Pagina 36 di 123 primaprima ... 2634353637384686 ... ultimoultimo
Visualizzazione dei risultati da 351 a 360 su 1226
[Box Tv] Beelink Mini MX (Amlogic S905 -1gb Ram-8gb flash)
  1. #351
    Androidiano di Riferimento L'avatar di anthonytex
    Ringraziato 402 volte in 277 Posts
    Quote Originariamente inviato da vn800art Visualizza il messaggio
    Aggiornamento applicato sull'ultimo Mx arrivato. Sul precedente, dove avevo aperto in R/w il sistema, anche dopo aver risistemato l' unica modifica effettuata, gli aggiornamenti restano bloccati!!!!!! Dovró sistemare in altro modo €%&*#@!
    Ed ecco il changelog completo
    Mini MX Software update,Firmware Version: s905_105L1
    Based versions: s905_104L1
    Updated content:
    1.Make wifi MAC address customization;
    2.Update Kodi for the official website of the Kodi 16 BETA5, to solve the problem of Kodi 4K video playback;
    3.Solve the problem of screen broken when played a part of 4k video sources;
    4.Support HLS V5 libplayer;
    5.Solve the problem of the probability occurrence of picture frame problem when continuously testing UHD video playback;
    6.Solve the problem of MXplayer stuck and progress bar abnormal when playing local video;
    7.Solve the problem of mpeg2 dash video can’t play;
    8.Solve the problem of screen stuck when playing rtspH265 video;
    9.Solve the problem of playing some of the online video is not synchronized;
    10.Solve the problem of screen black when playing some of H265 video;
    11.Solve the problem of occasionally flash full screen stripes when switching channels;
    12.Solve the problem of HDMI Passthrough play TRUE-HD audio track video silent and screen stuck;
    13.GPU optimized;
    14.Support Google Widevine L3;
    15.Solve the problem of some online video play pause after a period of time can't restore play;
    16.Solve the problem of connecting the mobile hard disk to display the total storage space is only 10M;
    17.Solve the problem of restart and serious stuck after running long time game;
    18.Solve the first broadcast truehd audio broadcast other video again hdmi passthrough silent problem;
    19.Solve the problem of WiFi transmit picture too slow;
    20.Solve the CVBS video broadcast and then switch to HDMI video down to the upper left corner but exit back to normal;
    21.Solve the problem of 4K H264 video broadcast images randomly flashing;
    22.Solve the udp streaming multicast embedded dvdsubtitle dolby sound ts stream cannot display subtitles problem;
    23.Solve the problem of unable to play HLS MP4 stream;
    24.Solve the problem of screen blackout after network adaptive video seek;
    25.Solve the problem of no subtitles when stream HLS V5 under .vtt format;
    26.Solve the probability of occurrence of a black boot that need to plug HDMI line recovery problem;
    27.Solve the problem of no output or output screen flashing after the standby wake up;
    28.Solve the switch from HDMI to CVBS restart and then cut back to HDMI output appears the problem of the white image;
    29.Solve the problem of no output after standby awakening even pull plug HDMI line;
    30.Solve the problem of stuck on the boot image;
    USB--brush machine file:
    Chained address:http://pan.baidu.com/s/1hrpTh5q password:ckcl
    Card--brush machine file:
    Chained address:http://pan.baidu.com/s/1kUkxk2b password:arqn
    Translation(OTA升级)
    1.If the network did not receive FOTA upgrade notification, can use the remote reboot, or recharging;
    2.After Pop-up notification of the upgrade, pay attention to choose to upgrade, because the default button is not in the location of the upgrade, the need to use the remote control to select or click the mouse to choose; upgrade process do not interrupt;
    3.If there is no option to upgrade, then after a period of time (3 days of a cycle) will pop up again upgrade notification;
    4.Under the condition of the Network, if manual to OTA upgrade interface (System update), prompt the Network connection failed, so is OTA server has a problem or adjustment, appear this kind of circumstance, can timely feedback.
    Widevine enable L3 . Più altre migliorie su H265 e audio hd, mi sembra buono! Ma come sempre Netflix fungeva già sulla 104!
    Non male dopo testo se ci sono miglioramenti col passthrought
    GUIDA sull'installazione e INFO su LibreELEC
    INFO su "che cos' è il passthrough?"
    s2 plus aicp 5.1
    Quote Originariamente inviato da krasty87 Visualizza il messaggio
    Quindi non esiste una soluzione per controllare il mini mx con il cell in remoto con qualche app?
    Io su android ho installato "Smart iRemote" (della Fustec Co.) e funziona benissimo.
    Ciao
  4. Il seguente Utente ha ringraziato rikipel per il post:
    krasty87 (31-01-16)
  5. #353
    Androidiano VIP L'avatar di vn800art
    Ringraziato 190 volte in 168 Posts
    Quote Originariamente inviato da rikipel Visualizza il messaggio
    Ciao
    Su Android in generale puoi usare REMOTEIME e puoi provare GOOGLE TV REMOTE.
