Non puoi scaricarlo direttamente sul cell perchè è un file zip..
Questo è quello che cambia dalla 3.6
Added 2 kernels: Vitaliy 26_10 & Stock KQ7 (you can use it to avoid problems with car charging Cradle)
Added apps: NotiGo, NoLock
Changed Skype to 2.0.0.47 version
Fixed problem of alarm clock the problem of alarm clock (FC when unlocking after alarm)
Framework with menu animations in default install, in option to choose framework without animations.
Changed init.d & build.prop a little
Gps.conf set to Europe/Poland You can easy change this just put Your country server onto list.
Added new version of lockers, launchers.
LinkBack URL
About LinkBacks
Rispondi quotando
Ultima modifica di massibolo; 02-04-12 alle
