Pagina 5 di 16 primaprima ... 3456715 ... ultimoultimo
Visualizzazione dei risultati da 41 a 50 su 153
[ROM][4.4.x] LIQUID-TREX Maguro
  1. #41
    Sep 2010
    ROMA
    Nexus 5,Gnex,Galaxy Giò
    New build
    TREX - maguro 22.05.2014
    android_frameworks_base
    -revert FwBase: hideable battery icon [1/2]
    -FWBase - Add Wifi name to notification drawer when Wifi is connected
    -Revert "FWBase - Wakelock Blocker [1/2]"
    -CM11 Themes: Reduce "unable to load asset" log spam
    -immersive mode: don't unconfirm a package, that's just dumb
    -CM11 Themes: Get proper package name in attachThemeAssets
    -Revert "ActivityTrigger: New class to invoke when activity starts/resumes"
    -Cleanup themes that fail to install
    -Themes: Fix -110 install error [2/2]
    -CM11 Themes: Expose applyDefaultTheme to public service
    -Avoid app install failures from malformed themes
    -fix battery jb style
    -PEEK: Beautify bridging layers code
    android_frameworks_native
    -Themes: Fix -110 install error [1/2]
    TREX_Settings
    -revert CarbonFibers: hideable battery icon [2/2]
    -Revert "CFibers - Wakelock Blocker [2/2]"
    -fix jb battery style
    DOWNLOAD
    Oneplus 9
    Oneplus 5 6/64
    ROM: Pixel Experience 9.0
    Nexus 5
    Galaxy Nexus (venduto)
  2. Il seguente Utente ha ringraziato morfances per il post:
    leonardodettoileo (24-05-14)
    Sep 2010
    ROMA
    Nuovo aggiornamento ragazzi...
    TREX - maguro 25.05.2014
    -Revert "Fix fatal exception due to missing looper for current thread."
    -Tele2 considered non-roaming on T-Mo
    android_packages_apps_Settings
    -Revert "Settings: Forward port Kill app longpress back"
    Fixed : Beim gedrückt halten des PowerButtons gibt es sofort einen Reboot!
    -CM11 Themes: Fix applyDefaultTheme implementation
    -Fix fatal exception due to missing looper for current thread.
    -SignalStrength: Hotfix TD-SCDMA take 2
    -Themes: Fix bad idmaps for system themes
    -Avoid calling idmap w/ trailing whitespace [1/2]
    -Bluetooth: use virtual sco calls for VOIP
    -audio: no notification sound when adjusting volume bar twice.
    -Bluetooth: Unbind only in case of OFF state
    -Bluetooth: Adds check to verify Bluetooth adapter state
    -BT: HF: Control verbose logging at runtime.
    -Clear cached locations when location providers disabled Bug: 12118307
    -AlarmMangerService: Fix the delay of ACTION_TIME_CHANGED for time-services
    -ExtMediaPlayer: Increase parcel pool size to 30
    -Fix socket descriptor leak from Zygote to child app
    -Alarm: ignore less than 2 mins upcomming power off alarm
    -Themes: Map themed icon to app after upgrade
    -Saunalahti considered non-roaming on Elisa
    -AudioService: fix cross deadlock in VolumeStreamState
    -Avoid calling idmap w/ trailing whitespace [2/2]
    android_vendor
    -Add Soundrecorder App to the build
    android
    -Switch to CM Sound Recorder
    -Test "building error" frameworks_av from CM
    android_build
    -fix O3 build error 1/1
    -fix O3 build error 2/2
    Link Download
    Ultima modifica di morfances; 25-05-14 alle 22:41
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  5. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    leonardodettoileo (25-05-14),miceneo (25-05-14)
  6. #43
    Sep 2010
    ROMA
    Prima rom 4.4.3 anche per la TREX!!!
