Pagina 41 di 142 primaprima ... 3139404142435191141 ... ultimoultimo
Visualizzazione dei risultati da 401 a 410 su 1419
[KERNEL][KK]Dorimanx per KITKAT [LG G2]
  1. #401
    LG G2
    Ringraziato 95 volte in 92 Posts
    Togli il dorimanx che fa pena e metti il Kernel Bruce.
    Samsung Galaxy S7
    Rom: SuperStock
    Kernel: Superstock 2.0
    Recovery: TWRP 3.0.2.4
    Androidiano VIP L'avatar di edoardomarco
    GNexus/Nexus4/LG G2/Note4
    Ringraziato 989 volte in 796 Posts
    Quote Originariamente inviato da rhinos92 Visualizza il messaggio
    Ciao ragazzi..ho un problema...monto il kernel dorimanx 7.1 sulla pardusHD sensation black 3.2..uso il profilo postato da zio ciccio...tuttavia soffro di continui crash alla home e alle app anke nel multitasking...infatti vedendo il task manager ho sempre 1.5 gb occupati pur avendo poche app installate...cpme posso risolvere?grazie dell'aiuto!!
    Nel tab tweaks prova a levare la spunta a " memory tweaks " e ad applicare le modifiche
    NUOVA VERSIONE:
    05/09/14
    Kernel 7.3
    *Fixed CPU Hang BUG added at 7.2 kernel...
    *Merged FIX for BT memory leak.
    *Merged Sound Control driver rewrites + mods.
    Now default headphones + in call speaker gain will be 2.
    *Fixed back light Control mod. now will do change only if device in dark room.
    and will not cause back light flickering when LUX is above 100 (bright room)
    *Allowed to use ONLY Intelligent Thermal control and set safe TEMP controls.
    BUT when using ONLY Intelligent Thermal control camera app will close longer!
    Cant fix that. ROM thermal is CLOSED source binary.
    *Now Analog PA setting via Faux Sound app will STICK. and not reset to default when no sound playing.
    If you have no change modding the PA gain, then your hardware/Software
    is supporting only PA on/off and it's set ON by default, no min/max.
    And we cant turn it OFF.
    This is how my hardware/Software behave.
    08/09/14
    Kernel 7.4
    *Fixed low/high sound bugs. now music will be clear, and incall will be loud.
    *Merged memory leak fixes for logger code.
    *Merged Support for MIUI KK STOCK Base ROMS.
    *Allow to set CAMERA and Incall MIC to -30 in STweaks to allow sound record in concerts.
    *Fixed Analog Power Amp gain control in Faux App.
    12/09/14
    Kernel 7.5
    *Fixed sound hissing in low end headphones/headsets.
    *Enabled HIFI performance code for all formats to fix sound.
    *Fixed HIGH speaker sound on boot animation.
    *Merged new thermal control core by Faux123 and converted it to
    Intelligent Thermal Control! it's super fast and holding temp just awesome.
    not letting any overheats to happen.
    *Allow to set MIC gain to -40 as requested by users.
    *Fixed Default HotPlug not activated on boot if selected as default.
    *Updated Sound Control code by faux123 to 3.6 build.
    *Merged code to reduce I2C bus source freq from 50Mhz to 19Mhz
    it's will save power.
    *Merged code that will allow us to use Mutli ROM recovery and switch kernels online! and boot to secondary ROM. for fun!
    Now we need to wait till recovery is finished and we will be the first LG G2 dual boot users!!!
    *Merge small fix to kthread work that help to reduce useless jobs in kernel.
    Ultima modifica di edoardomarco; 12-09-14 alle 12:12
  4. #403
    Androidiano VIP L'avatar di Pilone92
    Venezia
    SAMSUNG S+ - LG G2 - ONEPLUS 5
    Ringraziato 514 volte in 421 Posts
    Qulacuno ha testato la versione 7.5 con la rom optimusg3?
    Aug 2014
    Io sembra più veloce
  6. Il seguente Utente ha ringraziato mprovinzano per il post:
    Pilone92 (12-09-14)
  7. #405
    Senior Droid L'avatar di mcallister
    Ringraziato 47 volte in 43 Posts
    Megloo bruce o dorimanx per la batteria?
    DISPOSITIVI:
    ATTUALI:
    1.LG G2
    2.Asus Memo Pad FHD 10-stock
    3.Htc G1- CyanogenMod 7.2 and cwm recovery
  8. #406
    LG G2 D802
    Ringraziato 212 volte in 200 Posts
    Quote Originariamente inviato da mcallister Visualizza il messaggio
    Dorimanx senza dubbio
  9. #407
    Androidiano L'avatar di antonycapo
    Ringraziato 49 volte in 35 Posts
    Scusa avevo funzionate la cloudy 1.3 pulita ho riavviato da recovery dopo aver installato lo zip del dorimanx 7.5 d802 nel telefono ,ho flashato dopo aver fatto i reset completi tranne nella memoria interna ,ed ora al riavvio continua a rimanere fissa la scrtta lg e il telefono non riparte piu ,sono rientrato nella recovery ho rifatto lo stesso procedimento mha si ferma sempre li...soluzioni?grazie
    Ultima modifica di antonycapo; 12-09-14 alle 21:41
  10. #408
    LG G2 D802
    Quote Originariamente inviato da antonycapo Visualizza il messaggio
    Prova a fare un Wipe cache e dalvik cache. Eventualmente se non funziona rimetti il kernel che avevi prima
  11. #409
    Quote Originariamente inviato da poal98 Visualizza il messaggio
    Guarda ho reistallato lo zip della cloudy ed è tutto ripartito,dite che meglio scaricare un kernel versione precedente alla 7.5
    edit ora sembra essere ripartito dopo il flash del kernel...che cmq se entro in info telefono non vedo cambiato nel nome in info kernel
    Ultima modifica di antonycapo; 12-09-14 alle 22:11
  12. #410
    LG G2 D802
    Perché il kernel é basato sul kernel stock e quindi il numerino é lo stesso ma se usi app di terze parti come antutu o Android system info vedrai tutte le informazioni sul kernel.
