Pagina 54 di 79 primaprima ... 444525354555664 ... ultimoultimo
Visualizzazione dei risultati da 531 a 540 su 790
[ROM][FinTaDr0iD v 2.6.1][FULL ROOT & EXT4] [BT & 3G][FW.1.0.21 PRESTIGIO]
  1. #531
    Quote Originariamente inviato da goito69 Visualizza il messaggio
    Hi Finte!
    I've found the problem: the microSD is faulty.
    Whe I take off the kepler flys!!
    I've formatted it but I don't know if the problem will be appears again (is a 16GB..... )
    I'm gonna install the "FIXED2" again and see..
    Thaks for all!!
    Goito.
    Quote Originariamente inviato da fintematic Visualizza il messaggio
    Ah okok
    Keep me informed
    OK, "FIXED2" installed and working perfectly (I like much more this battery icon :-) )
    When the problems appears I saw in the satus bar one icon and message that alert me: something about "multimedia contents updating" and no dissapear. I though the pad was searching in the microSD, and taking off the microSD will no search on it. And yes! That was the problem.
    I put the microSD in the PC and tryed to copy all the files, and again apears the reading errors.
    All the problem was the corrupted microSD. Most od my files lost!!!
    Now, I've inserted the same microSD, formatted in the PC and empty. I don't know id the problem come back...
    I hope this can help somebody.
    Thanks a lot, King Finte!
    Goito.
    Me again with another problem....
    I have a USB wireless keyboard. I'm not sure if I tryed the keyboard in your 2.6 version, but sure in the kepler with other firms worked witout problems.
    Now, with your 2.6.2 it works, yes, but the microSD is automatically dismounted
    I dont know how to remount the microSD, then I've powered off the device and power on again.
    If I power ON the tablet with the keyboard conected there isn't any problem, only if the tablet is ON and connect the keyboard.
    And if I disconnect the keyboard the microSD is disconnected too.
    I've try with another device, one microSD USB reader, and no problem...
    For me is not very important becasue only connect the keyboard ocasionally... but this can be util for others...
    Bye!
    Goito.
    Ultima modifica di goito69; 04-01-12 alle 19:42
  4. #533
    Androidiano L'avatar di D@nx
    Dietro di te
    SAdvance Xperia E G2 Galaxy Y
    la mia chiavetta usb non funzionaaaaa!!!!! che faccio????
  5. #534
    Quote Originariamente inviato da croccio Visualizza il messaggio
    rimuovi prima la penna e poi il cavo dal tab e vedi che nn si riavvia
    Fatto! anzi per scrupolo anche in questo momento....il tab si riavvia e poi ogni app mi da processo .com. android...etc etc...devo solo spegnerlo...
    anzi ti aggiungo, se rimuovo prima il pen drive si riavvia e si blocca sul boot di finta... se rimuovo il cavo completo si riavvia ma poi devo spegnerlo altrimenti non funziona nulla...
  6. #535
    Genova
    Omnia2, Samsung N7000, N7100
    Ringraziato 136 volte in 113 Posts
    Mah se rimuovi la penna e non tocchi il cavo... non dovrebbe riavviarsi, hai la segnalazione di USBMassStorage Unexpectedly remoded, ma dovrebbe continuare a funzionare. Non solo se poi reinserisci la Penna USB viene riletta correttamente.
    Il problema del riavvio c'è se 'strappi' tutto insieme.
    Ciao
    PS. c'è se eri con un'applicazione attiva sul Pen Drive. Per esempio se con Explorer ti sposti dalla USB sulla memoria interna, per es., poi stacchi, da la segnalazione ma non si riavvia. Probabilmente, il comportamento al distacco, dipende anche da quale applicazione avevi usato sui dati della penna : musica, video o che altro, che probabilmente, ancora attiva, fa reagire il tablet in malo modo. Prova a forzare la chiusura (termina) di ciò che hai usato e poi scollega.
    Quote Originariamente inviato da slev Visualizza il messaggio
    Ultima modifica di otticus; 04-01-12 alle 22:13
  7. #536
    Genova
    Hi Goito69, i have tested with my usb wireless keyboard and ... same problem: microSD is dismounted. My Tablet is the 4GB original 810c... If you need the keyboard ('on the go' mode), choose other recent 'custom' fw in this forum (list here: https://www.androidiani.com/forum/me...tpad-810c.html) and verify.
    Ciao
    PS. I confirm: 'if the tablet is powered on with the keyboard connected' ... that is OK
    Bye!
    Goito.
