Pagina 178 di 226 primaprima ... 78128168176177178179180188 ... ultimoultimo
Visualizzazione dei risultati da 1,771 a 1,780 su 2259
[Info][Pareri] Thl T100
  1. #1771
    Senior Droid L'avatar di rockrider81
    Ringraziato 164 volte in 135 Posts
    Ciao
    forse mi sbaglio ma ho notato una news datata OGGI -> September 19, 2014 1:08:42 AM <- sul sito THL ...
    Non so se si tratta di una ROM funzionante "ufficiale" .
    Provate a leggere : THL Technology Happy Life News - THL T100S Android 4.4 Lastest Firmware
    Friday, September 19, 2014 1:08:42 AM America/Los_Angeles
    ROM Phone THL T100S – ROM Android 4.4.2
    ONLY MT6592 + Motherboard 1363GH
    Official ROM THL T100S version: thl_T100S.159D.A2.KK.FHD.B1B5.EN.16P256.IMX135.MT6 592GW.20140909 – V1_WCDMA
    ATTENTION This Rom is given For a Motherboard 1363GH
    If your "Build number" = " thl_T100S.159D.A2.JB9.FHD………" = it's good, else not installed this rom
    Gapps include – No Rooted
    Language support: Multilang
    Install ROM:
    - Unpack FlashTools, and Click on Flash_tool.exe
    - Select a the MT6592_Android_scatter.txt in ROM
    - Wait file to be added into Flash Tool
    - choose Option->USB Model,click USB Model
    –> Choose Option->DA DownLoad All->Speed->High Speed, click High Speed
    - Turn off your phone, remove the battery.
    - "Press F9 (hit Download button)" OR " if upgrade ROM Firmware->Upgrade "
    - and connect your phone into the computer via USB data cable.
    - The process will start and a red progress bar will appear after color purple, yellow.
    - And green circles display
    - Finish !
    - You can now safely disconnect your phone and turn it on.
    Download: THL T100S Android 4.4 Firmware
    Flashtools
    Posted in News By THL Mobile
    Xiaomi Mi9TPro - Xiaomi Mi5s Plus - Xiaomi RedMi Note 2 - ZOPO ZP920 - THL T100S GOLD - ZOPO ZP810 - H7500+ - HTC HD2 - Tablet Voyo Q101 MTK6753 - iPhone 4s (venduto) 5s ( venduto) ) 6s - iPod Touch 5 , Samsung Galaxy S4 - AC8227L Android Car Audio ROM YT9213B
    Aug 2014
    Ringraziato 16 volte in 11 Posts
    È la prima rom uscita su need, quindi non mi sbagliavo a pensare che fosse veramente quella ufficiale... La rom la ho provata e sinceramente thl poteva lavorarci un po più sopra... Mi affido ai modder di needrom e spero che facciano un ottimo lavoro.
    Inviato dal mio THL T100S usando Androidiani App
  4. #1773
    Androidiano L'avatar di Ommadawn
    Aug 2014
    Quote Originariamente inviato da rockrider81 Visualizza il messaggio
    Ciao
    Install ROM:
    - Finish !
    Flashtools
    Boh, le cose sono sue: o hanno fatto un copia/incolla da needrom (stesso identico articolo) compresa la rom, oppure c'è veramente una nuova release e per la procedura hanno attinto a una guida nota.
    The watcher and the tower
    Waiting hour by hour
  5. #1774
    Il titolo è quello ,
    ho controllato dentro i singoli file e li ho paragonati con quella di Needrom ...
    PURTROPPO E' LA STESSA ROM
    Vabbè dai ...
    Qualcuno ha notato quale messaggio della THL su facebook ? Io qui dall'azienda non ci entro ...
    Magari il 25/09 è veramente la data di rilascio della ufficiale funzionante ... boh .. altrimenti tocca metterci a lavorare per sistemarla e tamponare i problemi ...
  6. #1775
    se leggete bene nel build number: thl_T100S.159D.A2.KK.FHD.B1B5.EN.16P256.IMX135.MT6 592GW.20140909 – V1_WCDMA c'è scritto V1 quindi questo mi fa pensare che sia solo una rom di test se ricordo bene una cosa simile è successa anche a iocean con l'x8 dove prima di rilasciare l'aggiornamento vero e proprio rilasciarono una rom beta penso che sia lo stesso caso speriamo bene io ci credo poiche anche a me quando li ho contattati mi hanno confermato che il 25 sarebbe uscita
  7. #1776
    Ringraziato 23 volte in 13 Posts
    io ho la 159D + twrp2.7.1.0 SevenMax quando tento installazione da recovery mi da failed seguito da questo (updating partition details …. kernel does not have support for reading s and Linux contexts. e: unableto open zip file error flashing zip '/ EMMC / t100-on. zip ( la mia buil e del 201/02/25)
  8. #1777
    Quote Originariamente inviato da alberto300 Visualizza il messaggio
    reinstallato da capo rom del 2/25/2014 fatto root installata twrp tutto ok ma quando vado ad installare le rom esempio la hibrid o la cm11 mi da instllazione fallita provato anche wipe. ora mi chiedo quando il 25 uscirà la kitkat porò installare da ota?
  9. #1778
    Aug 2014
    io per i flash di rom ho sempre utilizzato la recovery cwm clockwordmod. ROM CWM&TWRP THL T100 | [Custom] add the 01/12/2014 on Needrom
    puoi provare a scaricare le diverse rom da qui, per flasharle facilmente puoi utilizzare l'app "rashr" scaricabile dal play store.
  10. #1779
    Aug 2014
    Oggi è 25... e tutto tace!
  11. #1780
    si spera in bene...
