Pagina 60 di 857 primaprima ... 1050585960616270110160560 ... ultimoultimo
Visualizzazione dei risultati da 591 a 600 su 8561
[SOS] PRONTO SOCCORSO MODDING - Aiuti, dubbi, consigli (Galaxy Note N7000)
  1. #591
    Nel mondo
    SG-N7000 e SM-N9005
    Quote Originariamente inviato da Andromeda1968 Visualizza il messaggio
    control + alt + canc......... avvia gestione attivita' ............... kiesdplr & keystrayagent
    Questo è ciò che mi viene fuori dall'ultima e definitiva prova, più di questo non so cosa fare, bandiera bianca!!!!!
    Initial CF-Root flasher, by Chainfire
    Credits:
    Easy rooting toolkit by DooMLoRD
    zergRush by Revolutionary Team
    Gingerbreak/Honeybomb by The Android Exploid Crew
    ---------------------------------------------------------------[*] This script will:
    (1) root ur device using zergRush exploit
    (2) flash CF-Root[*] Before u begin:
    (1) make sure u have installed adb drivers for ur device
    (2) enable "USB DEBUGGING"
    from (Menu\Settings\Applications\Development)
    (3) enable "UNKNOWN SOURCES"
    from (Menu\Settings\Applications)
    (4) [OPTIONAL] increase screen timeout to 10 minutes
    (5) connect USB cable to PHONE and then connect to PC
    (6) skip "PC Companion Software" prompt on device
    (7) !!! PUT A CF-ROOT zImage FILE IN THE zImage FOLDER !!!
    CONFIRM ALL THE ABOVE THEN
    Premere un tasto per continuare . . .
    --- STARTING ----
    --- WAITING FOR DEVICE
    --- cleaning
    --- pushing zergRush"
    721 KB/s (23052 bytes in 0.031s)
    --- correcting permissions
    --- executing zergRush
    [**] Zerg rush - Android 2.2/2.3 local root
    [**] (C) 2011 Revolutionary. All rights reserved.
    [**] Parts of code from Gingerbreak, (C) 2010-2011 The Android Exploid Crew.
    [+] Found a GingerBread ! 0x0002e118
    [+] Found a Samsung, running Samsung mode[*] Scooting ...[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 149 zerglings ...
    [+] Zerglings found a way to enter ! 0x10
    [+] Overseer found a path ! 0x0002e118[*] Sleeping a bit (~40s)...[*] Waking ![*] Sending 149 zerglings ...
    [-] Zerglings did not leave interesting stuff
    --- WAITING FOR DEVICE TO RECONNECT
    if it gets stuck over here for a long time then try:
    disconnect usb cable and reconnect it
    toggle "USB DEBUGGING" (first disable it then enable it)
    --- DEVICE FOUND
    We should have (temporary) root now
    We will try to flash CF-Root kernel now
    Please watch for any errors beyond this point!
    --- pushing zImage
    cannot stat 'zImage\zImage': No such file or directory
    --- flashing zImage
    /data/local/zImage: cannot open for read: No such file or directory
    --- cleaning up
    rm failed for /data/local/zImage, No such file or directory
    --- rebooting
    If all is well, CF-Root should be flashed
    Your device should be rebooting now
    Please check if you have root and CWM after boot completes!
    Può esere che qualche app. del GN mi blocca il processo, o forse prima di iniziare devo premere i tasti ACCENSIONE HOM E VOLUME SU??
    p.s. adesso sto facendo le prove dal mio portatile SONY VAIO
    Ultima modifica di CH3CH2OH; 16-05-12 alle 17:03
    Senior Droid L'avatar di SUPERGALAXYNOTE
    MODENA
    MI 9
    Ringraziato 116 volte in 101 Posts
    Ok o risolto o smanettato un po
  4. #593
    MODENA
    MI 9
    ciao andromeda o installato ics tutto perfetto o anche il root (verificato) kies mi rileva tranquillamente il firmwere l unica cosa mi dice che il dispositivo non supporta l aggiornamento firmwere via kies e normale? pensi che avro problemi a installare eventuali aggiornamenti ufficiali? grazie di tutto
  5. #594
    Riserva Navajo
    Quote Originariamente inviato da SUPERGALAXYNOTE Visualizza il messaggio
    no è normale lascia perdere kies
  6. Il seguente Utente ha ringraziato Andromeda1968 per il post:
    SUPERGALAXYNOTE (16-05-12)
  7. #595
    MODENA
    MI 9
    sei grande io di pc ne capisco parecchio ma con i tel e la prima volta e grazie a te e andato tutto ok e adesso mi godro un po questo ics
    a presto
  8. #596
    Riserva Navajo
    a presto
  9. #597
    Ri-flashato ICS ma il problema del blocco schermo persiste...che altro mi consigli??
  10. #598
    Riserva Navajo
    Quote Originariamente inviato da tomoji Visualizza il messaggio
    io non ho problemi con il blocco schermo hai provato altre opzioni di blocco schermo? metti il blocco come live wallpaper...e fai un test
  11. #599
    sisi ho provato un infinità di modi...potrebbe essere causato da samsung studio 5 che quando collegavo il dispositivo si attaccava?
  12. #600
    Riserva Navajo
    prova..cancella un po' di apk che ti sembrano a "rischio"