    Ultima modifica di otticus; 04-01-12 alle 22:51
  8. #537
    Androidiano VIP L'avatar di fintematic
    Sicilia
    Xperia Play - Toshiba Folio100
    Ringraziato 735 volte in 316 Posts
    Quote Originariamente inviato da Lady70 Visualizza il messaggio
    Ed ecco che arriva la rompiscatole!!! me lo dico da sola così mi levo il pensiero, oltre a sapere di essere OT .
    Scusate ma per me questa sezione ( non questo post) è ormai diventata illeggibile che tradotto è un gran casino, mi devo leggere richieste di come crakko il router altrui? e decine di volte le medesime domande a cui ormai nemmeno rispondo più.
    Non è assolutamente moderata e basta vedere cosa postano quindi perchè non aggiungere moderatore di questa sezione ad esempio Fintematic che è perlopiù presente????? e che ha aiutato e lavorato tanto per questo tablet? Ho detto lui magari anche affiancato da un'altro cuoco che sia presente.
    Perchè queste discussioni dove si scaricano e discutono le rom non si mettono in evidenza? così si trovano al volo e non scendono.
    Mi scappava e l'ho detta l'ho fatto con la buona intenzione di tenere in ordine uno spazio che ha dato tantissimo al nostro tablet portandolo a un livello nettamente superiore e sarei lieta se questo potesse continuare.
    Ora mandatemici pure
    Ciao Lady
    non rompi le scatole a nessuno anzi hai proprio ragione
    Già Moss ti ha risposto.. (volevo chiedere anch'io ma visto che già lui aveva fatto richiesta, ne basta uno )
    Per il fatto delle rom. Ho creato una discussione chiamata RACCOLTA ROM SMARTPAD 810C.. Ci sono tutte le rom
    Ciao
    Finte
  9. #538
    Sicilia
    Quote Originariamente inviato da bussolotto69 Visualizza il messaggio
    uongiorno a tutti.
    Ieri ho caricato la rom di Finte e il tablet è cambiato :o !! grazie 1000 al nostro cuoco.
    Avrei delle domande/curiosità da sottoporre:
    1) se durante l'uso dell'app "wireless file transfer pro" il dispositivo va in stand-by, anche con trafsrimento file attivo la connessione wireless si spegne; succede anche a voi ??
    2) se collego una chiavetta USB, poi come la scollego a dispositivo acceso ??
    3) ho installato delle app e successivamente le ho spostate su SD; al riavvio le icone delle app spostate, sulla home non ci sono + o meglio sono state sostituite dal logo di android (omino verde) senza nessun nome, perchè?
    Grazie a tutti anticipatamente e scusate per la lunghezza del post.
    Saluti
    Giuseppe
    Ciao Bussolotto
    1) Si è normale, scarica wifi lock free e non lo avrai piu questo problema.. come ha detto Otticus è saputo e risaputo che in questo tab ha questo effetto..
    2)Si.. però prima devi chiudere quello che avevi aperto quindi che è ancora in funzione nella pen drive senno si spegne..
    3)Non lo so perché non mi è mai successo...
    Ciao
    Finte
  10. #539
    Genova
    Ciao Finte hai preso qualche ora di vacanza, o stavi cucinando qualche novità? Sai è un pò tanto che non ci fai dei doni, potremmo cambiare sezione...
    Il punto 3) di Bussolotto sembra un problema legato alla mancata lettura della microsd ...
    C'è il problema dell'ospite spagnolo sulla tastiera, che è anche il mio anche se mi sembra un problema minore, visto che se la connetti all'accensione va.
    Ciao Bussolotto
    Ciao
    Finte
    Ultima modifica di otticus; 04-01-12 alle 23:12
  11. #540
    Sicilia
    Quote Originariamente inviato da otticus Visualizza il messaggio
    Ciao Otti,
    qualche minuto di vacanza lavoro xD
    comunque per il punto 3 il problema è che quando sposti le app su sd devi aggiornare il launcher.. (ci ho pensato ora ora) anche questo problema saputo e risaputo
LinkBacks (?)
  1. 05-03-12, 23:11
  2. 29-02-12, 15:36
  3. 17-02-12, 22:22
  4. 10-02-12, 10:18
  5. 29-01-12, 13:04
  6. 13-01-12, 15:23
  7. 10-01-12, 19:14
  8. 07-01-12, 22:46
  9. 07-01-12, 00:20
  10. 04-01-12, 16:48
  11. 04-01-12, 15:41
  12. 04-01-12, 13:49
  13. 03-01-12, 20:42
  14. 03-01-12, 16:30
  15. 03-01-12, 15:41
  16. 03-01-12, 14:15
  17. 02-01-12, 18:13
  18. 01-01-12, 08:52
  19. 28-12-11, 22:47
  20. 28-12-11, 17:09
  21. 28-12-11, 15:45
  22. 28-12-11, 14:43
