Pagina 8 di 17 primaprima ... 678910 ... ultimoultimo
Visualizzazione dei risultati da 71 a 80 su 166
[ROM] Viper10 | Android N ◦ Tweaks | HUB | OTA
  1. #71
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Viper10 2.3.0 (13 July)
    Additions & Updates
    • Pulldown Gestures Updates
      • Change Gesture color
      • Use shortcuts to start custom activities, direct calls, etc.
    • Custom volume steps (45 max) - Makes it easier to fine tune the volume with your volume buttons
      • STREAM_VOICE_CALL
      • STREAM_SYSTEM
      • STREAM_RING
      • STREAM_MUSIC
      • STREAM_ALARM
      • STREAM_NOTIFICATION
      • STREAM_BLUETOOTH_SCO
    • Put Signal icons on left
    • Notification LED Blacklist
      • Select the apps you don't want to flash the LED on a new notification
    • Venom Battery text moves to left now too when battery on left enabled
    • Contextual Header and Recent Apps
      • Set time based backgrounds (morning, afternoon, evening, night) images for your header and recent apps
      • Use predefined or custom images
      • Random mode
    • HTC Connect Quicksettings Tile
    • Custom Ambient Screen Brightness (255 steps)
    • Tweaks Backup and Restore (It takes a while the first time to show app - Patience!)
      • Backup options
        • Internal SDCard
        • VenomHub Server or Google Drive
      • Google Drive is used for backup and restore (Enables you to easily restore settings across different devices)
    Fixes & Cleanups
    • Fixed battery on the left when using stock battery
    • Fixed right margin on stock battery when using it on the left
    • Fixed double tap statusbar to sleep
    • Fixed delay of back and recent button when no doublepress action is set
    • Fixed Bluetooth Tile showing wrong state
    • Fixed ANR that caused a freezed headsup and statusbar
    • Fixed VenomTweaks opening discontinued Ticketsystem - Opening integrated IRC Chat support instead now
    It's as usual available via OTA: Settings->About->Software Update or VenomTweaks->Advanced->OTA Update
    There won't be a fullrom for 2.3.0.
    We will release 2.4.0 as fullrom with the new base in a few days.
    Enjoy
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
    Naples
    Oneplus 11 16/256
    Finalmente :
    Backup options
    Internal SDCard
  4. #73
    Apr 2010
    Quote Originariamente inviato da sirioo Visualizza il messaggio
    Finalmente :
    Backup options
    Internal SDCard
    Ciao come lo faccio il backup dei dati ??
    non trovo l'opzione
    Naples
    Oneplus 11 16/256
    Quote Originariamente inviato da anomalos Visualizza il messaggio
    non trovo l'opzione
    bk opzioni dei tweaks , trovi profiles nella pagina about
  6. Il seguente Utente ha ringraziato sirioo per il post:
    anomalos (13-07-16)
  7. #75
    Apr 2010
    Tu lo metti il firmware 401.3 o aspetti che esca la 2.4
    Naples
    Oneplus 11 16/256
    Attendo per ora non ce fretta, approfitterò del salvataggio dei setting per fare un fullwipe e monterò la fullrom da 0
  9. #77
    Apr 2010
    ma non credo ci siano problemi nell'aggiornarlo ...
    vorrei sapere se questo va bene http://www.electronicpunk.com/leedro...1.80.401.3.zip
    Grazie sirioo
  10. #78
    Naples
    Oneplus 11 16/256
    Grazie sirioo
    Io li prendo da qui
    https://docs.google.com/spreadsheets...6yUY2s/pubhtml
  11. Il seguente Utente ha ringraziato sirioo per il post:
    kaos80 (13-07-16)
  12. #79
    Senior Droid L'avatar di kaos80
    Ringraziato 65 volte in 51 Posts
    Si sa cosa c'è di nuovo nel nuovo firmware?
    Inviato dal mio HTC 10 usando Androidiani App
  13. #80
    Naples
    Oneplus 11 16/256
    Viper10 2.4.0(FULL ROM ONLY (14 July)
    Rebased to 1.80.401.3(All carriers still supported)
    Additions & Updates
      • STREAM_VOICE_CALL
      • STREAM_SYSTEM
      • STREAM_RING
      • STREAM_MUSIC
      • STREAM_ALARM
      • Random mode
      • Backup options
        • Internal SDCard
    Fixes & Cleanups
    • Fixed bottom padding of Horizontal quicksettings
    • Horizontal quicksettings are now vertically and horizontally centered
    • Moved Horizontal quicksettings indicator a bit down when text is hidding
    As usual you can download latest versions on our website, enjoy!
  14. Il seguente Utente ha ringraziato sirioo per il post:
    kaos80 (16-07-16)
