digitalboyz
questo changelog secondo te corrisponde alla tua descrizione?
ma vi rileggete quando fate certe assurte affermazioni?!
Invece di ringraziare!
- Removed Alcatel-Customized Launcher and replaced by Nova Launcher
- Updated Keyboard
- Touchscreen sensitivity improved
- Removed all Vodafone Apps
- Removed Power On and Power Off Vodafone Animations (Only displayed for 1 seconds while powering on)
- Removed Alcatel File manager and replaced with ES File Explorer
- Rooted
- Changed some icons when status bar is expanded with Nexus ones (much better)
- Make APN for Tethering adjustable
- White color for carrier and date text in status bar (More clean and elegant)
- CRT Animations for ScreenOff
- Rotations upside-down now enabled
- Original Google icon in settings menu
- DSPManager from CM10 (Good Equalizer)
- Calculator from CM10 with great functions
- Improved Speed
- init.d support
- Removed Chrome
- SMS app from CM10
- CMWallpapapers added
- Vodafone Credit can be used to pay in Playstore
- StatusBar Expanded modified
- (Two blue lines have same width now, Removed floating carrier label, dots instead of squares under quick toggles)