    ROM
    GAPPS
    -Merge tag 'android-4.4.3_r1.1' into kk
    -Don't cleanup overlay mapping for non-theme apps
    -reduce cookie tracking (3/4): add a way to count cookies
    -CameraTile: Launch default gallery app when long pressing active camera tile
    -Correct stride for drawing to cached glyph bitmap
    -Use alpha channel instead of red in drawCachedGlyphBitmap
    -MtpDatabase JNI: Fixed a memory-leak in getObjectPropertyValue().
    -Show Seconds next to StatusBar Clock [1/2]
    -framework: Add compass tile (1/2)
    -Remove double tap, make long press to enable torch [1/2]
    android_build
    -back to stock TARGET_GCC_VERSION
    -Generate extra userdata partition if needed
    android_development
    -Merge tag 'android-4.4.3_r1.1' into HEAD
    android_kernel_samsung_tuna
    -video: omap2: displays: disable Content Adaptive Brightness by default
    -ARM: OMAP4: l2x0: Cleanup prefetch offset register setting
    -ARM: OMAP4: l2x0: Set optimized value for prefetch offset
    -OMAP4: do not force workarounds for errata fixed in 4460
    -Enable PL310 double linefill for Tuna board
    -Tuna: set PL310 cache controller prefetch offset to 3
    -Enable SCU Speculative linefills
    -tuna: Enable Cortex A9 optimizations
    -Add sysfs vibrator intensity controls
    -board-tuna-vibrator.c: Low vibrator dmesg log Spam
    -BMP180: Report temperature through ABS_MISC.
    -BMP180: Finish temperature reporting.
    -BMP180: Fix typo.
    -input: touchboost: I've tried a gazillion different ways to deal with input cpu-boost events, but in the end what really works for me and flawlessly is leaving the governor taking care of the cpu frequency changes. I'd rather have a global input register handler that feeds the governor with the touch input times in usecs and leave the boosting logic to the governor. CAF's cpu-boost code is half broken too so I'm not bothering with trying it again.
    -Revert "board-tuna-vibrator.c: Low vibrator dmesg log Spam"
    -Revert "Add sysfs vibrator intensity controls"
    -Update Local Version "TREX-SM-KK-r5.0"
    TREX_Settings
    -Show Seconds next to StatusBar Clock [2/2]
    -Remove double tap, make long press to enable torch [2/2]
    -Settings: Add compass tile (2/2)
    android_packages_apps_Dialer
    -Dialer: Correct geocode resource typo
    -Update missing stuff to 4.4.3, fixing build with it
    -Dialer: update TRDS for new 4.4.3 Dialer
    -change Pngs
    -Update Pngs
    -Update landscape layout to match 4.4.3 codebase
    android_packages_apps_InCallUI
    -change Pngs
    -fix non-intrusive for RTL
    -Replace deprecated string resources.
    android_packages_services_Telephony
    -OutgoingCallBroadcaster: add subscription id to NEW_OUTGOING_CALL
    -respect quiet hours vibration settings when ringing
    -some updates from CM
    android_packages_apps_Contacts
    android
    -Return to CM LockClock
    -Merge tag android-4.4.3_r1.1 into kk
    -Update 4.4.3
    Wallpaper (TREX-Wallpapers)
    -new Wallpaper ISS
    gapps
    -remove LG Tastatur
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  7. I seguenti 2 Utenti hanno ringraziato morfances per il post:
    fedelamb (10-06-14),leonardodettoileo (10-06-14)
  8. #44
    Sep 2010
    ROMA
    Seconda build 4.4.3
    TREX - maguro 11.06.2014 & TREX gapps 11.06.2014
    Link Download
    Rom
    Gapps
    -appops: do not prune apps that are not present
    -inputdevices: update from aosp (master)
    -base: remove extra checks
    -synchronize updateStringCache on mAccessLock
    -Themes: Check CRC of APK MANIFEST.MF at install
    -Themes: Avoid compiling icon packs every boot
    -sync status bar transparency state on theme change
    -Theme special volumeup+down volume panel
    -FB: Add transparency to Glowpad background [2/3]
    android_vendor
    -disabled packages: Add new GMS updater activity names
