Pagina 32 di 130 primaprima ... 2230313233344282 ... ultimoultimo
Visualizzazione dei risultati da 311 a 320 su 1298
[ROM LOLLIPOP Android 5 Mod By BB72 & Cuoco92] ZTE Nubia Z7 Max |COMBO ROM|
  1. #311
    Androidiano L'avatar di RDaneel
    Oct 2009
    N Z7 Max, Le 2Pro
    Ringraziato 33 volte in 24 Posts
    Aggiornamento effettuato. Tutto OK! Ancora una volta splendido lavoro, bravi!
  2. Il seguente Utente ha ringraziato RDaneel per il post:
    BB72 (01-05-15)
    Androidiano VIP L'avatar di pesa1234
    Nubia Z11 MAX - Z7Max
    Ringraziato 1,530 volte in 848 Posts
    Ora sono tornato alla combo e tutto OK... Mahhhhh
    Nubia Z7 Max - Z11 Max...
  5. #313
    Quote Originariamente inviato da pesa1234 Visualizza il messaggio
    Misteri di Android...
    Inviato dal mio LG-D858HK usando Androidiani App
  6. #314
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    BB72, I've tried to upgrade directly from your 3.08 beta0 to 3.09 beta1 modifiying your upgrade script and everything has worked.
    Many changes in icon set for being only a minor upgrade. ROM is also more fluid than 3.08.
    I don't know if stock 3.09 upgrade touch more partitions beside system and boot, but at least for me this direct upgrade has worked properly.
    Grazie!
  7. Il seguente Utente ha ringraziato inigoml per il post:
    BB72 (01-05-15)
  8. #315
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    Grazie!
    Well this is good but I'm sure 3.09 stock corrects and modify others partitions...thetefore I always suggest to install 3.09 stock before...
  9. #316
    Oct 2014
    Ringraziato 16 volte in 12 Posts
    Hi BB,
    I have done factory restore of Stock 3.09 because I already updated Two days before so before upgrade I want everything to wipe.
    But I don't know, something happened and phone went brick. Only bootloader is working.
    But some how I found in Chinese website and install cwm recovery via bootloader and install your 3.08 beta and recovered the phone.
    I will give my comments after install your 3.09
    Thanks for the support.
  10. #317
    Quote Originariamente inviato da niza2000in Visualizza il messaggio
    Hi BB,
    Maybe you did system wipe before to install Rom...if so it is why you got problem...only 3 wipes MUST BE DONE...DATA-CACHE-DALVIK CACHE
  11. Il seguente Utente ha ringraziato BB72 per il post:
    niza2000in (01-05-15)
  12. #318
    Oct 2014
    Yes I have done system wipe because when I done data,cache,dalviche phone was on but its stuck up in the initial setup.
    I noticed your warning message should not do system wipe, but I took chance if we wipe everything phone will be on, there I did the mistake and phone got brick.
    With the help of silence star install Chinese cwm via bootloader and restored now ☺
  13. #319
    Oct 2014
  14. #320
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Quindi non ho capito bb anche aggiornando tramite recovery dalla 3.08 alla 3.09 tutto é ok ?
