Pagina 31 di 50 primaprima ... 21293031323341 ... ultimoultimo
Visualizzazione dei risultati da 301 a 310 su 491
[ROM] [ZTE Z7MAX] [Android 6.0] CM 13.0 unofficial
  1. #301
    Nov 2015
    Quote Originariamente inviato da paolothlw8 Visualizza il messaggio
    updated
    yes, root explorer no longer works on CM13, the app needs to be updated
    Thanks!Paolo
    Jan 2016
    Hello paolothlw8!
    Thank you very much for the Z7MAX compiled CM series.
    I'm using China Telecom single card, CM13 use very smooth, everything is normal others.
    But there is a problem, there is a certain probability of incoming or outgoing phone automatically hang up, usually within a minute of call will be the failure, not tested hands-free state, attempts have been replaced baseband 322 and 373, can not eliminate the fault.
    Based on revised MOKEE MK60.1 CM also appeared the same fault.
    If you can fix the problem, then the CM13 will be perfect.
    Telecommunications 4G: TD-LTE, FDD-LTE;
    Telecom 3G: CDMA2000;
    Telecom 2G: CDMA.
    Sorry, my English ability is not good, these are generated by google translation.
  4. #303
    Jan 2016
    Thanks!Paolo
  5. #304
    link release V1 in first page
    Nubia Z7MAX
  6. #305
    May 2015
    Madrid, Spain
    Nubia z7 max
    Ringraziato 21 volte in 16 Posts
    Great. Version 1... we are GA now!!! And with February security patches ! ;-)
    By the way, with beta8 bluetooth gate was still present after a couple of hours. Hope CM team will fix this issue in latest commits! ;-)
    Thank you, Paolo, as usual....
    Think about Xiaomi Mi 5.... };-D
  7. #306
    May 2015
    Madrid, Spain
    Nubia z7 max
    It's me or incoming phone calls do not sound???
  8. #307
    May 2015
    Madrid, Spain
    Nubia z7 max
    Quote Originariamente inviato da inigoml Visualizza il messaggio
    After testing everything (disable sound profiles, select several ringtones, checking sound manager, checking event notifier options, do not disturb, etc).... solved by the looser way... reboot phone.
  9. #308
    Feb 2016
    Hi paolo. Thx for you great work and rom for this phone. I have 2 questions. I want to revert to stock lolipop and I'm trying to open factory ports but after typing *#7678# or any other combination for that setting I don't get the option for opening the ports.
    The second question is, if I have to send my device back to China what is the safest way to revert to 4.4.2 android. Through nubia installer and how do I flash the stock recovery and rom over twrp and this rom???
    Thank you very much
  10. #309
    Quote Originariamente inviato da MonkPsycho Visualizza il messaggio
    Thank you very much
    for the port setting I wrote a little guide (very little) some time ago here
    with nubia tools the phone is completely flashed (also the stock recovery so you don't need to flash it)
    Nubia Z7MAX
  11. #310
    May 2015
    Madrid, Spain
    Nubia z7 max
    Look at BB72 ROM nubia Z7 thread. I remember there was a revert procedure for downgrade. But you can also install a clean official Lollipop build and nobody could tell you anything.