    -add Android Port.apk
    android_build
    -Fixing adbd so that it's respectful of /data/misc/adb/adb_keys once
    -Fix landscape layout
    -Improve latest CAF strings
    -fix dialpad digits color while TRDS is on
    -Dialpad key digit color TRDS update
    -Revert "InCall full screen photo"
    -Add transparency to Glowpad background [1/3]
    -Add transparency to Glowpad background [3/3]
    -data usage chart: move color values to resource file
    -Move peek [1/2]
    -replace lockscreen rotation option in Display with Slim's
    TREX_Settings
    -Move peek to CF [2/2]
    gapps
    -update Slim 10.06.2014
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  9. Il seguente Utente ha ringraziato morfances per il post:
    miceneo (12-06-14)
  10. #45
    Sep 2010
    ROMA
    New build 4.4.3
    TREX -maguro 13.06.2014
    -png update xhdpi "Transparente Dialoge" (maguro,mako)
    -NotificationHelper: Create broadcast receiver for Peek app
    -[1/2] Prepare NotificationManagerService for new format
    -Apps: Add blacklist interface [1/2]
    -QS: respect equalizer in switch to small tiles
    -HOVER [1/2]
    -HOVER: Fix a couple of things
    -Frameworks: Store dialpad showing state (1/2)
    -Revert "QS: respect equalizer in switch to small tiles"
    -Themes: PhoneWindowManager UI context on demand
    android_vendor
    -update AP apk
    -Added apn settings for Mobitel and Etisalat, Sri Lanka (MCC=413)
    android
    -hardware/cm for the dinosaurs still around
    -Removing unnecessary reference to CM that is annoying me...
    -Hide "Volume adjustment sound" option on non-voice capable devices
    -modify AOSP RU translation
    -Various cleanups
    -[2/2] Prepare NotificationManagerService for new format
    -Skip apps where the LED's already set up
    -Apps: Add blacklist interface [2/2]
    -Silently update the package manager
    -HOVER [2/2]
    -Launch only contacts picker for blacklist entry
    TREX_Settings
    -Fix Peek preference
    -Enable incall transparency by default [2/2]
    -Store dialpad showing state (2/2)
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  11. #46
    Sep 2010
    ROMA
    New buils is up
    TREX -maguro 18.06.2014
    -listview: ensure active views are filled prior than scrap views
    -hwui: Always enable the scissor while composing layer
    -CM11 Themes: Add support for composed icons [1/2]
    -Themes: Don't set icons for iconpack that is applied
    -Themes: Don't kill launchers that handle the theme change
    -SystemUI: prevent NPE on clear recents double press
    -Floating window: Fix possible NPE
    -Themes: Add categories to theme change intent.
    -Keyguard: Avoid unneeded SIM dialog show() calls
    -PEEK: Sensors improvements
    -DocumentsUI: Remove catch-all statements
    -DocumentsUI: Handle NPE gracefully
    -DocumentsUI: DE-Translation (add custom strings)
    -frameworks/Documents: ES translations
    -Fix Icon size in DocumentsUI
    -Fix DocumentsUI FC
    -Replaced custom strings with Android defaults
    -HOVER: Theme Engine compatibilities and some resources tweaks
    -Themes: Get resources with an explicit theme attached.
    -Don't log an error if we cannot open icon hash
    -Themes: Set bounds on iconUpon
    -tests: Hide new private APIs
    -PackageManagerService: Prevent sending a SIGKILL while the device shutting down
    -Keyguard: Distinguish the TextView id of pinEntry
    -Make sure slashes don't appear in the Quick Recording files
    -QuickRecord: Fix crash on other languages
    -Framework changes for moving applications to external volume
    -Add class for changing app moving setting
    -Add color values for ease of TRDS theming
    -Incoming Call in Background (3/3)
    -SystemUI: Update UserTile from Google 4.4 code
    -Fix icon support for secondary users.
