Pagina 10 di 17 primaprima ... 89101112 ... ultimoultimo
Visualizzazione dei risultati da 91 a 100 su 166
[ROM] Viper10 | Android N ◦ Tweaks | HUB | OTA
  1. #91
    Moderatore L'avatar di sirioo
    Naples
    Oneplus 11 16/256
    Ringraziato 1,287 volte in 1,060 Posts
    Viper10 3.4.0 (21nd October)
    Additions & Updates
    • Merged with 1.95.401.4 base
    • Custom apm backgrounds
    • Color 'No Notifications' text
    • Color Clear text and button
    • Themes can now use a theme.prop in /system/customize/ (again) to preset colors values
    Fixes & Cleanups
    • Removed plenty of venom debugging info cluttering the logcat
    • Fixed weather widget icons not applying when a sense theme is installed
    Available as OTA:
    via Settings->About->Software update / VenomTweaks->Advanced->OTA Update.
    I'll update the fullroms : http://venomroms.com/viper10-dowloads/
    Ultima modifica di sirioo; 22-10-16 alle 00:28
    Device : OP11 Grey - 16/256 | Rom : OOS 14 BA | Audio Mod : Dolby Atmos + ViperFX RE | Kernel: Stock | Recovery : Stock
    NON ACCETTO RICHIESTE DI AIUTO IN PRIVATO
    ****RISPETTA IL REGOLAMENTO DEL FORUM****
    Administrator L'avatar di iLuke
    Jan 2011
    Ringraziato 5,317 volte in 3,365 Posts
    Viper10 4.0.0 Beta Preview (24th November)
    Additions & Updates
    • Rebased on 2.28.401.6 Android N base
    • Magisk support, thx @topjohnwu
    • Rooted with phh superuser by @phhusson (SuperSu didn't let the rom boot)
    • Some additions to customize the new quicksettings
    Information, please read
    • 95% of the tweaks are working..for the ones that are not, we are aware if it. Please don't report, complain or ask for them.
    • Download links you'll find on our homepage
    • There are major issues with decryption and TWRP. Please read the information on the homepage...they are really important!
    • Thanks to the godlike and most genius of HTC developer LlabTooFeR (that came out of his mouth! ). He made the release possible.
    :::::::::::: REGOLAMENTO DEL FORUM | FAQs | TAG BBCode ::::::::::::
  4. Il seguente Utente ha ringraziato iLuke per il post:
    sirioo (24-11-16)
  5. #93
    Apr 2010
    Quote Originariamente inviato da iLuke Visualizza il messaggio
    Additions & Updates
    Mi sembra di aver capito che ancora c'è qualche problema con twrp il firmware ... se magari potete mettere una bella guida dopo averla provata Grazie
  6. #94
    Naples
    Oneplus 11 16/256
    Basta attendere una twrp compatibile oppure rimettere un firmware antecedente dopo l'installazione . Io attendo una Twrp compatibile
  7. #95
    Apr 2010
    Quote Originariamente inviato da sirioo Visualizza il messaggio
    Aspetto anche io .. Grazie
  8. #96
    Androidiani Power User L'avatar di pasudag
    Aug 2014
    HTC 10, HTC One M7
    Ringraziato 1,002 volte in 844 Posts
    Purtroppo dipende dal kernel la non compatibilità della twrp, fino a quando htc non pubblicherà i sorgenti di quest'ultimo il problema non si risolverà..ad ogni modo c'è più di un'alternativa per provare la rom nougat con firmware nuovo, ovviamente la recovery è inutilizzabile..
    Inviato dal mio HTC 10 utilizzando Tapatalk
    HTC U 11
    FIRMWARE: 2.33.401.10
    Versione Android 8.0 "OREO"
  9. #97
    Naples
    Oneplus 11 16/256
    All downloads on:
    Viper10 4.1.0 (06 December)
    Additions & Updates
    • US Unlocked Support (Fullrom only) - Enables VoLTE, WiFi Calling
    • SuperSU option: Works better for some apps, but breaks safety net.
    • Enabled camera panorama selfie mode (Fullrom only)
    • Headsup notification configuration works now
    • InCall Headsup notification - Replaces the fullscreen caller
    • Option to make InCall Headsup notification clearable (you can swipe it away without dimissing the call)
    • Region Screenshot
    • Statusbar theming is back
    • Enabled Systemui tuner
      • Added Navbar Tuner
      • Added Nightmode/Color filter option
    • Notification theming complete now - color for footer can be set.
    • Added option to show DND on volume panel
    • Volume DND panel gets themed with volume backgroud color and NEQS text color (same DND panel is in NEQS)
    • Custom button light values per light sensor value
    • Button and flashlight notifications
    • Venomnavbar is back with extended navbar
    • Hide options for stock navbar and venomnavbar (auto hide, touch anywhere to hide, shortpress, longpress hide)
    • Color options for navbar working now
    • Header options are back
      • Aligned header views with other content in the header
      • Decreased default infoline text size
      • Infoline textsize configurable now
      • There are some bugs still with the header options..those will be fixed hopefully till next weekend - For people that can't live with the broken animation when expanding neqs can revert the statusbar of the previous release.
    • Force enabled call recording
    Fixes & Cleanups
    • Fixed OTA - works just for people on old firmware running decrypted. Get that ****ing TWRP running @nkk71 , @topjohnwu and @beaups :P
    • Fixed distorted statusbar notification count
    • Fixed screenshot button mapping causing shell to reboot
    • Fixed selecting custom lockscreen weather location fcing VenomTweaks
    • Fixed hidden battery reappearing after statusbar reboot/reboot
    • Button light notifications
      • Fixed lights getting turned off although its set to always on in the native settings when using button light notifications.
      • Fixed lights staying on and draining battery after timeout hits
    • Fixed VenomSideBar force closing when trying to access the setttings
  10. I seguenti 2 Utenti hanno ringraziato sirioo per il post:
    iLuke (08-12-16),pasudag (09-12-16)
  11. #98
    Naples
    Oneplus 11 16/256
    Viper10 4.2.0 (Tonight)
    Additions & Updates
    • Rebased to 2.28.401.9
    • Hiding Persistent notifications (lets you hide them, without disabling other notifications of the app)
    • Different options how to show the (full) alarm in your statusbar header
      • Expanded only (stock)
      • Collapsed only
      • Expanded and collapsed state
      • Hide both
    Fixes & Cleanups
    • Fixed bundled notification row not getting themed
    • Fixed notifcations with children not getting themed (happend for mail/message apps when several unread notifications were present)
    • Fixed appdrawer not flinging from page two to one when blinkfeed is disabled
    • Fixed neqs not expanding
    • Fixed toggle to disable keep quick neqs collapsed not working
    • Fixed Ambient Display not working
    • Disabled SystemInfo circles for now
    All downloads on:
    Ultima modifica di sirioo; 09-12-16 alle 19:28
  12. #99
    Jan 2011
    Qualcuno ha provato la nuova rom 4.2.0?
    nel caso come si sta trovando?
  13. #100
    Aug 2014
    HTC 10, HTC One M7
    Quote Originariamente inviato da TuLKaS Visualizza il messaggio
    Messa adesso, è ancora da testare un po' soprattutto nel funzionamento dei tweaks, per il momento è ok.
    HTC U 11
