Pagina 7 di 31 primaprima ... 5678917 ... ultimoultimo
Visualizzazione dei risultati da 61 a 70 su 305
[ROM] [ZTE Z7MAX] [Android 5.1.1] CM 12.1 unofficial
  1. #61
    Quote Originariamente inviato da securecrt Visualizza il messaggio
    wow , nice ...... can't wait to test the new kernel...
    check your PM
  2. Il seguente Utente ha ringraziato PaoloW8 per il post:
    securecrt (07-08-15)
    release V5 and changelog in first page
  5. I seguenti 3 Utenti hanno ringraziato PaoloW8 per il post:
    bubbl3 (08-08-15),luiseteyo (08-08-15),securecrt (08-08-15)
  6. #63
    Jan 2015
    Hello
    I am in v2 version.
    If I want go to v5 version, will I lost all the data (phone, sms, appli, ...) and will I must reinstall all ?
    Thks
  7. #64
    no, just do a wipe cache and dalvik cache and flash over
    (better if you make a full backup in recovery before doing it all)
  8. #65
    Baby Droid L'avatar di brooklyn2006
    Aug 2015
    Russia
    ZTE Nubia Z7 max
    Thank you Paolo for V5 Release!
    You can add to the next release of the automatic call record?
  9. #66
    Quote Originariamente inviato da brooklyn2006 Visualizza il messaggio
    I do not think that the cm12.1 has this feature
  10. #67
    Jan 2015
    Hi,
    here is my problem with the Roma.
    I do not know if this is due to the passage v5 because it seems to me that I had no problems with the v2.
    I have a lot of enormously 4g see the same at all.
    i still question marks on the network icons, and I have more data connections.
    Yet everything is set and everything worked well before.
    Best regards
  11. #68
    Jan 2015
    Dublin (Ireland)
    ZTE Nubia Z7 Max
    Quote Originariamente inviato da Kokireg Visualizza il messaggio
    Hi,
    Best regards
    I can't really understand what you mean, would suggest you to upload some screenshots.
  12. #69
    Jan 2015
    this is what appears ca me and I have more data.
    Occasionally the data not long but almost never work in 4G.
    before it worked very well in V2
  13. #70
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Red face
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    Wow!!! You are the best, Paolo. ;-) You fixed touch panel!!!!
    Testing now.
