Pagina 227 di 270 primaprima ... 127177217225226227228229237 ... ultimoultimo
Visualizzazione dei risultati da 2,261 a 2,270 su 2694
[ROM-AOSP][28-08-2011] The FroyoMOD v2.9.3- Beyond Froyo2!! xD
  1. #2261
    Senior Droid L'avatar di 89luca89
    May 2010
    Terracina (LT)
    Ringraziato 284 volte in 138 Posts
    RELEASED 2.8.0!
    2.8.0 Changelog
    Autoboot OR: add recovery command creation
    1% step battery (thanks kabaldan and GoodWin!)
    Lock Home in Memory
    New Memory Managment
    New Overclock
    Add selection of silent mode with volume control
    Add a long press option to the status bar widgets to open the corresponding settings!! (THANKS radadev on GitHub!!)
    Wifi icon will bring to Wifi Seings
    Blutooth icon will bring to Bluetooth settings
    Data/Newtwork/AirplaneMode button will bring to MobileData settings
    Brighness/Rotation/Screen Timeout will bring to DisplaySettings
    Sync icon will bring to Account Settings
    Gps/Lockscreen will bring to Gps and Security settings
    AudioMode button will bring to Audio Settings
    Flashlight button will bring to the Flashlight App!
    Buttons Are now Chooseable!! (Thanks Cvpcs)
    Allow disabling of dock observer
    Add the possibility to swap the volume keys in landscape mode (Thanks againg kabaldan for both! )
    Flashlight app+Button
    AttributeCache clear (again Master Kab xD)
    Slide notifications during swipe-to-clear (This is VERY Nice and Wonderful effect THanks evancharlton From GITHUB!!)
    Gallery 2D AOSP By Default --> Faster, lighter and AOSP! xD
    Music STOCK By default
    Launcher 2d AOSP By default, smaller memory print!! Faster!
    Fix FC In Edit Other Levels
    Fixed Overheat
    Fixed Not-so-ok overclock
    PACKAGES:
    Now included the AOSP 2d gallery
    Added also AOSP 3d Gallery
    Added MIUI Camera or Stock chooseable!! (FOR WHO WANT ALSO WIDESCREEN CAMERA!! )ù
    Added MIUI Music
    Spero vi piaccia!!!
    Per i Temi ci vuole un casotto di tempo e non ce l'ho.,..
    per ora...
    Basians Theme Ports The FroyoMOD [METAMORPH for OpenRecovery] - xda-developers
    Usate questi! I lavori di sto Tizio fanno paura! !!
    Enjoy!!
    >>>The FroyoMOD v2.7.0<<<
    >>> ROM:EclairMOD v0.3b <<<
    >>>Androidiani OpenRecovery by ME & Azhad<<<
    NEW-> HTC HD2-> Gingerbread+ubuntu
    Motorola Milestone, Rom FroyoMOD, 1,1ghz LV
    Nokia n97mini IoEsisto v8 CFW
    Nokia e51 hacked
    Nokia n800 Maemo/Android 1.6
  2. I seguenti 2 Utenti hanno ringraziato 89luca89 per il post:
    franzuso (27-05-11),SatanShark (26-05-11)
    Androidiano L'avatar di SatanShark
    Mar 2011
    Salerno
    Di già???
    La provo subito!
  5. #2263
    May 2010
    Terracina (LT)
    Eh si su Xda insistevano nel saltare i temi li rilascero dopo xD
    Nokia e51 hacked
  6. #2264
    Dec 2009
    scusa luca,ma poi devo riflashare anche le impostazioni che avevo scelto per l'overclock e la tastiera o quelle restano?
    qualche giorno fa avevo postato un problema per quello che riguardava l'utilizzo del gps con google navigator e copilot,hai avuto altri feedback in merito o sono problemi che ho avuto solo io?potrei provare a risolvere con un'installazione pulita dopo full wipe?
    grazie!!
  7. #2265
    May 2010
    Terracina (LT)
    Scusa il feed sul gps mi era sfuggito xD
    Comunque solitamente un full wipe risolve ogni problema!
    Riguardo i pack, bisogna reinstallarli e anzi riscaricali che alcuni sono aggiornati!!
    Nokia e51 hacked
  8. Il seguente Utente ha ringraziato 89luca89 per il post:
    andy206 (27-05-11)
  9. #2266
    Androidiano L'avatar di picobello
    Jan 2010
    milano
    Scaricata e installata!
    Per il momento tutto OK! Anche le mappe di google (che prima ogni tanto causavano il reset) per ora non danno problemi!
    Solito meritatissimo ringraziamento a Luca!!
    Ultima modifica di picobello; 27-05-11 alle 00:51
  10. #2267
    Jan 2011
    Quote Originariamente inviato da 89luca89 Visualizza il messaggio
    Grandissimo Luca! Se reinstallo il pack della tastiera HTC perdo tutti i termini che ho aggiunto al dizionario?? (Devo riscaricarlo o va bene quello della 2.7.0?)
  11. #2268
    May 2010
    Terracina (LT)
    Puoi backuppare i settings della tastiera HTC e poi fare ripristina
    Nokia e51 hacked
  12. Il seguente Utente ha ringraziato 89luca89 per il post:
    Lapidus (27-05-11)
  13. #2269
    89luca89, Grazie per il vostro lavoro, io uso la versione di froyomod ma l'unica cosa è modificare il kernel, che devia di Koreano Froyo è vecchio ma molto stabile e senza errori né DSI bisogno della correzione e anche le mosse rom molto molto velocemente senza problemi, non se vi capita di provare con questo kernel ed evitare il fastidioso effetto dello schermo dalla correzione DSI.
    Solo è un commento da Venezuela
    Jose Pedraja
    Utilizzo di traduttore di Google
  14. #2270
    89luca89, Thanks for your work, i use your version of froyomod but the only thing I modify is the kernel, which change by the Koreans who is older but very stable and no errors DSI nor need the fix and the same mind moves rom very very fast without problems, not if you happen to try with this kernel and avoid the annoying effect of the screen by the DSI fix.
    Solo is a comment from Venezuela
    Jose Pedraja
