Pagina 303 di 597 primaprima ... 203253293301302303304305313353403 ... ultimoultimo
Visualizzazione dei risultati da 3,021 a 3,030 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #3021
    Androidiano L'avatar di Napoletano80
    lg p990 dual core
    Red grazie per la dritta perchè mi stava venendo voglia di provarla!! infatti ho ' ultima MisjudgedTwat's..quindi lascio tutto cosi!!...ti volevo fare una domanda ma la chuck norris 1.3 tu l hai provata?
    Quote Originariamente inviato da redefined Visualizza il messaggio
    Se state utilizzando l'ultima di MisjudgedTwat's non occorre che aggiornare alla temasek 100. Sono praticamente uguali.
    temasek 100
    CHANGELOG (Same for N1 RC1-92)
    PORTS FROM EXTERNAL SOURCE
    NEW - Forgot to change intent on bootanimation chooser
    NEW - Add preference to bootanimation chooser
    NEW - Add preference for bootanimation chooser
    NEW - CM Boot Animation Helper
    NEW - Add bootanimation changer to CMParts (1/2)
    NEW - Custom action on the double tap on the home key.
    NEW - Increase double-tap delay for home key extra activity launcher
    NEW - Add a green gps-fixed icon to status bar
    NEW - try color changes to cmbattery and cmsignal text
    - Improve functionality of status bar restart + cleanup
    - Add option to restart status bar to CMParts
    - fix notification background changes2
    - added jerryscript notification backdrop changer 1/3
    - Add ability to show/hide remaining system icons in status bar (1/2)
    - Add ability to show/hide remaining system icons in status bar (2/2)
    - Make status bar dateview use clock's color
    - dropdown menu fixes
    - Statusbar color change mod by jerryscript
    - notification backdrop changer by jerryscript 1/2
    - notification backdrop changer by jerryscript 2/2
    - center clock 2/2 by Jerryscript
    - Statubar date fix
    - Statusbar mods by jerryscript
    MERGED COMMITS UP TO
    Change I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
    Gerrit Code Review
    CHERRY-PICKS
    If you see any picking is missing from last build, it is because it was merged, abandoned, reverted by me or I've eaten it up.
    NEW - Change I90858354: Optimize T9Search performance / memory consumption
    MERGED - Change I3ccd8711: Safeguard against dumping large amounts of memory if SP is bogus.
    MisjudgedTwat's
    commits for statusbar restart:
    NEW - Add option to restart status bar to CMParts
    NEW - Improve functionality of status bar restart + cleanup
    commits for bootanimation changer:
    commits for status bar transparency, icon hiding, text color:
    - Statubar date fix
    - jerryscript changes to dateview colors
    - fix typo
    commits for notification background:
    - notification backdrop changer 2/2 by jerryscript
    CHERRY-PICKS
    NEW Ib2ff8fa5: Update hungarian translation.
    NEW I882cb6db: Update Telenor Online apn settings
    NEW I5e087e95: Update hungarian translation
    NEW I0ff2bff0: Update hungarian translation
    NEW I87169137: Update hungarian translation
    UPDATED I19cb79b8: Fix typo in queue_property_triggers ident
    MERGED If93f8199: Applying theming to more framework items.
    Ib44b5881: Restrict zygote to system user.
    Venezia
    S4 & G3
    Quote Originariamente inviato da Napoletano80 Visualizza il messaggio
    No, resto su aosp pura.
  4. #3023
    Androidiano VIP L'avatar di Andry96
    Terracina
    Samsung Galaxy SII
    Ringraziato 60 volte in 57 Posts
    Qual'è il kernel migliore?
  5. #3024
    lg p990 dual core
    Secondo me dopo averne provati vari..sono rimasto al kernel della keng. Che ho scaricato....quindi il suo originale.
    Inviato dal mio Optimus 2X usando Androidiani App
    lg p990 dual core
  6. #3025
    Quote Originariamente inviato da maw_erick Visualizza il messaggio
    Ciao Red e a tutti,
    oggi mi rivolgo a tutti perchè credo possa essere d'aiuto a tutti quello che mi accade.
    In pratica tempo fa mi rivolgevo a Red perchè il telefono con qualche Rom non aggiornata l'ora e non si collegava ai dati.
    Una cosa fastidiosa perchè mi portava a spegnere e riaccendere e certe volte a cambiare Rom e per ultimo a cambiare bb e ril.
    Smanettando, ho trovato in Titanium backup la funzione di pulizia della cache in manipola dati.
    Con questa funzione riesco subito a risolvere: si aggiorna subito l'ora e la connessione.
    Ma mi domando, perchè mi succede spesso e se si può ovviare in qualche modo.
    Max
    Ciao,
    scusate l'insistenza ma nessuno ha mai avuto questo problema e risolto definitivamente ?
  7. #3026
    Terracina
    Samsung Galaxy SII
    Ma sul kernel del 13, quindi quello che hai anche tu, si può fare l'undervolt ?
  8. #3027
    Rispondo io, perchè lo uso : si
    m.
  9. #3028
    Ra_
    Ra_ non è in linea
    ragazzi ho bisogno di una mano..devo preparare il dual per la mia ragazza e dopo aver avuto dei problemi con altre rom, avevo deciso di mettere la cyano... Ora ho visto che oltre alla kang è comparsa la MisjudgedTwat, quale è la migliore fra le due? La differenza tra pdroid e nodroid?
    Poi nello specifico cosa dovrei installare?
    Guardando l'OP:
    Baseband 725 (10d) file unico -
    Come installare una baseband -
    gapps-gb-20110828-signed -
    Patch inversione memorie -
    Widget Meteo - orologio LG -
    Last kernel vadonka -
    le mod cam a cosa servono?
    le ungapps cosa hanno di diverso dalle official?
    Il Tema ICS è un tema che va ad aggiungersi agli altri CM o diventa quello unico e principale (sostituisce quello di default)?
    Il telefono dovrebbe stare sempre con internet acceso avendo la tim young e avrebbe sempre whatsapp in esecuzione...quindi dovrei se possibile creare una combinazione molto conservativa e parsimoniosa di batteria...metterei il vodonka e non l'iron perché da come ho capito in giro lo preferite, anche se nel tread di xda l'autore della MisjudgedTwat consiglia l'iron.
    L'importante comunque è che duri un giorno
    Aspetto vostre risposte...
  10. #3029
    Terracina
    Samsung Galaxy SII
    m.
    E come? mi diresti i passaggi?
  11. #3030
    Venezia
    S4 & G3
    Quote Originariamente inviato da Andry96 Visualizza il messaggio
    installi pimp my cpu pimpmycpu-4.1.apk
    fai partire l'app e selezioni l'icona +
    setting > tocchi i voltaggi per ogni Frequenza e decidi i set
    Prima di impostare "boot" testa il terminale.
LinkBacks (?)
