Pagina 4 di 71 primaprima ... 234561454 ... ultimoultimo
Visualizzazione dei risultati da 31 a 40 su 706
[KERNEL][LP]Dorimanx per LOLLIPOP[LG G2]
  1. #31
    Androidiano VIP L'avatar di edoardomarco
    GNexus/Nexus4/LG G2/Note4
    Ringraziato 989 volte in 796 Posts
    Kernel 3.0
    *Merged updates to cpufreq code structure.
    *Merged big update to drivers/base code including power and RAM code fixes.
    Many bugs fixed, code updates from 3.10.y android msm.
    *Merged update to Dorimanx App by @Krija
    *Set ZEN and other I/O govs to support high fifo batch tuning to reduce load on eMMC
    Thanks to @Duki994 for pointing this out.
    *Set eMMC nomerges = 2 to reduce CPU load when high I/O is needed for APPS or downloads.
    this speedup SQL Data Bases read/write by 6sec! it's LONG time to wait for something to "MOVE"
    *Enabled CPU accounting and grouping per task as LP ROM need that, and i have disabled in config.
    Seen errors in LOGS and enabled. now all clean. should help with CPU power redistribution per apps.
    *Fixed max 4 cores online. even if user set max 2 and turned screen OFF/ON, now kernel obey user needs after boost on wakeup.
    *Corrected some Dorimanx XML descriptions.
    *Fixed setting SELINUX ON, and mounting modem with full selinux rights and perms after selinux was OFF.
    *Corrected busybox not working if Selinux is ON and set to enforce.
    *Corrected permissions for selinux ON mode in kernel folders and scripts.
    *integrati i fix alla struttura del codice cpufreq
    *integrati fix imnportanti a driver/codice di base
    *integrati update all app dorimanx
    *impostati zen e altri io govs in modo che supportino un settaggio alto di fifo batch
    *abilitato l accounting e il gouping per task della cpu
    *fixata la modalita max 4 core online
    *corrette alcune descrizioni xml dorimanx
    *fixato il selinuxon
    *corretto busybox non funzionante se il selinux era on
    *corretti i permessi per la modalita selinux on nelle cartelle e scrips del kernel
  2. Il seguente Utente ha ringraziato edoardomarco per il post:
    DreamReaper (18-06-15)
    KERNEL 3.0 BUGGATO QUINDI VERRÀ RIMOSSO, uscita la 3.1 a breve l italiano
    19/06/15
    Kernel 3.1
    *Reverted change that make reboot in suspend. now stable (i had reboot too!)
    *Merged fix for Alucard cpu hotplug by DEV.
    *Merged fix for HDMI code. resolution change fix.
    *Fixed OTA app access to /cache/recovery/
    *Set max GPU freq to 450 for performance profile. just in case. set higher if you wish.
    kernel 3.0 will be removed. BUGGED.
    nemmeno la traduco: rimossa anche questa
    Ultima modifica di edoardomarco; 19-06-15 alle 21:38
  5. I seguenti 2 Utenti hanno ringraziato edoardomarco per il post:
    DreamReaper (19-06-15),gianpassa (19-06-15)
  6. #33
    Senior Droid L'avatar di Ringo89
    Ringraziato 52 volte in 46 Posts
    A breve rilascerà una 3.1.1. Pare abbia trovato la causa dei reboot casuali che alcuni utenti segnalano. Fortunatamente io non riscontro alcun problema.
  7. Il seguente Utente ha ringraziato Ringo89 per il post:
    riccese (19-06-15)
  8. #34
    Androidiano L'avatar di riccese
    molise
    Huawei P20 PRO
    Ringraziato 26 volte in 24 Posts
    azz...l'ho messo da 1 paio d'ore (la 3) e non stavo riscontrando problemi. Che faccio, rimetto lo stock in attesa del 3.1 o superiore???
  9. #35
    Androidiani Power User
    Quote Originariamente inviato da Ringo89 Visualizza il messaggio
    Io non ho mai avuto problemi, sono con il nightmare, ma risolse subito il problema.
    Quote Originariamente inviato da riccese Visualizza il messaggio
    Secondo me la puoi tenere, io la avevo (adesso ho messo la 3.1) e non ho mai avuto reboot
  10. Il seguente Utente ha ringraziato th3D0ct0r per il post:
    riccese (19-06-15)
  11. #36
    molise
    Huawei P20 PRO
    bene...per sicurezza ho messo pure io la 3.1 proprio ora !
    sto scaricando la 3.1.1 appena upplodata
    Ultima modifica di riccese; 19-06-15 alle 14:04
  12. Il seguente Utente ha ringraziato riccese per il post:
    th3D0ct0r (19-06-15)
  13. #37
    Ci sta la 3.1.2 adesso
  14. Il seguente Utente ha ringraziato th3D0ct0r per il post:
    riccese (19-06-15)
  15. #38
    molise
    Huawei P20 PRO
    arghhhhh !!! si ora riavviato con la 3.1.1 nemmeno la provo e metto la 3.1.2
  16. #39
    Ringraziato 63 volte in 47 Posts
    Ripeto qui la domanda visto che ero OT nell'altra discussione.
    Quanto tempo impiegate per una ricarica con questo kernel?
    Quali altre migliorie porta all'uso quotidiano ?
  17. #40
    Quote Originariamente inviato da elvi92 Visualizza il messaggio
    Con la ricarica a 1600ma impiego circa 90 minuti se non lo uso mentre carica, altrimenti ci vogliono dai 100 ai 120 (dipende da quanto lo usi)
  18. Il seguente Utente ha ringraziato th3D0ct0r per il post:
    elvi92 (19-06-15)
