6.8 e il CrossBreeder di oggi.. Il telefono vola! Si sente tanta differenza, sicuramente è grazie anche al CrossBreeder, il ragazzo ci sta lavorando sodo, fa uscire gli aggiornamenti quasi tutti i giorni.
  16. Il seguente Utente ha ringraziato oleksandr per il post:
    Alkemix (23-06-13)
