Pagina 18 di 31 primaprima ... 8161718192028 ... ultimoultimo
Visualizzazione dei risultati da 171 a 180 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #171
    Jul 2015
    Nice! Good News!
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    I have fixed the bootloop problem
    with the new build id the kernel need some patch
    so...I started a new kernel from scratch with the latest codeaurora compatible version (https://www.codeaurora.org/cgit/quic...LA.BF.1.1.1.c5)
    now I have to add all the features that I had put into the old kernel
    Fantastic!
    So, this weekend we will enjoy testing a new ROM... je, je... Great, Paolo. We love you! :-D
    Ultima modifica di inigoml; 18-09-15 alle 11:01
  4. #173
    ok I'm done with the new kernel
    this morning I updated the cm sources code and I compiled the V13
    it works for me without bootloop (I did two tests: update from the V11 and flash with full wipe)
    anyone wants to try it just to have another test before I release this version to all ?
    Ultima modifica di PaoloW8; 18-09-15 alle 13:58
    Nubia Z7MAX
  5. #174
    May 2015
    Madrid, Spain
    Nubia z7 max
    it works for me (I did two tests: update from the V11 and flash with full wipe)
    Send me the link and I will give a try.
  6. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (18-09-15)
  7. #175
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    thanks !
    link sent
    Nubia Z7MAX
  8. #176
    May 2015
    Madrid, Spain
    Nubia z7 max
    thanks !
    link sent
    Working without any problem. Also entering into deep sleep correctly. :-)
  9. Il seguente Utente ha ringraziato inigoml per il post:
    PaoloW8 (18-09-15)
  10. #177
    perfect, thanks !
    Nubia Z7MAX
  11. #178
    link and changelog V13 in first page
    Nubia Z7MAX
  12. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (18-09-15)
  13. #179
    Sep 2015
    Thx a lot for your rom.I notice that carbonrom had stopped updating in recent two versions.
    I have use carbonrom for about a month and love it very much.
    And i wonder whether it will update again?
    Thanks.
  14. #180
    Jan 2015
    Nubia Z7 Max
    Hi Paolo and thanks for your great work
    However, I have a bug report for V13: when the screen is unlocked and a call is incoming (the white popup at the top of the screen; sorry, I tried to put a screenshot here but the forum software doesn't seem to let me), only the number is displayed and not the contact name. When the screen is locked and an incoming call happens everything works fine.
    I believe it's a regression since V11 didn't have the bug.
