Pagina 9 di 17 primaprima ... 7891011 ... ultimoultimo
Visualizzazione dei risultati da 81 a 90 su 166
[ROM] Viper10 | Android N ◦ Tweaks | HUB | OTA
  1. #81
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Viper10 2.6.0 (28th July)
    Additions & Updates
    • Rebased on 1.90.401.3
    • Updates Sense Home to 8.14.781908
      • Android Security Patch Level from July 1st, 2016
      • 16s exposure time
      • Lags are gone after reboot it seems
      • ...lets wait for the official changelog (-:
    • Custom Autobrightness
      • Change the brightness for different light sensor levels
        • It's possible to decrease the minimum autobrightness by 10%! from (30 to 1 on lowest light sensor setting)
        • Customize the brightness value for each sensor level yourself
      • Add/Edit Light Sensor Levels
        • It's even possible now to add more sensor levels if the given ones do not please you
        • Makes it possible to adjust the brightness values better to different light conditions
    • Hide Weather on LockScreen
    Fixes & Cleanups
    • Fixed JB Toast Style Toggle
    • Fixed Dim BLN - LEDS will blink with full brightness now
    • Restored original Traffic Icon Location
    • Fixed positioning of Venom Battery Text
    Fullroms:
    MD5: C388A743125F3D79B965C091845CB1BA
    AndroidFileHost
    German Mirror
    There will be no OTA from 2.5.0 to 2.6.0, because 2.6.0 is rebased on 1.90.401.3.
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
  2. I seguenti 4 Utenti hanno ringraziato sirioo per il post:
    ant90 (30-07-16),carminuccio (31-07-16),iLuke (28-07-16),kaos80 (12-08-16)
    Jan 2011
    Buongiorno a tutti.
    Qualcuno può mettere il link per il download del firmware perché non riesco a trovarlo da nessuna parte?
    Grazie mille
  5. #83
    Androidiani Power User L'avatar di pasudag
    Aug 2014
    HTC 10, HTC One M7
    Ringraziato 1,002 volte in 844 Posts
    Quote Originariamente inviato da TuLKaS Visualizza il messaggio
    Buongiorno a tutti.
    Grazie mille
    https://www.androidfilehost.com/?fid=24665539028713498
    Ultimo firmware disponibile attualmente.
    Inviato dal mio HTC 10 utilizzando Tapatalk
    HTC U 11
    FIRMWARE: 2.33.401.10
    Versione Android 8.0 "OREO"
  6. Il seguente Utente ha ringraziato pasudag per il post:
    kaos80 (13-08-16)
  7. #84
    Naples
    Oneplus 11 16/256
    Viper10 2.9.0 (26th August)
    Additions & Updates
    • Toggle to prevent camera acquiring maximum screen brightness when opening it
    • Signal strength icon for statusbar
      • dBm or ASU level option
      • Custom color
    • Added CM ScreenRecorder App
    • ScreenRecorder Tile to start/stop screen cast
    Fixes & Cleanups
    • Fixed some shortcuts not working for the Sense Home Menu
    • Fixed notification background color not applying
    • Fixed "Add to home" FC on Sense Home Menu
    As usual available via the OTA system:
    Settings->About->Software Update
    or
    VenomTweaks->Advanced->OTA Update
    ..fullroms later when I'm in the mood.
  8. I seguenti 2 Utenti hanno ringraziato sirioo per il post:
    iLuke (26-08-16),kaos80 (26-08-16)
  9. #85
    Androidiano L'avatar di dado866
    May 2014
    HTC One Black
    Ringraziato 43 volte in 30 Posts
    postate qualche screen delle personalizzazioni, sono interessato ma vorrei saperne di più
    *OnePlus 3T 64gb gunmetal Oreo 8.0 Stock
    *HTC One M7 ROM: Slim 7.1.2 | twrp-2.8.7.0 **UNLOCKED** M7_UL S-OFF / CID: SuperCID
  10. #86
    Naples
    Oneplus 11 16/256
    Quote Originariamente inviato da dado866 Visualizza il messaggio
    dai un occhio qui :
    [ROM] 26/08 Viper10 2.9.0 | 1.90.401.5 | HTC 10
  11. #87
    Naples
    Oneplus 11 16/256
    Viper10 3.0.0 (6th September)
    Additions & Updates
    • Rebased on 1.95.401.3
    • Visual theming - Tap item to change its color
      • Notification area: Header, Horizontal Quicksettings, Notifications, Weather
      • Native Quicksettings
      • Volume Dialog
    • Configure update interval of traffic icon
    • Option to disable Notification LED (useful if you use button light notifications)
    • Option to disable LED's when on DND (Notification LED and Button Lights Notification LED's)
    • Option to disable Charging LED on DND
    Fixes & Cleanups
    • Fixed signalstrentgh not showing for cdma phones - damn murricans always need an extra wurst
    • Fixed button light notification led getting stuck on "On State" sometimes
    • Fixed custom autobrightness "Normal" Profile not applying in VenomTweaks
    Since its a new base (again) with quite some changes there won't be an OTA Update.
