Tranquillo procedi
Tranquillo procedi
Se ti è piaciuto il mio lavoro offrimi un caffehttps://www.paypal.com/cgi-bin/websc...=DYAE6Q6K488AE
Bribbri (13-05-15)
Ultima modifica di Bribbri; 13-05-15 alle 16:04
sempre relativamente alla v. 10:
ho scelto in fase di installazione il launcher miui (ho sempre adorato le rom miui....) ma le scritte sono tutte in cinese, c'è possibilità di cambiarle?
I had the very same problem sometime ago. I restarted in recovery, connected the PC and then connected with the phone with adb becoming root with su. I discovered the correct cache partition (you can mount it from the recovery, grep on /proc/mounts to find the device and then umount it again) then zeroed it with dd. When it finished I recreated the filesystem by hand with mkfs. A tricky procedure but worked like a charm... you need some Linux skill to carry it out correctly.
Mah devo dire che l'autonomia della v10 mi ha un po' deluso... Ho l impressione che con la v5 reggeva di più
Forenait (13-05-15)
I had the very same problem sometime ago. I restarted in recovery, connected the PC and then connected with the phone with adb becoming root with su. I discovered the correct cache partition (you can mount it from the recovery, grep on /proc/mounts to find the device and then umount it again) then zeroed it with dd. When it finished I recreated the filesystem by hand with mkfs. A tricky procedure but worked like a charm... you need some Linux skill to carry it out correctly.[/QUOTE]
I just had the same problem totay.
Tray again whit battery charged at 100%
