Pagina 302 di 597 primaprima ... 202252292300301302303304312352402 ... ultimoultimo
Visualizzazione dei risultati da 3,011 a 3,020 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #3011
    Venezia
    S4 & G3
    Quote Originariamente inviato da 480p Visualizza il messaggio
    Quello che hai tu mi fa bloccare il telefono 2-3 volte al giorno senza undervolt, se questo non succedesse avrei il tuo kernel!!
    Inviato dal mio Optimus 2X con Tapatalk 2
    Ciao, invece a me il contrario. Usando gli etana ( non ho provato gli ultimi due) saltuariamente il cel mi resta bloccato a schermo spento e devo togliere la batteria. boh...
    Venezia
    S4 & G3
    Oggi temasek è uscito con la 100
    CHANGELOG (Same for N1 RC1-92)
    PORTS FROM EXTERNAL SOURCE
    NEW - Forgot to change intent on bootanimation chooser
    NEW - Add preference to bootanimation chooser
    NEW - Add preference for bootanimation chooser
    NEW - CM Boot Animation Helper
    NEW - Add bootanimation changer to CMParts (1/2)
    NEW - Custom action on the double tap on the home key.
    NEW - Increase double-tap delay for home key extra activity launcher
    NEW - Add a green gps-fixed icon to status bar
    NEW - try color changes to cmbattery and cmsignal text
    - Improve functionality of status bar restart + cleanup
    - Add option to restart status bar to CMParts
    - fix notification background changes2
    - added jerryscript notification backdrop changer 1/3
    - Add ability to show/hide remaining system icons in status bar (1/2)
    - Add ability to show/hide remaining system icons in status bar (2/2)
    - Make status bar dateview use clock's color
    - dropdown menu fixes
    - Statusbar color change mod by jerryscript
    - notification backdrop changer by jerryscript 1/2
    - notification backdrop changer by jerryscript 2/2
    - center clock 2/2 by Jerryscript
    - Statubar date fix
    - Statusbar mods by jerryscript
    MERGED COMMITS UP TO
    Change I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
    Gerrit Code Review
    CHERRY-PICKS
    If you see any picking is missing from last build, it is because it was merged, abandoned, reverted by me or I've eaten it up.
    NEW - Change I90858354: Optimize T9Search performance / memory consumption
    MERGED - Change I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
  4. #3013
    Androidiano VIP L'avatar di cajenna
    Mar 2011
    Tivoli (RM)
    Galaxy Note2 ~Tab2 10.1
    Ringraziato 208 volte in 186 Posts
    Ciao red,buonasera a tutti,appena aggiornata la temasek dalla 99 alla 100,la cosa più evidente è il logo di avvio,veramente simpatico,poi il resto è "sotto il cofano",finalmente,con queste build,ho trovato l'usabilità del dual,in attesa di ics,che al momento,non si sa quando verrà pubblicato (mannaggia LG).
    Questo ragazzo sta facendo veramente un ottimo lavoro,peccato che lg corea non assuma queste persone.
    Mi chiamo Silvio,molto piacere.
    Il mio sito...La mia configurazione e i miei test su windows 8...I ♥ my Samsung Galaxy Note2 LTE.
    <- Se in qualche modo ti sono stato utile,non dimenticarti di cliccare sul THANKS qui a sinistra.
  5. #3014
    Androidiano L'avatar di Napoletano80
    lg p990 dual core
    ciao ci fai sapere le prime impressioni sulla rom..durata batteria....rete...fluidità e che ke rnel e baseband usa grazie
    Quote Originariamente inviato da cajenna Visualizza il messaggio
  6. #3015
    Mar 2011
    Tivoli (RM)
    Come baseband utilizzo la 725 froyo,come durata batteria rientra nella normalità della V20q,rete molto buona e fluidità eccezionale,il mio dual è rinato.
    questo si riferisce alla RC1-99
  7. #3016
    lg p990 dual core
    ma come kernel hai usato quello suo...o altri ho visto che ci sono 2 tipi di kernel
  8. #3017
    lg p990 dual core
    questi sono i 2 kernel che 070512-0104-temasek.zip 2.55 MB 06.05.12 19:17:34
    070512-0104-Voodoo-temasek.zip 2.56 MB 06.05.12 19:17:35
    dicevo
  9. #3018
    Mar 2011
    Tivoli (RM)
    Il suo,il terminale è a default e va bene cosi,per me.
    testai,in passato,altri kernel ma non mi hanno soddisfatto,quindi,almeno per il momento,tengo il suo.
  10. Il seguente Utente ha ringraziato cajenna per il post:
    Napoletano80 (08-05-12)
  11. #3019
    lg p990 dual core
    ragazzi allora postate le prime impressioni della temasek 100!!!!
    Ultima modifica di Napoletano80; 08-05-12 alle 12:43
  12. #3020
    Venezia
    S4 & G3
    Se state utilizzando l'ultima di MisjudgedTwat's non occorre aggiornare alla temasek 100. Sono praticamente uguali.
    temasek 100
    - Statubar date fix
    Gerrit Code Review
    CHERRY-PICKS
    MisjudgedTwat's
    commits for statusbar restart:
    NEW - Add option to restart status bar to CMParts
    NEW - Improve functionality of status bar restart + cleanup
    commits for bootanimation changer:
    commits for status bar transparency, icon hiding, text color:
    - Statubar date fix
    - jerryscript changes to dateview colors
    - fix typo
    commits for notification background:
    - notification backdrop changer 2/2 by jerryscript
    CHERRY-PICKS
    NEW Ib2ff8fa5: Update hungarian translation.
    NEW I882cb6db: Update Telenor Online apn settings
    NEW I5e087e95: Update hungarian translation
    NEW I0ff2bff0: Update hungarian translation
    NEW I87169137: Update hungarian translation
    UPDATED I19cb79b8: Fix typo in queue_property_triggers ident
    MERGED If93f8199: Applying theming to more framework items.
    Ib44b5881: Restrict zygote to system user.
    Ultima modifica di redefined; 08-05-12 alle 13:19
LinkBacks (?)