    -Don't create idmap if app doesn't have resources.arsc
    -Calculate application sizes correctly
    android_build
    -colorize non-fatal javac stderr yellow (and actually display it... at… all)
    android
    -Track our vold for app2sd
    -Update Blacklist
    -Settings: Modify AOSP JA translation
    -Fix CustomScreenColor when picking an image
    -RU translations
    -Blacklist: Avoid crash when dialog dismissed via back button.
    -Add app moving setting to the menu in Settings -> Apps
    -Enable moving applications to an external volume
    -Integrate quite hours active period strings for JA translation
    -Modify volume override summary for JA translation
    TREX_Settings
    -RU translations
    -Fix issue with translation
    -revert Omni's non-instrusive [3/3]
    -Incoming Call in Background (2/3)
    -update glowpad transparency title
    -revert Omni's non-intrusive [2/3]
    -Incoming Call in background [2.5/3]
    -Fix mismerge
    -revert Omni's non-instrusive [1/3]
    -Incoming Call in Background (1/3)
    -add decline and answer incoming call action on notifications
    -Set Ticker to contact
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  12. #47
    Ferrera Erbognone (PV)
    LG G3 Vodafone, Galaxy Nexus
    Avevo la build del del del 13/06 ed ho voluto riprovare la cm_remix ma non per nulla soddisfatto. Ho riprovato la paranoid ma ancora di più insoddisfatto (che brutta), e sono ritornato immediatamente alla nuova build del 18/06, che dire una grande rom!!!
    W la trex!!!
  13. Il seguente Utente ha ringraziato ruggy63 per il post:
    morfances (20-06-14)
  14. #48
    Sep 2010
    ROMA
    Quote Originariamente inviato da ruggy63 Visualizza il messaggio
    W la trex!!!
    finalmente qualcuno che la segue...xD
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  15. Il seguente Utente ha ringraziato morfances per il post:
    ruggy63 (20-06-14)
  16. #49
    Quote Originariamente inviato da morfances Visualizza il messaggio
    Avevo già provato anche la 4.4.2 e posso dire che ormai è una tra le migliori in assoluto, di gran lunga superiore alle famose citate nel forum di xda, grazie a te per avermela fatta conoscere
  17. #50
    Sep 2010
    ROMA
    visto che ci sei puoi mettere la 4.4.4 e fammi sapere ?
    TREX -maguro 20.06.2014
    ---- Android 4.4.4 KTU84P ----
    -Floating window with Multitasking w AppCircleSideBar [1/3]
    -Implement App circle sidebar [2/3]
    -PowerMenuTile fix
    -Navigation bar IME cursor + Fixes
    -RU translations
    -fix qs and notification shade toggle on expanded desktop
    -IME cursor controll be consistent
    -Remove DEFAULT_THEME_APPLIED_ON_FIRST_BOOT
    -Add status bar and navigation bar to ThemesContract
    -Install themes and icon packs for secondary users.
    -Add previews to the themes contract.
    -Revert "Vpn: Setup routes."
    -Fix whitespace issue with translation
    -Clock: use mCalendar to get seconds
    -Merge tag 'android-4.4.4_r1' into temp
    -Add "Turn WiFi off" action to "Open networks" notification
    android
    -Bump for 4.4.4_r1
    -Update default.xml
    android_build
    -colorize non-fatal javac stderr yellow (and actually display it... at…all)
    -Merge tag 'android-4.4.4_r1' into kk
    -ota: Let devices specify their own recovery-from-boot.p installer
    android_vendor
    -update AP apk
    -Consistently use start/end instead of left/right layout properties [1/2]
    -remove 'Brightness adjustment' from auto brightness dialog
    TREX_Settings
    -Implement App circle sidebar [2/2]
    -RU translations
    -Consistently use start/end instead of left/right layout properties [2/2]
    -Update RU translations
    Oneplus 9
    Oneplus 5 6/64
    Nexus 5
  18. I seguenti 3 Utenti hanno ringraziato morfances per il post:
    leonardodettoileo (21-06-14),PrimaScelta (21-06-14),vismo (21-06-14)
