Pagina 18 di 28 primaprima ... 81617181920 ... ultimoultimo
Visualizzazione dei risultati da 171 a 180 su 280
[Kernel][Roms][STOCK/CM9/CM10][Aroma]Dual Boot 5Roms G-Note GT-N7000
  1. #171
    ragazzi a me dopo che finisce di montare la partizione esce il seguente errore, (ext4,emmc, /dev/block/mmcblk 010/data), sapete aiutarmi??? please!!!
    Quote Originariamente inviato da gaex100
    vi riporto l errore:
    Extract: /tmp/bin/busybox
    Extract: /tmp/bin/dd
    Extract: /tmp/bin/mount_partitions
    Extract: /tmp/bin/umount_partitions
    about to run program [/tmp/bin/busybox] with 3 args
    about to run program [/tmp/bin/busybox] with 8 args
    Config Rom1 Internal SDCard....
    Copy system partition to SDCard. Please wait...
    about to run program [/tmp/bin/dd] with 3 args
    1744896+0 records in
    1744896+0 records out
    893386752 bytes (852.0MB) copied, 103.518830 seconds, 8.2MB/s
    Copy data partition to SDCard.Please wait...
    mkdir: cannot create directory '/tmp/sdcard/SDRoms/rom1': File exists
    run_program: child exited with status 1
    4194304+0 records in
    4194303+1 records out
    2147483647 bytes (2.0GB) copied, 284.931733 seconds, 7.2MB/s
    Copy cache partition to SDCard...
    409600+0 records in
    409600+0 records out
    209715200 bytes (200.0MB) copied, 24.385795 seconds, 8.2MB/s
    Mounting partitions for the selected rom on SDCard....
    If you see any error, do not flash any rom or mod. It may mess up your phone rom.
    unmount of /system failed; no such volume
    unmount of /data failed; no such volume
    about to run program [/tmp/bin/busybox] with 4 args
    losetup: /dev/block/mmcblk0p9: Invalid argument
    about to run program [/tmp/bin/busybox] with 5 args
    losetup: /dev/block/mmcblk0p10: Invalid argument
    losetup: /dev/block/loop3: No such device or address
    mount: failed to mount /dev/block/mmcblk0p10 at /data: Invalid argument
    script aborted: assert failed: mount("ext4", "EMMC", "/dev/block/mmcblk0p10", "/data")
    Installer Error (Status 7)
  4. #173
    Senior Droid L'avatar di darboc
    Ringraziato 131 volte in 93 Posts
    Quote Originariamente inviato da cic1 Visualizza il messaggio
    QUASI PRONTA LA GUIDA!!!
    Mancano alcune piccole cose poi la pubblico.
    Visto che alcuni di voi sono ormai più esperti e attenti di me sull'argomento (tipo darboc ma non solo), se volete ve la giro in pvt in formato editabile, se volete aggiungere o modificare qualcosa.
    E speriamo di attirare nuovi adepti!
    Inviato dal mio GT-N7000 usando Tapatalk
    Ma certo cic a disposizione se posso dare una mano
    Ciauz
  5. #174
    Quote Originariamente inviato da darboc Visualizza il messaggio
    Ciauz
    Vuoi provare la mia rom?
    Se vuoi ti dò il link
  6. #175
    Samsung Galaxy Note GT-N7000
    Piacerebbe anche a me provare una nuova rom. Ormai quelle presenti sul forum me le sono passate tutte... se fosse possibile...
  7. #176
    Androidiano L'avatar di cic1
    Jan 2011
    OnePlus One
    Come no! Posta il link... magari fai l'immagine da montare direttamente su chuan!
    OPO 64Gb
    [Rom]CYANOGENMOD12- Nightly
  8. #177
    Jan 2011
    OnePlus One
    Quote Originariamente inviato da gaex100 Visualizza il messaggio
    Direi che non riesce a montare la partizione /data...
    È una ROM su SD?
    Come l'hai creata quella partizione?
    A volte copiandola da telefono si corrompe...
    Ti conviene provare a ricrearla
    OPO 64Gb
  9. #178
    È una ROM su SD?
    o fatto come da guida sono andato in tools copio sistem data e canche e dopo k finisce di montare esce questo errore... da premettere che la prima volta era andato tutto a buon fine solo che non mi piaceva la rom installata
    e quindi o ripristinato il nandroid backup e ieri quando ho riprovato usciva questo errore... ho provato anche diverde volte.
  10. #179
    Ragazzi una domanda a voi di solito quanto tempo impiega il primo avvio di una rom su sd? Io ogni volta devo starci dai 10 ai 20 minuti dietro la prima volta...
  11. #180
    Androidiano L'avatar di mflash
    Quote Originariamente inviato da manu.leo Visualizza il messaggio
    Troppo...a me pochi minuti ...a spanne meno di 5