    Specifico x Kodi c'è Kore che è proprio il suo.
    Ciao a tutti e due ( anche @krasty87 ).
    Sono Mister Wolf, risolvo problemi..... (cit. da Pulp Fiction) .... Se ti ho aiutato, a sinistra sul PC c'è il tasto THANKS, usalo !
  6. Il seguente Utente ha ringraziato vn800art per il post:
    krasty87 (31-01-16)
  7. #354
    Feb 2015
    Quote Originariamente inviato da anthonytex Visualizza il messaggio
    se ti riferisci a kodi, per quanto mi riguarda persistono i problemi con il passthrought.
    Inviato dal mio HUAWEI G7-L01 usando Androidiani App
  8. #355
    Jan 2016
    Ciao
    Ciao l'ho installato ora ma non riesco a trovare il dispositivo mimi mx tra l'elenco..e poi c'è il mouse e la tastiera nel telecomando?
  9. #356
    s2 plus aicp 5.1
    devi avere il cellulare connesso alla stessa rete del mini mx.
    Ultima modifica di rikipel; 31-01-16 alle 20:24
  10. #357
    Jan 2016
    Quote Originariamente inviato da VIGE967 Visualizza il messaggio
    A me da problemi con entrambe le connessioni, praticamente i flussi dd e dts vengono riprodotti con delle micro interruzioni cadenzate ogni 15 secondi circa, visibile anche dal display dell'amplificatore con il lampeggio dei simboli delle 5 casse, con la App del preinstallata riproduttore video invece tutto ok
    Confermo lo stesso problema. Da quanto ho capito spulciando sui forum in inglese è un problema difficilmente risolvibile legato all'hardware e non so se kodi funzionerà mai bene in tal senso con l's905...
    Ultima modifica di dieghe78; 31-01-16 alle 21:16
  11. #358
    Oct 2014
    Ringraziato 26 volte in 22 Posts
    Quote Originariamente inviato da dieghe78 Visualizza il messaggio
    È un vero peccato, per il resto è un bel box, io per ora sono tornato al vecchio MX III il nuovo l'ho passato al vicino di casa che lo collega solo al TV
  12. #359
    Landvo L200, Doogee X5 pro
    Ringraziato 975 volte in 788 Posts
    Quote Originariamente inviato da GianP09 Visualizza il messaggio
    per l'aggiornamento alla 105 nessun problema, sono circa 60mb, a differenza della 104 che era poco più di 20mb, di certo volumi che non prevedono grossi cambiamenti.
    per ora è tornata l'app cinese del pesciolino e un launcher per kodi sempre cinese, disinstallati all'istante ovviamente
    ora il tempo di capire cosa va e cosa no
    edit:
    - kodi 15.2 va continuamente in crash e blocca il sistema (proverò con la jarvis)
    - non risolti i problemi con chrome, crash vhe manda in blocco il sistema.
    ...cominciamo male.
    I problemi che persistono con chrome in effetti non mi piacciono per nulla, anche se ora per tamponare utilizzo sia il browser nativo che puffin browser che ha supporto nativo a flash player.
    Anche i problemi con Kodi sono preoccupanti, mi sa che questa volta Beelink il firmware l'ha fatto uscire un po' troppo prematuro vista anche la quantità di bugfix con l'ultima release, niente a che vedere con la stabilità dei firmware dell'mxq (non sono mai riuscito a farlo crashare in un anno di utilizzo ). Ma nulla esclude che ci sia anche lo zampino di Amlogic in tutto questo, temo sia proprio il soc s905 che non è nato molto bene, perchè a ben guardare un po' tutti i box usciti recentemente con questo tipo di soc non sono esenti da problemi (Minix U1 incluso)
    Diciamo che per il mio uso per ora va abbastanza bene così visto che io il box lo collego solo al televisore e quindi non risento delle varie problematiche con l'audio in passthrough che in questa discussione molti di voi stanno riscontrando.
    Tra l'altro, per alleggerire un po' la quantità di memoria usata all'avvio sto usando un launcher alternativo (squarehome.tablet, in stile Metro UI) che mi garantisce un po' di sprint in più durante l'uso.
  13. #360
    Allora riassumendo: settando il passthrought sia con Spdif che con HDMI si hanno micro interruzioni (fastidiose ) dell'audio giusto? Almeno questo accade a me e a molti di voi mi pare di aver capito, ieri ho scritto che andava bene ma evidentemente avevo testato con volume talmente basso e per poco tempo che non ci ho fatto caso(mea culpa)... Se non si setta il passthrought MA 5.1 canali confermo (come hai detto tu @GianP09) che va in blocco tutto quindi per chi ha qualche film con audio in opus /AAC /FLAC multicanale che non viene passato usando il passthrought deve accontentarsi dell'audio in stereo!