    Fullroms:
    AndroidFileHost
    GDrive
    Ultima modifica di sirioo; 07-09-16 alle 12:02
  12. #88
    Naples
    Oneplus 11 16/256
    Viper10 3.1.0 (13th September)
    Additions & Updates
    • Temperature Infoline
      • Battery
      • CPU
      • GPU
      • Thanks for the extra work you sons of murricans. Supports Fahrenheit - Setting is pulled from the HTC Weather app.
    • Theme Brigthness Slider
      • Slider
      • Thumb
      • Autobrightness button
    Fixes & Cleanups
    • Fixed Visual Theming FCing when the header wasn't reorderd once
    • Header clock color can be applied now without setting an HTML preset
    • Added required statusbar reboot for some visual theming items
  13. #89
    Naples
    Oneplus 11 16/256
    Viper10 3.2.0 (2nd October)
    Additions & Updates
    • Venom HUB Web Store opened! (VenomHUB Desktop)
      • Browse all VenomHUB content on your desktop browser
      • Download apps, themes and addons to your desktop
      • Install apps, themes and addons from your desktop browser directly on your device(like it works with the play.google.com)
      • Addons, themes and other items can show linked items(f.e. you will see if some addons are compatiable with theme)
      • Minor UI improvemnets in WEB HUB and in HUB App
    • Add "Clear recents apps" mapping to button actions and three finger gesture
    • Add doubletap statusbar action to scroll content to the top
    • Disable Vibration system wide
    • Allow haptic feedback during powersaver
    • Set media volume as default when using the volume rocker
    • Removed VZW disabled data message when toggling and on boot
    Fixes & Cleanups
    • Fixed HTC Music FC when using HTC car app (full rom only)
    Available as OTA:
    via Settings->About->Software update / VenomTweaks->Advanced->OTA Update.
    Fullroms:
    AndroidFileHost
    Germany
    GDrive
    Information regarding the VenomHUB Store:
    Ensure you open VenomHUB once before, to resync the account (If it doesn't work, go to Settings->Sync & Accounts->Venom press the 3 dots on the top right and sync)
    You can access the Web store on https://hub.venomroms.com. ensure you relogin after syncing the VenomHub on your device.
    If you don't see the store on the Web Hub, it cached the old version. Press ctrl+f5 to hardreload the page.
    To remote install, you simply hit install on the items you want to install and then on the bottom right theres a circle with down arrow you need to click, to start the installation.
    After pressing it, you'll get a popup on your HTC10 to install the requested items
    Everyone hitting the thanks button without leaving a comment will get negative Karma points.
  14. Il seguente Utente ha ringraziato sirioo per il post:
    pasudag (03-10-16)
  15. #90
    Naples
    Oneplus 11 16/256
    Viper10 3.3.0 (16th October)
    Additions & Updates
    • Caffeine tile now shows a toast message when the labels are hidden for neqs
    • Theme the advanced power menu
      • Background
      • Item title color
      • Item summary color
      • Icon color
    • New Venom Package Installer(Replaced system package installer)
      • Install apps in background(progress in notification)
      • Install multiple apps at the same time.
      • Show proper reason, when some app is not installed
      • Button to ignore overlay detection
    • Optimized caching in VenomHUB, loading will be faster now
    • Option to show battery temperature in battery percentage info line
    • Disable bugreport getting created when pressing both volume buttons at the same time
    Fixes & Cleanups
    • Fixed brightness slider auto brightness mode disappearing with a custom color set
    • Fixed VenomHUB Remote install FC when installing bootanimation
    • Fixed stuck progress bar on remote install
    • Fixed VenomHUB apk update
    • Fixed ImmobilienScout24 Fcing, caused by scroll to top mod. Probably affects other apps that are bad coded.
    Available as OTA:
    Fullroms:
    AndroidFileHost
    Germany
    GDrive
    Don't forget about your karma...!
  16. Il seguente Utente ha ringraziato sirioo per il post:
    iLuke (17-10-16)
