Pagina 17 di 233 primaprima ... 715161718192767117 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #161
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    Build V43
    md5sum: 60ea427c66f165a9a94d0907c138e4ef
    With the latest drama with regards to CyanogenMod Inc, I'm staying neutral. I won't be commenting on whats current and future means for unofficial builds on cm. If its going to be positive, good but if its the end of unofficial builds, so be it. Open source will still prevail.
    Also note on my last couple of posts that I'm removing CellBroadcastReceiver and true enough, with effect from builds after V38, this feature has been removed. You are reminded to flash the CellBroadcastReceiver.zip ONCE (available in my misc folders) in order for user to continue enjoy this feature. Future updates, you are not required to flash this zip anymore.
    Changelog
    Active Display by ChameleonOS. Bear in mind this cannot be used with HALO. So either this or HALO, not both as both are related to notifications. That was my initial test results but maybe I'm wrong.
    Option to change number of columns in QS. I'm not able to pick from SlimROM the whole commit as like crDroid (with colors) as it breaks my tilapia device. I am trying to grab logcats from my tilapia but atm something is wrong with tilapia logs (its EMPTY) so till I am able to resolve this, there won't be something similar.
    Lock Screen - Option to hide initial page hints
    Frameworks - Use boost hints on dexopt
    Android 4.3_r3.1 - JLS36G
    Updated cm source, major commits includes,
    - [COLOR="#FF00
    00"]PhoneWindowManager: Hardware key handling fixes and cleanup[/COLOR]
    - PhoneWindowManager: Delay setting updates during window animation
    - Freeze screen while changing expanded desktop mode
    - Fix up 'launch player on headset connection' option
    -. etc...many other commits....
    Sep 2010
    TEMASEK's CM 10.2 V44
    cm-10.2-20130923-UNOFFICIAL-i9300-V44.zip
    md5sum: c2dca929aafa8f3017d6135c6df2084f
    FIXED - Data connection no longer breaks during calls.
    FIXED - Notification Rows Transparency as reported by @JustArchi's users. It was broke during the recent porting of features and classified as port derp merge.
    Active display: Add sunlight mode - ChameleonOS
    Frameworks - Delay hiding systemui by 100ms - ChameleonOS
    - When disabling the keyguard, the systemui visibility is changed and can occur after we hide it so delaying this a bit resolves that issue.
    Add Focal by xplodwild - This is built from source.
    Updated cm source
  4. #163
    Androidiano L'avatar di crazyniko
    Ardea (RM)
    Oneplus One & Galaxy S5
    Quote Originariamente inviato da almaximo Visualizza il messaggio
    Updated cm source
    Scusa se magari la domanda è un po così ma mi è venuto questo dubbio : se flasho questa ROM Temasek v44 ha già il kernel incluso o devo flasharlo a parte? Grazie mille
    Oneplus one 64 gb sandstone black
    CyanogenMod 12.1-20150701-Nightly - recovery TWRP 2.8.6.1
    Kernel AK.270
  5. #164
    Sep 2010
    Quote Originariamente inviato da crazyniko Visualizza il messaggio
    La ROM è una CM e come tale deve essere rilasciata con Kernel CM (by Temasek)
    se vuoi i kernel Temasek aggiornati devi rifleshare il kernel dopo aver aggiornato la ROM
  6. Il seguente Utente ha ringraziato almaximo per il post:
    crazyniko (23-09-13)
  7. #165
    Sep 2010
    vi lascio un modem che avevo provato prima delle ferie e che adesso ho flashato nuovamente
    XXUFME7
    con Wind da ottimi risultati e sembra che si trovi davvero a suo agio con il RIL open source delle CM (ottimo segnale, ottimi dati e ottimi consumi)
    veniva da una delle tante rom originali samsung in versione leaked da un operatore israeliano
    è la versione da flashare da recovery, solo modem, generico
    se qualcuno ha voglia di testarlo anche con altri operatori e di lasciare le impressioni per tutti
    https://mega.co.nz/#!FI1kkTLT!KfCs7E...o4w-2i0HdgwgDI
  8. Il seguente Utente ha ringraziato almaximo per il post:
  9. #166
    Sep 2010
    Build V45
    md5sum: 5ea8cc6b715d284ddfe8ef61411f53f9
    Add temasek bootanimation - CREDIT: @PartimusPrime & @noobSU
    Revert "Active Display"
    Revert "base: App crash when select suggestion's length more than specified."
    - This possibly causes some FC issues in messaging & hangouts, etc.
    FIXED - Quick Peek no longer resizes its screen to peek status bar. - @Cristiano Matos
    Removed Focal from in-source building. Pls support xplodwild's Focal via Play Store and recommended to grab his donate version.
    Updated cm source
  10. Il seguente Utente ha ringraziato almaximo per il post:
    Locaa92 (24-09-13)
  11. #167
    Sep 2010
    Build V46
    md5sum: db6c81b7a0a4e1de57ed86b63482482a
    Re-introduce Active Display by ChameleonOS
    - Several fixes since last drop of this feature
    - Now the sensor will turned off when the feature is disabled. Sensor will be back on when its enabled.
    Privacy Guard by cm - Revamped to using app ops. But this revamp lacks flexibility so the current "App Ops" feature stays for now.
    Add TRDS 2.0 Mms
    Updated cm source
  12. #168
    Androidiano L'avatar di andrea909
    Monto la v43 di questa ROM. Mi sapete dire perche il sensore di prossimità è sempre acceso? C'è qualche settaggio per aggiustare questa cosa?
  13. #169
    Sep 2010
    Quote Originariamente inviato da andrea909 Visualizza il messaggio
    Aggiorna all'ultima versione e va a posto
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  14. Il seguente Utente ha ringraziato almaximo per il post:
    andrea909 (27-09-13)
  15. #170
    Cosa sarebbe active display che è stato reintrodotto nell'ultima versione?
    Ultima modifica di andrea909; 27-09-13 alle 02:00
