Pagina 386 di 553 primaprima ... 286336376384385386387388396436486 ... ultimoultimo
Visualizzazione dei risultati da 3,851 a 3,860 su 5522
[ZOPO ZP999/3X-KOMU K8 4G] Marsapa rom
  1. #3851
    May 2015
    everytime
    Senior Droid L'avatar di ftorquy
    Abruzzo
    Ringraziato 93 volte in 89 Posts
    Quote Originariamente inviato da golanu Visualizza il messaggio
    Yes I can enter and I have tried several re-flashes - still same result, stuck at boot logo.
    Do you know Sp Flash tool?Try to flash v8.1:u can find it in post 1
    After u flash it try again to flash in recovery v10
    Ultima modifica di ftorquy; 17-05-15 alle 17:54
  4. #3853
    May 2015
    After flashing 8.1 with SP, should I perform a full wipe before flashing V10 in recovery mode?
  5. #3854
    Abruzzo
    Yes,is better to do full wipe eveytime u flash a new rom
  6. #3855
    May 2015
    I tried and same thing - stuck at boot logo.
  7. #3856
    Abruzzo
    Did you try with SP?Stuck at boot logo?It's not possible
  8. #3857
    May 2015
    The steps performed were the following:
    1. Flash 8.1 with SP (Firmware Upgrade option selected)
    2. Wipe data - Factory reset & Wipe Dalvik Cache - via recovery
    3. Install V10 from zip - via recovery
    4. Reboot
    5. Stuck at boot logo.
    What am I missing here?
  9. #3858
    Abruzzo
    4. Reboot
    After you flashed the 8.1 everything was good?
  10. #3859
    May 2015
    Yes, It starts fine.
  11. #3860
    Abruzzo
    Then is possible the file (v10 rom) was corrupted tries to re-download it.Let me know.
