Pagina 171 di 242 primaprima ... 71121161169170171172173181221 ... ultimoultimo
Visualizzazione dei risultati da 1,701 a 1,710 su 2417
[ROM] - UltimaROM - Sammy based [AROMA]
  1. #1701
    Androidiano VIP L'avatar di terzo33
    Palermo
    Galaxy S4
    Ringraziato 342 volte in 227 Posts
    Sì dovrebbe uscire oggi...
    Edit :
    The upload completed successfully on my server last night. I'm now just going to spread it across the others and places like deposit files, xdafileserver and romhut
    Ultima modifica di terzo33; 22-03-13 alle 15:17
    DEVICE: Samsung Galaxy S4 16GB White Frost
    ROM: BoBCaTROM v.13
    KERNEL: Jeboo
    MODEM: Stock MJ7
    OPERATORE: Vodafone
    EXT MEMORY: Samsung MicroSDHC 32gb Classe 10 UHS-I
    Androidiano VIP L'avatar di TopoMonko
    Romagna
    Note 4 - G4
    Ringraziato 593 volte in 437 Posts
    Zitto Zitto io la sto gia scaricando
    Forza ragazzi è onlineeeeeeee
    Things to note:
    In the Advanced Settings there are checkboxes for Extended Power Menu and Long Menu Kill - They do NOTHING right now, but will in the future.
    CRT and volume 2 skip are missing from the installer. They are now toggle options in advanced settings
    There are more lockscreen options in the advanced settings. Some have vibration on them. I will work out how to disable them later
    Torch on Lockscreen is Didact74's implementaiton. You hold the home button to turn it on, and as long as you're on the lockscreen it will stay on. If you unlock, or the screen goes off, so does the torch. Be mindful of this when using it... you will need to keep the screen awake. This is also a toggle in Lockscreen Settings
    You WILL NOT be able to restore a backup of contracts from XXEMR2 or UltimaROM 10.1. Samsung changed the database structure between XXEMB2 - > XXEMR2 -> XXEMB5 and it WILL force close on you. However, coming from XXEMB2 -> XXEMB5 will be fine.
    That's about all I can think of. Enjoy!
    Consider, once you have installed and chosen your selected mods, battery icons and so on, odexing your ROM.
    Read the instructions carefully.
    Ultima modifica di TopoMonko; 22-03-13 alle 16:01
    HTC One - Black Pearl 32GB
    Se ti sono stato d'aiuto Ringraziami con il tasto "Thanks"
  4. #1703
    Palermo
    Galaxy S4
    Siiiiiiiiiii... scatenate l'inferno!!!!
    ROM: BoBCaTROM v.13
    KERNEL: Jeboo
    MODEM: Stock MJ7
    OPERATORE: Vodafone
  5. #1704
    Androidiano L'avatar di ciccius
    Galaxy S3,Htc Desire S
    Ringraziato 34 volte in 32 Posts
    Anche io in download
  6. #1705
    Palermo
    Galaxy S4
    TopoMonko peccato per le prime due funzioni che erano molto utili...
    ROM: BoBCaTROM v.13
    KERNEL: Jeboo
    MODEM: Stock MJ7
    OPERATORE: Vodafone
  7. #1706
    Quote Originariamente inviato da terzo33 Visualizza il messaggio
    Pare che le implementerá in futuro quindi basta avere un poco di pazienza
  8. #1707
    Romagna
    Note 4 - G4
    Eh sinceramente non ho capito cosa intenda.. sarebbe da provarlo.. ancora non sono riuscito a scaricare la rom :banghead: mi si interrompe sempre il download!
    Comunque a mio avviso son o state inserite ottime mod come la torcia in lockscreen, la possibilita di scegliere se volere o no il crt dalle impostazioni e altre..
    Inoltre c'e da valutare l'opzione di odexare o no la rom!
  9. #1708
    Palermo
    Galaxy S4
    Anche io non riesco a scaricarla. ... TopoMonko che significa odexare la rom?
    ROM: BoBCaTROM v.13
    KERNEL: Jeboo
    MODEM: Stock MJ7
    OPERATORE: Vodafone
  10. #1709
    Se può interessare io sto scaricando da Deposit file a 140k,purtroppo xda server e rom hunt vanno lentissimi per quanti download ci sono
  11. #1710
    Romagna
    Note 4 - G4
    L'han spiegato quakche post fa..
    Kryten dice che porta benefici per quanto riguarda la batteria e la fluidita.. solo che poi se vuoi installare altre mod ti tocca deodexarla di nuovo..
    Per cui se sei uno comunque che una volta configurata la rom e sistemato tutto non ha intenzione di smanettarci ogni giorno ti consiglia di odexarla!
    Quote Originariamente inviato da ciccius Visualizza il messaggio
    A me da romhut va anche a 250 solo che poi dal nulla si blocca......
