Pagina 67 di 233 primaprima ... 1757656667686977117167 ... ultimoultimo
Visualizzazione dei risultati da 661 a 670 su 2323
[ROM][CM11][4.4.2]temasek's UNOFFICIAL all build r3p2MALI(I9300)
  1. #661
    Androidiano L'avatar di maxjaki
    A me questa v3 sta mangiando la batteria !!!
    Androidiano VIP L'avatar di Volpe92
    Venezia
    S3, S6 edge 64gb, note 3
    Ringraziato 172 volte in 139 Posts
    Quote Originariamente inviato da maxjaki Visualizza il messaggio
    Anche io ho avuto questa impressione... Ho visto anche una carica lenta...
  4. #663
    Androidiano VIP L'avatar di almaximo
    Sep 2010
    Mate 10 PRO / Samsung S8
    Ringraziato 234 volte in 191 Posts
    Build V4
    md5sum: 7410e978764e667e827e065fcbe8061b
    From this build onwards, you are NO LONGER required to use only latest official CWM. You can use the recovery of your choice
    CHANGELOG FOR V4
    • Added "MediaScanner behavior on boot"
      - Temasek spare parts -> General Settings
    • Updated - "Add lockscreen ring battery setting"
      - moved to Lockscreen Settings
    • Reverted - "Lockscreen: Add timeout and instant lock option to slide lock"
      - not working well
    • Statusbar reflect am/pm based on the global user settings 12h/24h format - SlimROM
    • Fetch navbar color from systemUI - SlimROM
    • Updated - Quick settings / Ribbons (Patchset 9)
    • Added "Lockscreen - Customizable shortcuts"
    • fb: global menu follow new 4.4 UI - SlimROM
      - the sound indicator is still ICS blue...change it to white In general we should consider to change all tab_selected files into a Holo.Light switch due it is already defined in styles.xml
    • fb: change alert dialog to new 4.4 UI - SlimROM
      - and add Holo / Holo.Light switch to reflect it proper on the different app styles
    • fb: do not call every time settings on clock intents - SlimROM
      - only needed for configuration change
    • fb: fix rounding issues and take density into account - SlimROM
      - we are a multiDpi rom...and on 4.2 and 4.3 already the text in the circle battery icon was on lower dpi a small bit up. The original author compensated this with just a +1 to the Y value. Thats not the right way...calculate the current dpi into the offset and all is well.
      - We want a perfect 4.4...so this nitpicks even if we are talking about 0.5dp maybe should be fixed.
    • fb: Follow new 4.4 transition on Network Stats - @Cristiano Matos
    • fb: Fix in glowpad disapearing targets when longpressed - @Cristiano Matos
    • fb: Set persist.sys.dalvik.vm.lib at system server startup - SlimROM
      - Bug: 11463182
    • fb: Move set of persist.sys.dalvik.vm.lib to SystemServer only
      - Bug: 11463182
      - Bug: 11479647
    • fb: Improve scrolling cache - Pawit Pornkitprasan
      - Scrolling cache helps make short scrolls/flings smooth but will cause stutter when long flings are made. This patch disables scrolling cache when long flings are made.
      - This patch also fixes a related bug where scrolling cache will not be enabled properly when transitioning from flinging to scrolling.
      - Patch Set 2: Calculate threshold based on maximum velocity (Sang Tae Park)
    • Frameworks: speed up statubar/notification drawer - IceColdJelly
      - a lot user complain about slow statusbar pull down introduced with jb 4.2....this speed it up
    • fb: Fix to NullPointerException when activity is relaunched
    • fb: Keyguard: Set WIDGET_CATEGORY_KEYGUARD when AppWidgetHostView is created
      - Allows the default lockscreen widget to inherit the keyguard widget host category. Without this, only widgets added through -KeyguardActivityLauncher are assigned the correct OPTION_APPWIDGET_HOST_CATEGORY.
    • fb: StorageManager: fix android.process.media process stop while plug a discontinuous partitioned SD Card
      - While get volume state, throw an IllegalArgumentException, catch this exception in StorageManager and return null to MtpService to avoid process stoping.
    • fb: Remove possible leak when exception occurred.
    • fb: Fix: external storage problem NavRing and NavBar applications - SlimROM
      - If the user binds an app which is located on the external sdcard and is rebooting the button icon will be left blank because the navring/navbar is already constructed before the sdcard is mounted. To avoid this we listen to the app available intents.
      - If it is not available the ring target/navbar button shows the none icon. When available it shows the correct app icon. So that the user can clearly see
      this app is accessable or not. As well when the user goes into mass storage mode or does unmount the sdcard or whatever case could happen that the application is not there.
    • Updated - QuickSettings: Update all QS drawables to fit KitKat (Patchset 8)
    • Updated cm source
    DOWNLOAD SITES
    temasek.hopto.org
    Dev-Host
    AndroidFileHost
    MediaFire
    __________________________________________________ ________________________________
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  5. I seguenti 3 Utenti hanno ringraziato almaximo per il post:
    criiistian (18-11-13),Enr1988 (18-11-13),Locaa92 (18-11-13)
  6. #664
    Non funziona più la tastiera per il resto sembra ok
  7. #665
    Venezia
    È uscito il kernel yank555 compatibile per questa rom lo sto provando con la v2 e sembra andar molto bene
  8. #666
    Androidiano VIP L'avatar di Enr1988
    Legend-DS-GS2-GS3-MotoG-Lg G2
    Ringraziato 989 volte in 743 Posts
    Quote Originariamente inviato da Volpe92 Visualizza il messaggio
    Al momento lo trovo meglio del sia in prestazioni che consumi rispetto al kernel di temasek.. Il tutto in accoppiata con la v3..
    Se ti ho aiutato usa il tasto THANKS per ringraziarmi!!
    [B]Oneplus 3/B] Oxygen Os Beta 19 Dorimanx Kernel
  9. Il seguente Utente ha ringraziato Enr1988 per il post:
    crazyniko (18-11-13)
  10. #667
    con la v4 il dialer mi va in crash
  11. #668
    Sep 2010
    Quote Originariamente inviato da criiistian Visualizza il messaggio
    problema noto su diversi utenti
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  12. #669
    Sep 2010
    uffa, ogni volta che aggiorno devo lottare con le gapps
    stamani erano spariti di nuovo calendario e gmail
    riflashato PA- Gapps modular e sono riapparsi ma......
    problemi con google search che va spesso in crash da solo (google now presumo) e con il servizio bluetotth transfer e ha iniziato a crashare in auto
    vabbè siamo alla versione 4
    Ultima modifica di almaximo; 18-11-13 alle 11:48
    Huawei Mate 10 Pro
    Huawei Mediapad M5
  13. #670
    Sep 2010
    Quote Originariamente inviato da Enr1988 Visualizza il messaggio
    come ci passo per provarlo ? lo flasho sopra e via o serve qualche wipe ?
    Huawei Mate 10 Pro
    Huawei Mediapad M5
