Pagina 458 di 597 primaprima ... 358408448456457458459460468508558 ... ultimoultimo
Visualizzazione dei risultati da 4,571 a 4,580 su 5967
[ROM] KANG over CyanogenMod 204 and CM10(Optimus Dual)
  1. #4571
    Venezia
    S4 & G3
    Quote Originariamente inviato da salvatopo Visualizza il messaggio
    Già...
    trovate il nuovo link per youtube hd al post 4559
    Venezia
    S4 & G3
    MisjudgedTwat's ha pubblicato l'aggio della sua rom arrivata alla versione 38
    http://dl.bangl.de/android/cm7%20p99...0-nopdroid.zip
    http://dl.bangl.de/android/cm7%20p99...990-pdroid.zip
    CURRENT STATUS
    VERSION
    38
    LAST CHECK
    2012-09-08 11:51 AM
    MERGED UP TO
    Iec2008a9 Fix duplicate resource.
    CHERRY PICKS
    I462a6943: Fix endless loop of mediascanner with some MPEG files.
    I3f0849f1: Include nickname and organization in T9 search.
    I4f214a26: Update Buildbot Url
    I246bac73: Browser: Update search engines
    Id5b4f450: Disable AM/PM style selection menu while 24-hour clock is selected
    I2ca1ed62: adding missing cdma make file and APNs
    I52d9c174: Customizable kill app via back key timeout
    Idfe31503: Port "Strip Unicode" feature from ICS branch into GB
    Ic8f584f0: Security fix for CVE-2011-3874
    I2ab5d81d: Bluetooth Toggle on Lock Screen with gestures (CMParts)
    I2235a77b: Bluetooth Toggle on Lock Screen with gestures (framework)
    Ief2f83d3: add speex support in sip service.
    I5280176d: add speex encoder,decoder support
    I5f0a90d3: Added ability to ignore unsupported Exchange policy (2 of 3; Email) - Issue 3172
    I1476b835: Added ability to ignore unsupported Exchange policy (3 of 3; CMParts) - Issue 3172
    Ifadd08ae: Added ability to ignore unsupported Exchange policy (1 of 3; framework) - Issue 3172
    Id1588e05: LatinIME: Option to reverse volume key logic on cursor control
    Idc791cc5: CMParts: Dutch translations
    If8656cf3: Added SMS Service Support using AT Commands, PDU mode, removed debugging msgs
    I785a960f: Added SMS Service Support using AT Commands, PDU mode
    I89c12856: Added SMS Service Support using AT Commands, PDU mode, Phone app to be able to send SMS
    Ia73d5349: libaudio-msm7x30: update msm/aic3254 routing sequence
    Iac551d95: Added possibility to change the style of lock pattern screen (2/2) [Patch Set 6]
    I6d37a6ab: Update German translation.
    Id0a55976: Remove obsolete translations that cause build warnings.
  4. #4573
    Quote Originariamente inviato da redefined Visualizza il messaggio
    CURRENT STATUS
    VERSION
    38
    LAST CHECK
    2012-09-08 11:51 AM
    MERGED UP TO
    CHERRY PICKS
    Oggi aggiorno e poi aspetto sto benedetto ( o maledetto) ICS che spero ci data la possibilità di avere ottime KANG e Cm10.
  5. #4574
    Puglia
    Ringraziato 30 volte in 25 Posts
    Alla fine dell'installazione mi dice "applicazione non installata".
    Edit: dopo aver disinstallato youtube sono riuscito a installarla, ma non si avvia e esce con un errore: Interruzione imprevista dell'applicazione YouTube, processo com.google.android.youtube...
    Ultima modifica di salvatopo; 10-09-12 alle 12:04
    Ho un Samsung Galaxy S3 LTE (GT-I9305) e da un po' un bel Galaxy S7 Flat (GT-930F)
    E se ti sono stato di aiuto in qualcosa, regalami un pizzico di soddisfazione con un thanks.
  6. #4575
    Venezia
    S4 & G3
    Non so cosa dirti. Questa sera faccio upload della mia (ne ho copia su sd) e posto il link.
  7. #4576
    Puglia
    Ok, così la provo, grazie.
  8. #4577
    Venezia
    S4 & G3
    ecco il link YT_v2.5.16_WiFi_HD.apk youtube hd
  9. Il seguente Utente ha ringraziato redefined per il post:
    salvatopo (11-09-12)
  10. #4578
    Puglia
    Installato... ma che differenza c'è con quello del market?
  11. #4579
    Senior Droid L'avatar di vismo
    LG G3
    Ringraziato 166 volte in 146 Posts
    La differenza è che ti fa vedere i video in hd... Mentre quello del market li ridimensiona alla risoluzione dello schermo :thumbup:
    Inviato dal mio Optimus 2X
  12. #4580
    Puglia
    Quote Originariamente inviato da vismo Visualizza il messaggio
    :o ma è fichissimo!!!
    Provo immediatamente, sperando che FastwebMobile mi conceda banda.
LinkBacks (?)
