Visualizza i risultati del sondaggio: State provando questa ROM ?
Chi ha votato
13. Non puoi votare questo sondaggio
  • Si , aggiorno ogni nightly della AOSPAL
    7 53.85%
  • No, ma seguo gli aggiornamenti pensando di usarla in futuro
    5 38.46%
  • No , non è una Rom interessante
    1 7.69%
Pagina 9 di 21 primaprima ... 789101119 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 203
[AOSPA4][KITKAT][SABERMOD4.8] ParanoidSaberDroid - AOSPAL
  1. #81
    Androidiano L'avatar di johnmuddy
    Ringraziato 68 volte in 44 Posts
    Quote Originariamente inviato da fabribasi Visualizza il messaggio
    Mi confermate questo problema?
    A me non si verifica
    LATEST BUILD January 20th, 2014 - PA 4.0 BETA
    January 20th, 2014 | PA 4.0 BETA3
    PA - Beta 3 Changes:
    • New PA-4.0 Bootanimation
    • Quick Settings 3.0 - See here to see what's changed
      Features:
    • Make immersive tile a dual tile (introduced in QS3.0 - click the upper right icon to switch between front and back tile) - the front tile always switches between immersive mode on and off, the back tile switches between the states (hide nav/status/both)
    • Lockscreen Notifications: add button to navigation bar to show all notifications
    • Add switch to last app as navigation ring target (Credit: OmniRom)
    • Statusbar clock and date mods such as center clock, custom date etc. (Credit: SlimRoms)
    • Custom carrier label - to disable use a space as text
    • Smart pulldown - always open quicksettings when no notification is present
    January 17th, 2014 | PA 4.0 BETA
    Bug fixes::
    • Fix navigation bar buttons icon in landscape mode
    • Fix navbar settings FC when saving configuration in landscape mode
    • Try to fix the reboot on power button issue - at least I'm no more able to reproduce it but because the problem appears almost randomly I can't promise that it's fixed.
    • Try to fix some bluetooth issues by using the AOSP bluetooth app without our modifications - again, I can't promise it's fixed because I was never able to reproduce any issues
      Features:
    • Add patch to AOSP dialer which allows to use caller ID and nearby places like in stock dialer. This is basically an opensource variant of the google stock dialer known from N5 - thanks to Xiao-Long Chen and kufikugel and whoever might be involved in this!
    [/I]
    Ultima modifica di johnmuddy; 22-01-14 alle 23:20
  4. #83
    Androidiano VIP L'avatar di dubledude
    Napoli
    LG Nexus 5
    Ringraziato 608 volte in 559 Posts
    Quote Originariamente inviato da johnmuddy Visualizza il messaggio
    Scusatemi...navbar diventata ridimensionabile?
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
  5. #84
    Androidiano VIP L'avatar di fabribasi
    Nexus 4
    Ringraziato 31 volte in 31 Posts
    Si lo era anche nel build precedente
    Paranoid 3.99RC1 Franco kernel
  6. Il seguente Utente ha ringraziato fabribasi per il post:
    dubledude (23-01-14)
  7. #85
    Napoli
    LG Nexus 5
    Che bella notizia mi hai dato...come va nel complesso ora? Provai la prima build
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
  8. #86
    Nexus 4
    Molto bene. Non ancora metto l'ultima build però. Consuma un po' sotto rete 3g ma non ho cambiato kernel, con il Franco dovrebbe andare meglio
  9. Il seguente Utente ha ringraziato fabribasi per il post:
  10. #87
    Napoli
    LG Nexus 5
    Adoro troppo le notifiche...leggo molti fix al sistema notifiche voglio provarla per bene la metto su e vedo
    Comodissime facendo 400-500 SMS al giorno
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
  11. #88
    Napoli
    LG Nexus 5
    che kernel consigliate? lo stock resta fisso a 1,5 Ghz
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
  12. #89
    NexusZero
    domandina: ogni volta che flasho un aggiornamento di questa rom esce l'ottimizzazione delle app.. vuol dire che aggiornano anche il kernel?
  13. #90
    Napoli
    LG Nexus 5
    Quote Originariamente inviato da NexusZero Visualizza il messaggio
    No è la dalvik che si ricrea
    LG Nexus 5
    ROM Purity Rom
    KERNEL Stock
