Pagina 27 di 31 primaprima ... 172526272829 ... ultimoultimo
Visualizzazione dei risultati da 261 a 270 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #261
    Androidiano L'avatar di LiveMoto
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Ringraziato 22 volte in 14 Posts
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    with the apk keytest you see the scancode of all button or only one ?
    TWO!
    CENTER and one VOL
    code 226, 257
    4PDA community from Russia
    Quote Originariamente inviato da LiveMoto Visualizza il messaggio
    ok thanks
    tomorrow I will try some changes on kernel source
    but I don't have this headset so I can't test if work
    then...i will send it to you
    Nubia Z7MAX
  4. Il seguente Utente ha ringraziato PaoloW8 per il post:
    LiveMoto (19-11-15)
  5. #263
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Yeah! Super! Good luck and Have fun from work
    I think really the reason lies in this: https://www.androidiani.com/forum/in...ml#post7216791
    PS I express interest in community 4PDA, some users have with the community also want it.
    I pay your morning coffee on the PayPal
    Ultima modifica di LiveMoto; 19-11-15 alle 18:50
  6. Il seguente Utente ha ringraziato LiveMoto per il post:
    PaoloW8 (20-11-15)
  7. #264
    Nov 2015
    Hello one question: the phone is always in Airplane Mode.
    Yes i can disable airplane mode but it says "turn off airplane mode"
    I tried so many Nubia Roms.. has this to do with QPST and Winhex settings ?
  8. #265
    Quote Originariamente inviato da ForeignDude Visualizza il messaggio
    I think yes
    you have already tried to reflash entirely the firmware stock with nubia tools ?
    Nubia Z7MAX
  9. #266
    Nov 2015
    flashed baseband version 3.55 and 3.65 both dont work, i will try somethings in qpst
  10. #267
    try to flash all phone with nubia tools and not only the baseband
    ROM Nubia Z7 Max v3.09 | [Official] add the 04/28/2015 on Needrom
    Nubia Z7MAX
  11. #268
    Aug 2015
    hello v18 has several small problem.
    Preferred SIM for Calls can't keep "Ask every time" ,it will change from "Ask every time" to card 2 every reboot.
    Double-tap to wake will be turned off when reboot some time,
    Can CM12.1 take settings Heads UP for every single app?
    because if it only for all apps, Dialer's Heads UP can't display name when my friends call me some time.it only disphay their phone numble.
  12. #269
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Paolo.
    I've been doing a snapshot of the camera. For several months notice incorrect work of the camera application.
    Sometimes the captured image is not stored on the phone, sometimes instead preserved black square.
    In addition, if you enable the phone network WCDMA/LTE without GSM, the camera application will continuously restart if the network is lost signal. Helps enable Air-mode.
    Very often, photographs are not recorded, but can not figure out the algorithm of actions.
    Ultima modifica di LiveMoto; 04-12-15 alle 09:35
  13. #270
    Jul 2015
    Russia, Ul'yanovsk
    ZTE z7 Max
    Thumbs up
    Paolo.
    And please, update CM12 and BlissPop ROM.
    Thanks!
