Pagina 49 di 142 primaprima ... 3947484950515999 ... ultimoultimo
Visualizzazione dei risultati da 481 a 490 su 1419
[KERNEL][KK]Dorimanx per KITKAT [LG G2]
  1. #481
    Androidiano VIP L'avatar di edoardomarco
    GNexus/Nexus4/LG G2/Note4
    Ringraziato 989 volte in 796 Posts
    Kernel 8.5
    *Merged updates for sound driver.
    *Merged updates for CORE code.
    *Fixed manual charge lock on 900ma using 1.8a charger.
    *Merged updates for SeLinux.
    *Added Auto mount F2FS partitions if formatted as F2FS on boot.
    *Fixed CRON functions and added calibrate battery every week.
    *Tuned Intelli and Alucad HotPlugs.
    *Fixed Thermal Core down/up control.
    *Added new controls for how many cores can be OFF during high temp.
    IF! Core control is Enabled.
    *Added HotPlug Live Status is Synapse main tab.
    *Fixed Profiles backup/restore
    *Made arrangements in STweaks XML to look more clear to understand.
    *Fixed Stuck freq on core0 after high pressure thermal test.
    will be reset to max on 55C temp.
    *Merged updates for Alucard Hotplug. more performance and smart hot-plugging.
    *Merged updates to Alucard, Darkness, Nightmare CPU govs from DEV.
    Improved freq handling.
    *Updated with latest ZVD+ZVE LS980 Source update from LG. it's common code
    for all branches.
    +Update to NFC driver
    +Update to MTP driver
    +Update to LCD panel driver
    +Update to sound driver
    *Tuned Ondemand to be more fast, and respond fast.
    *Fixed BUG in OOM LMK driver.
    *Moved all Thermal Controls back to STweaks, in new TAB.
    Synapse is now for live date state. for debugging. and for fun.
    *Fixed Stuck freq on CORE0 after boot. and after thermal event.
    *Updated Alucards Touch boost driver + add/remove control for it.
    See STweaks.
    *Tuned Ondemand gov.
    *We now Boot on 2.26Ghz then set by profiles. was 2.8Ghz (version 8.4 only)
    *Now ROM thermal alone can handle huge stress test on max TEMP of 77C
    for 5 min, that all i tested, i am sure it's can hold hour... just bad for hardware.
    *Fixed 1000ms description.
    *We now boot on four cores! so boot will be little faster.
    *Fixed possible SOD bug on charger overnight.
    and when disconnecting power.
    *Allowed to charge from USB3 port on 900ma as it's give us that.
    *Merged update for Alucard and Darkness CPU GOVS.
    *Fixed MIN freq stuck on some freq above 1GHZ
    now we can set MIN freq up to 1.03Ghz no more!
    we dont need more for MIN freq.
    *Fixed BUG in multi core freq set that can cause deadlock = SOD.
    *Tuned Alucard HotPlug, now last core will work on stress load. as others.
    Improved idle state on one core.
    HotPlug is smart, it's not turning all core for a finger swipe... so you will need to stress is a bit to see all cores online.
    *Updated ExFat driver, critical bug fixed inside the module.
    *Fixed performance degradation when freq reduced due thermal event.
    now will be restored back to max every time temp is reduced.
    by this boost performance to state of awesomeness!
    *Tuned ROM thermal policy to work with 5c temp diff for freq cuts.
    *Added controls for Touch boost driver in STweaks.
    *Possible random SOD on suspend FIX!
    *Disable some not used drivers.
    *Added zip binary for zipping kernel log on creation.
    so data inside will not be damaged on transfer to me.
    *Merged power use reducer code, for CPU, will allow to save more power on idle
    or low load.
    *Fix slow wakeup from long suspend.
    *Fix for Alucard Hotplug suspend function.
    *Tuned Intelli HotPlug to perform faster.
    Senior Droid L'avatar di CEMT96
    Reggio Calabria
    iPhone 5 16GB
    Ringraziato 60 volte in 49 Posts
    Ma come faccio ad entrare in recovery? :/
    Nulla è reale, tutto è lecito.
    iPhone 5 16GB iOS 10.1
    E ricorda che se ti sono stato utile ringraziami cliccando il tasto "Thanks" non fa male a nessuno e fa tutti più felici!!!
  4. #483
    Quote Originariamente inviato da CEMT96 Visualizza il messaggio
    Il modo più rapido è scaricare quickboot dal playstore aprirlo e selezionare recovery
  5. Il seguente Utente ha ringraziato edoardomarco per il post:
    CEMT96 (20-10-14)
  6. #484
    Reggio Calabria
    iPhone 5 16GB
    Ma come mai non si può overcloccare la gpu?
  7. #485
    Androidiano VIP L'avatar di Enr1988
    Legend-DS-GS2-GS3-MotoG-Lg G2
    Ringraziato 989 volte in 743 Posts
    Perché non si avrebbero dei vantaggi... Visto che già con frequenze stock di cpu e gpu il nostro g2 sotto stress va costantemente ad essere regolato dal thermal control, con conseguente downclock, per impedire che le alte temperature friggano lo schermo e l'hw...con l'Oc della GPU il thermal controll interverrebbe prima per una più rapida salita delle temperature con conseguente peggioramento delle performance!
    Se ti ho aiutato usa il tasto THANKS per ringraziarmi!!
    [B]Oneplus 3/B] Oxygen Os Beta 19 Dorimanx Kernel
  8. Il seguente Utente ha ringraziato Enr1988 per il post:
    asterixb (20-10-14)
  9. #486
    Reggio Calabria
    iPhone 5 16GB
    Capisco la cpu. Ma la cpu si puo anche tenere stock o a 2ghz che tanto é bella potente lo stesso ma la gpu almeno... Io uso molti giochi e un po di prestazioni grafiche in piu mi farebbero comodo
  10. #487
    Io gioco poco, ma in tutti i giochi provati con grafica avanzata non ho mai sentito la necessità di fare un OC della gpu... Magari devi semplicemente cambiare i settaggi del kernel..prova intelliactive come governor e vedi come ti trovi
  11. #488
    Reggio Calabria
    iPhone 5 16GB
    Ho messo il settaggio preimpostato performance e dead trigger 2 mi fa 20-30 fps, ora provo a mettere intelliactive e vediamo come va
  12. #489
    Ringraziato 34 volte in 32 Posts
    Se non sbaglio performance locka la frequenza al massimo disponibile, difficile avere un governor più performante XD
  13. #490
    Reggio Calabria
    iPhone 5 16GB
    Non il governor, il profilo. Comunque se metto quel governor si frigge il telefono ahaha
