Utente della settimana: megthebest con ben 17 Thanks ricevuti negli ultimi sette giorni
Utente del mese: megthebest con ben 47 Thanks ricevuti nell'ultimo mese
Pagina 27 di 62 primaprima ... 17252627282937 ... ultimoultimo
Visualizzazione dei risultati da 261 a 270 su 618
Guida di unbrick z7 max-mini
  1. #261
    Androidiano VIP L'avatar di manuelb
    Honor 6 Plus/Opo/Asus tf300t
    Ringraziato 670 volte in 497 Posts
    Yunos phone no oneplus!!!!! I can't read the photo...photo is reduced....baaahhhh...senza parole...however how you brick it ?
    Inviato dal mio z7 max 48000 antutu usando Androidiani App
    Feb 2015
    I wanted to resize mine partition.
    With the software on nubia forum is wanted to change it in 16+16.
    It came back with 32+0.
    I trey it again is there was the brick.
    The photo: when i go to Open Disk management Console (right side on the bottum above Continue)
    Secund screen
    Drives must be initialized before you can through management for logical access. Drive one.
    The following partition style to use for the selected disks: MBR or GPT
    I look it up what that mean:
    Before an empty disk can be used will have to be initialized first. Initialization takes place on the first sector of a hard drive and set the operating system unable to boot and also contains the partition table. By partitioning is indicated which part of the hard disk may be used.
    It looks like I have to initialize en then probably format it?
    Can I sent the picture directly to you on one way of another?
  4. #263
    Quote Originariamente inviato da Jan1959 Visualizza il messaggio
    Secund screen
    No no you mustn't format !! Upload photo on mega and give me link...
  5. #264
    Jan 2015
    Hi, if pc now view phone no touch o reformat emmc. With nubia tools simple reprogramming rom, all partitions included in this rom.
  6. #265
    Feb 2015
  7. #266
    Feb 2015
    I choose antoher dirver ZTE Composite ADB Interface
    I was accepted but Id is stil 19
    Is that good or......
    New info
    In miy computer i can not see it still.
    I wil go for now and try tomorrow again.
    Ultima modifica di Jan1959; 07-02-15 alle 22:31 - Motivo: new info
  8. #267
    Cracky tu quando hai flashato il boot hai selezionato mbr vero ? No gpt
  9. #268
    Feb 2015
    Quote Originariamente inviato da manuelb Visualizza il messaggio
    I dont understand thequestion.
    Google says: Cracky you when you flashed boot mbr have selected it? No gpt
    When I go to boot manager i get a question to initalize the Z7 drive.
    At this moment i did NOT initalize in HDD raw the Z7 drive.
    I write recovery.img once again succesfull and try several times to change the driver
    No success stil id 19
    Ultima modifica di Jan1959; 08-02-15 alle 10:21 - Motivo: Extra information afterwards
  10. #269
    this message is for cracky not for you..
  11. #270
    Feb 2015
    Sorry I'm not italian but french so I submit my post in english.
    I've read almost all the posts of this thread but not seen similar issue as I face.
    My Z7 mini is bricked.
    I installed the required driver 'Qualcomm QDLoader 9008' and my phone i detected as such when connected to my PC (windows 7 64 bits).
    I start Nubia ToolStudio and click refresh.
    My phone appears in the list associated with the correct com port.
    But after 1 seconds the phone disappears from the device list of my computer then reappears a few seconds (3 or 4) later.
    So when I click the 'Start' button in the nubia ToolStudio, I get an error.
    Does anyone already faced the same issue ? Any suggestion ?
    Thanks.
