Pagina 17 di 31 primaprima ... 7151617181927 ... ultimoultimo
Visualizzazione dei risultati da 161 a 170 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #161
    Jul 2015
    I also have problems while doing the update from V11 to V12.
    I flash the V12 over V11 and also flashed the radio 357 in recovery, then I reboot the phone.
    after long time waiting (android updating , apps optimization) the phone reboot by itself and enter boot loop....
    I am downgrade the radio to 356 and still trying to see what will happen...
    Jul 2015
    I have the same problems as you.
  4. #163
    Feb 2014
    a full wipe has not helped the Baseband 357 it can not but be that I had already on it, I had the feeling of the touchscreen is not responding.
  5. #164
    Jul 2015
    Quote Originariamente inviato da migel121 Visualizza il messaggio
    I am also failed after doing the full wipe on V12 + radio 357 or 356
    Ultima modifica di securecrt; 16-09-15 alle 08:31
  6. #165
    lol...I don't know why...to me it working well since yesterday
    check if md5 is correct:
    codice:
    paolo@LinuxPC:~/Android/cm12.1/out/target/product/nx505j$ md5sum cm-12.1_nx505j-20150915-Rel_V12.zip
    657c89a31fd77b93b6a2605b97f1dc7c  cm-12.1_nx505j-20150915-Rel_V12.zip
    anyway, for the moment stay with the V11 meanwhile I do some checking
    (baseband 357 can be used with V11)
    Ultima modifica di PaoloW8; 16-09-15 alle 09:20
    Nubia Z7MAX
  7. #166
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Tested radio 3.57 with V11. Everything running without problem.
    It appear to be a problem with V12 only. Perhaps only if coming from V11 without full wipe, but today I'm very lazy to perform a full wipe... :-)
  8. #167
    Jul 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    codice:
    I have double checked the md5 it is same as yours.
    now I will stay on the V11 + Radio 357.
  9. #168
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    don't try
    on my phone...update from V11 (with only wipe cache and dalvik) works well
    but now I tried with a full wipe and I have the bootloop
    so....I try to understand what is the problem
    Nubia Z7MAX
  10. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (16-09-15),migel121 (16-09-15),securecrt (16-09-15)
  11. #169
    May 2015
    Madrid, Spain
    Nubia z7 max
    don't try
    If syncing from CM12.1 trunk, It could be a CM issue. Sometimes these things happen with mainstream...
  12. #170
    I have fixed the bootloop problem
    with the new build id the kernel need some patch
    so...I started a new kernel from scratch with the latest codeaurora compatible version (https://www.codeaurora.org/cgit/quic...LA.BF.1.1.1.c5)
    now I have to add all the features that I had put into the old kernel
    Nubia Z7MAX
  13. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    BaSch83 (18-09-15),inigoml (18-09-15),securecrt (18-09-15)
