Pagina 255 di 597 primaprima ... 155205245253254255256257265305355 ... ultimoultimo
Visualizzazione dei risultati da 2,541 a 2,550 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #2541
    Venezia
    S4 & G3
    Quote Originariamente inviato da samsungboy Visualizza il messaggio
    Provato? Miglioramenti sul multitasking e consumi?
    ancora no, l'ho postato stamane.... ma lo provo sicuramente.
    Androidiano L'avatar di vuar62
    caserta
    Quote Originariamente inviato da redefined Visualizza il messaggio
    nuovo ironkernel hack64 disponibile
    https://github.com/downloads/SetiroN...eats-check.zip
    Questa, non è ics, va bene per la cayno 7?
    Samsung S6 Edge plus SM-928F
  4. #2543
    Venezia
    S4 & G3
    Quote Originariamente inviato da vuar62 Visualizza il messaggio
    One-package-fits-all: just replace the ramhack with what you want and the right version (ICS or GB) will be installed
    i.e. ironkrnL64_date -> ironkrnL80_date
    New flags: rld, beats, check, su
    Linux updated to 2.6.32.58
    fixed a couple minor install script issues
    should be CWM touch compatible
    correctly renamed LG camera
    improved RAM behaviour
    mass storage (besides MTP) should work on ICS for the SDcard
    included Reloaded ICS app, credits to rob43 Reloaded ICS v1.9b2 04/01/12 | UI Enhancements for CyanogenMod 9 | Update: theming - General Themes / Extras - RootzWiki (donate to him! http://bit.ly/zSq1n6 )
    If you have battery issues it's not directly the kernel's fault. An application is running in the background, possibly because of corrupted data. Run a file system check, eventually try to isolate the running application and delete its data.
    fsck might render unaccessible previously corrupted files and prevent boot. In this case, reflash CM9. If some app's data was heavily corrupted, a reset might be necessary.
    OTF is a pointless gimmick, it gives no real advantages and potentially causes performance degradation
    FLAG RECAP:
    align : enable zipalign at boot (GB only)
    anim : disable boot animation
    app : install additional apps (GB only)
    basic : remove even the most basic tweaks
    beats : install beats by dre equalization
    cam : install lg camera
    check : run a file system check after flashing
    cron : disable cron job for automatic cache dropping
    debug : enable kernel installation debugging
    font : disable installing roboto font (GB only)
    host : disable install host file
    jrnl : enable ext4 journal removal and 'risky' mount options
    log : enable log removal
    nitz : enable nitz timezone fix (removed if missing)
    prio : install priority-modded services.jar on ICS (SK3 only)
    prop : disable build.prop tweaks
    rld : enable installing ReloadedICS
    sql : disable tweaked sqlite
    su : install updated SU binary that prevents segmentation faults
    uv : enable slight undervolt
  5. #2544
    Venezia
    S4 & G3
    in prima pagina ho inserito il link di un nuovo kernel per la cm7
  6. #2545
    vodonka ha aggiornato il suo kernel alla versione 3.0!
    e dice che con i driver lite si ha un ottima durata della batteria!
  7. #2546
    Venezia
    S4 & G3
    Quote Originariamente inviato da lucastraz Visualizza il messaggio
    si, ho appena visto. comunque il kernel di cui parlavo è stato "realizzato" anche con il suo aiuto.
  8. #2547
    ho provato a flashare il kernel 3.0 di etana e si blocca al logo lg
    penso sia un bug inquanto ho fatto tutti i wipe e provato anche piu volte ma nulla...!
    aspetto aggiornamenti.
    confermato quanto detto da molti altri utenti su xda
    Ultima modifica di lucastraz; 05-04-12 alle 17:04
  9. #2548
    Venezia
    S4 & G3
    hai provato quello postato in prima pagina?
  10. #2549
    sto riflashando l'etana che sembrerebbe aver risolto il problema...e comunque con il kernel che hai postato tu non dovrebbero esserci differenze apparte l otf e alcune chicche di vodonka!
    ancora bootlop!
    ora mi sono stufato e provo l' imperticus
    Ps. l'imperticus parte senza problemi senza bisogno dei full wipe....ora fase test!
    Ultima modifica di lucastraz; 05-04-12 alle 19:19
  11. #2550
    ancora bootlop!
    guardate questa discussione nuova base??
    xda-developers - View Single Post - [CM7][UNOFFICIAL][APR02] temasek's UNOFFICIAL BUILD RC1-85
    leggete poi anke qui
    [ROM][1 Apr] INDROID EVOLUTION RC3[V20Q] (RELEASED) - Page 12 - xda-developers
LinkBacks (?)
