Pagina 120 di 142 primaprima ... 2070110118119120121122130 ... ultimoultimo
Visualizzazione dei risultati da 1,191 a 1,200 su 1419
[KERNEL][KK]Dorimanx per KITKAT [LG G2]
  1. #1191
    Androidiano L'avatar di Sagace
    E' stato trovato un modo per risolvere il bug dello storage con 0gb di spazio totale?
    Androidiano VIP L'avatar di edoardomarco
    GNexus/Nexus4/LG G2/Note4
    Ringraziato 989 volte in 796 Posts
    NUOVA VERSIONE:
    14/4/15
    Kernel 10.2
    BETAS 10.1.1 --> 10.1.5
    *Replaced sepolicy for f2fs, now we using the LG original with mod for f2fs only. was CM11 binary.
    *Set boot scripts to use fstab to mount data or system or both as f2fs in case they formatted as f2fs.
    *Fixed bug in boot script that was braking STweaks load in case user set not to load settings on boot.
    *Merged fixes and optimizations to Alucard cpu gov and hotplug. and to Nightmare Cpu gov.
    *Tuned Alucard and Nightmare CPU govs for response and idle low drain.
    *Merged few fixes for SPS driver in MSM code. (Smart-Peripheral-Switch)
    *Fixed System not RO when not needed and not RW when needed... was mess there.
    *Fixed installing kernel when your system/data is F2FS.
    *Updated busybox 1.24.1 from source + Android NDK patches and fixes.
    *Added new STweaks sound control: INCALL Speaker gain! now we can boost the incall volume. not depending on headphones gain.
    READ the control description before asking!
    *Fixed hotplugs switch function, now works as should. in some cases cores where STUCK ONLINE when switching hotplugs.
    *Merged new I/O sched. "ZEN" it's fast and tuned for Android SSD storage.
    *Disabled hidden bricked hotplug driver, it's needs to be fixed before use. no point to leave it in RAM.
    *Alucard optimized all his CPU govs and his Hotplug driver + tuning by me.
    *Reverted one change in GPU driver that seems was the scrolling delay bug. we have more gpu steps than default driver.
    *Boosted GPU 100Mhz step with higher bus freq. to reduce small lags when min gpu freq is 100mhz.
    *Fixed bug with stuck cores when switching hotplugs. added small delay from one to other and cores off function.
    Now works as should. very old bug.
    *Changed vol to gain descriptions in STweaks XML for sound control.
    *Added new Advanced Color interface + App (color control) by @savoca great stuff!
    when i have set saturation to 50 inside app, i have finally seen true awesomeness of my screen!
    *Updated Intelligent Thermal driver, to use global freq control functions, and clean old deprecated code!
    *Fixed LOAD ALL button in STweaks.
    *Merged new STweaks app compiled by @Krija now it's called DORIMANX simple as that.
    *Set ZEN I/O driver as default in all profiles and on boot.
    *Merged updates to SPI, SOUND, NET, BAM_DMUX, RQ-STATS drivers.
    *Merged updates to Interactive CPU GOV.
    *Merged updates to MSM CPUFREQ code including better Power Management code.
    reduced deepsleep power use to -5ma!!!
    *Merged updates to Alucard Hotplug by DEV.
    *Fixed code bugs and disable 2 useless debug logs that no one need.
    *Added more checks to charger driver for releasing charger wakelock when no power connected!
    *Added boost to I/O using less merge checks and allowed to use different CPUs to finish I/O tasks.
    *Fixed small bugs in boot scripts.
    NEW changes!
    *Merged updates to EXFAT driver.
    *Merged better idle dynticks code for fast CPU idling when system is not loaded.
    Should save more power.
    *Disabled some encrypt custom ARM drivers to be able to use STOCK encryption.
    *Merged update to Touch Boost Driver by Alucard.
    Quote Originariamente inviato da Sagace Visualizza il messaggio
    che io sappia ancora no
  4. #1193
    Senior Droid L'avatar di GastonILbello
    Sep 2014
    Ringraziato 163 volte in 140 Posts
    Quote Originariamente inviato da kRel Visualizza il messaggio
    Ricordo che hai detto che hai KK: usi il Dorimanx con la Cloudy o cosa ?
    Piesse, ma il FS di KK e/o lollipop è f2fs ???
    uso il dorimanx sulla 20 stock di 6ril1 e lo zip v2 debloated di somboons.
    il file system di kk è ext4 e credo che sia così anche su lollipop
  5. #1194
    Nov 2013
    Napoli
    Htc One
    Ragazzi ho la cloudy g2 con Dorimax 9.8,, a quale versione aggiorno ?? (con questa la batteria dura molto ed ho setting di Gaston)
    Device: HTC One Silver
    S-OFF
    HBOOT: 1.57.0000
    RADIO: 4T.27.3218.14 - OPENDSP: v32.120.274.0909 - FIRMWARE: 6.09.401.5
    RECOVERY: TWRP 2.7.1.1
    ROM: Insertcoin-m7 4.0.2
    KERNEL: Kangaroo v045
  6. #1195
    Sep 2014
    Quote Originariamente inviato da Ciro955 Visualizza il messaggio
    aggiorna all'ultima versione e usa i miei settings che va alla grande
  7. #1196
    Androidiano L'avatar di Egerfaust
    Treviso
    OnePlus 3 - Soft Gold
    Ciao ragazzi, attualmente monto la cloudy g2 2.2 con recovery Bump e Bootloader Kitkat. Vorrei provare questo kernel con i settaggi di Gaston, mi intimoriscono 2 cose, la prima, quella di fare un backup dei dati perchè può andare in bootloop (succede spesso? non vorrei fare il wipe dei dati per provare un kernel), la seconda è questa:
    - Lokified during flash! Suport ONLY JB BootLoaders!
    Significa che con la mia configurazione non posso flasharlo?
    Grazie!
    Smartphone: OnePlus 3 - Soft Gold - Android 6.0.1 - OxygenOS 3.2.7
  8. #1197
    Nov 2013
    Napoli
    Htc One
    Quote Originariamente inviato da GastonILbello Visualizza il messaggio
    10.2 giusto?
    I setting sono sempre quelli in prima pagina?
    S-OFF
    HBOOT: 1.57.0000
  9. #1198
    Sep 2014
    Quote Originariamente inviato da Egerfaust Visualizza il messaggio
    Grazie!
    hai già quello che ti serve, cioè recovery bumped (spero tu abbia la 2.8.6.1) e bootloader di kk, quindi puoi benissimo passare al dorimanx.
    ti suggerisco, cosi come viene fatto in ogni discussione su xda, di eseguire un nandroid backup da recovery, non si sa mai
    10.2 giusto?
    si giusto e i settings sono quelli di prima pagina
  10. Il seguente Utente ha ringraziato GastonILbello per il post:
    Egerfaust (16-04-15)
  11. #1199
    Nov 2013
    Napoli
    Htc One
    Una volta scaricato mi basta flasharlo e basta ? Cioe come fosse un aggiornamento
    S-OFF
    HBOOT: 1.57.0000
  12. #1200
    Sep 2014
    prima di flashare devi fare il wipe di cache e dalvik
  13. Il seguente Utente ha ringraziato GastonILbello per il post:
    Ciro955 (15-04-15)
